So now i want to add 3 push buttons to control menus and stuff. I am not very good with buttons could somebody give me a link if there is one to how to add buttons.
Is this all I have to do?
I also came across this tutorial but i can't determine which chip he is using?
I built a board for my arduino that I can plug an LCD into and it has buttons as well. See it here: LCD shield with LCD mounted | Here is the LCD shield with th… | Flickr
I use the analog pins in digital mode, turned on the internal pullups and then used the buttons to ground the inputs when the buttons are pushed. It took some time, but it has been a very useful development tool.
The button would be wired the same regardless of the example. You are going to use digital inputs to determine what to do with the menu. So your going to ask:
If there is a signal on this pin, then move the menu up one.
So the diagram in http://arduino.cc/en/Tutorial/Button would work, you would just leave out the led and the code for the led. I have no idea how the coding for the menu works, but sticking with the button project the basic program would look something like:
int upButton=0;
pinMode(2,INPUT);
upButton=-digitalRead(2)+1; //Ok, so when I was taught programming 0 meant off and
//1 meant on, so I have to reverse this or I go nuts!
//all this does is switch around 0 and 1...
//so just to show the math: -0+1=1 and -1+1=0
if(upButton==1)//so now if the button is pressed, do stuff...
//Menu Move Up Code
So any of the button examples/tutorials on the thread can be used.
The entire code is not listed here, so I put some snippets in for you.
I did something like this:
int backBtn = 14; //These are the input buttons
int incBtn = 15;
int decBtn = 17;
int nextBtn = 18;
int escapeBtn = 16;
pinMode(backBtn,INPUT); //set pin as input
digitalWrite(backBtn, HIGH); //turn on the internal pull-up
pinMode(incBtn,INPUT);
digitalWrite(incBtn, HIGH); //turn on the internal pull-up
ETC.
then when I read buttons:
void readBtns()
back = digitalRead(backBtn); //Read the value of backBtn
next = digitalRead(nextBtn); //Read the value of nextBtn
escape = digitalRead(escape_Button); //Read the value of escape_Button
inc = digitalRead(incBtn); //Read the value of incBtn
dec = digitalRead(decBtn); //Read the value of decBtn
delay(debounce); //Wait a short time
The buttons are tied to ground on one side and to the input pin on the other side. In the setup, I defined the pin as an input and then set the pull up with digitalWrite to HIGH.
#include <LCD4Bit_mod.h>
//create object to control an LCD.
//number of lines in display=1
LCD4Bit_mod lcd = LCD4Bit_mod(2);
//Key message
char msgs[5][15] = {"Right Key OK ",
"Up Key OK ",
"Down Key OK ",
"Left Key OK ",
"Select Key OK" };
int adc_key_val[5] ={30, 150, 360, 535, 760 };
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
pinMode(13, OUTPUT); //we'll use the debug LED to output a heartbeat
lcd.init();
//optionally, now set up our application-specific display settings, overriding whatever the lcd did in lcd.init() //lcd.commandWrite(0x0F);//cursor on, display on, blink on. (nasty!)
lcd.clear();
lcd.printIn("KEYPAD testing... pressing");
adc_key_in = analogRead(0); // read the value from the sensor
digitalWrite(13, HIGH);
key = get_key(adc_key_in); // convert into key press
if (key != oldkey) // if keypress is detected
delay(50); // wait for debounce time
if (key != oldkey)
oldkey = key;
if (key >=0){
lcd.cursorTo(2, 0); //line=2, x=0
lcd.printIn(msgs[key]);
//delay(1000);
digitalWrite(13, LOW);
// Convert ADC value to key number
int get_key(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)
k = -1; // No valid key pressed
