//Let's say we have a stored byte but it can only have a value between 0-15 by default
uint8_t storedByte = 0;
//we have another variable which is intended to be stored on the upper bits of storedByte with reduced precision
uint8_t variable = 0;
//first limit previously stored value to be sure
//if (storedByte > 15)
// storedByte = 15;
storedByte &= 0x0F;
//also limit variable for the available bits
if (variable > 150)
variable = 150;
storedByte += (uint8_t)((float)variable * 0.1f) << 4;
//Bitwise Or results the same value in every case??
storedByte |= (uint8_t)((float)variable * 0.1f) << 4;
c '1' 0x31, b 0x01, storedByte 0x10
c '2' 0x32, b 0x02, storedByte 0x21
c 'a' 0x61, b 0x0a, storedByte 0xa2
c 'b' 0x62, b 0x0b, storedByte 0xba
c 'c' 0x63, b 0x0c, storedByte 0xcb
c 'g' 0x67, b 0x00, storedByte 0x0c
c 'h' 0x68, b 0x01, storedByte 0x10
c 'j' 0x6a, b 0x03, storedByte 0x31
unsigned int storedByte;
byte b;
char s [80];
void loop () {
if (Serial.available ()) {
char c = Serial.read ();
if ('a' <= c)
b = 10 + c - 'a';
else if ('0' <= c)
b = c - '0';
if (b > 0x0F)
b &= 0x0F;
storedByte >>= 4;
storedByte |= b << 4;
sprintf (s, " c '%c' 0x%02x, b 0x%02x, storedByte 0x%02x",
c, c, b, storedByte);
Serial.println (s);
void setup () {
Serial.begin (9600);
That is only true if 'storedByte' is either <=15 or ==16. If 'storredByte' is 33 (0x21) then the first one would set 'storedByte' to 15 (0x0F) and the second would set 'storedByte' to 1 (0x01). Not the same.
Oof, a non-standard Arduino-only definition of round. The standard C++ round function returns the same type that was passed in (e.g., float -> float or double -> double, though float and double are treated the same on the 8-bit Arduini).
