Adding distace sensor to robot
I need to add a forward and reverse distance sensor (Sharp GP2D13) to a robot. I need to move in reverse when and object is detected in the forward stop zone. The robot uses a Servo 8 board to send pulses to the PWM board. Is it possible to take the output signals from the Servo 8 board and the inputs from the sensors into a Arduini Diecimila USB IO board to create object avoidance?
Of course this is possible. A lot of examples exist for this.
For example have a look at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236642410/3#3 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1181749104
or http://letsmakerobots.com/node/2164
search the forum for terms like obstacle avoidance or sharp sensor...
and have a look at "Distance Sensing" here: http://www.arduino.cc/playground/Main/InterfacingWithHardware
Is there a better option, I have not purchased the sensors or the board.
My idea resulted from reading the user post of the circular robot with a base made of Lexan. I will read the other link you provided.
I have a MMP8 mobile robot platform, Lantronix WBX2100( wireless connection) , Super Logics CP8200(analog to digital), Servo 8 board, Dlink DCS-6620G camera and some regulator circuits assembled. I made a docking/charging station, robot will be in an area that has limited access( underground tunnel).
Thanks
