adding condition in one dowhile loop in a if else if statment
Hi there,
This is my first Arduino project. I am basically stuck in a DO WHILE LOOP within an IF ELSE IF statement. following is the coding for the Arduino IDE. This coding is used by visual studio 2015 in VB. it contains a toggle on/off button. upon pressing On the LED starts blinking but when I press off button then no response. I had find out that it is in a loop and there is no condition to break the loop further I think that in order to the system to read the ELSE IF statement, it should read the serial port first. BUT I don't know how to do this . I had been trying for so long but failed. Can anyone here help me with this Please!
pinMode(52, OUTPUT);
Serial.begin (9600);
int val;
if (Serial.available()){
delay (100);
while (Serial. available()>0 )
val=Serial.read ();
if (val == '1'){
do{
digitalWrite(52,HIGH);
digitalWrite(52,LOW);
delay(500);}
while(val=='1');
else if (val == '0') {digitalWrite(52,LOW);};
do{
                       delay(500);}
                       while(val=='1');
Once in that loop, there's no way out.
    delay (100);
If there's something to read, waste enough time for the input buffer to overflow.
Not sensible.
Please use code tags when posting code.
I think you meant to say:
  static boolean blink = false;
  if (Serial.available()) {
    int val = Serial.read ();
    if (val == '1')
       blink = true;  // Turn blinker on
    if (val == '0')
       blink = false;  // Turn blinker off
  if  (blink) {
    digitalWrite(52, HIGH);
    digitalWrite(52, LOW);
thanks JOHNWASSER. your code really works. thanks again . a big relief for me.
Regards
