Adding double click to my program
Hey everyone, I'm still new to Arduino coding. So far I've been able to put this together, it's a code to control a LED strip. there's a button for colour (BTN), brightness (BTN2) and patterns (BTN3). Wanted to add a double press to go to the previous colour (BTN) and pattern (BTN3). Just wondering if anyone has any suggestions or a good tutorial to look at. Thanks
#include <FastLED.h>
#include <OneButton.h>
#define LED_PIN 2
#define BTN_PIN 3
#define BTN2_PIN 4
#define BTN3_PIN 5
#define NUM_LEDS 72
CRGB leds[NUM_LEDS];
uint8_t patternCounter = 0;
uint8_t patternCounter2 = 0;
uint8_t patternCounter3 = 0;
OneButton btn = OneButton(BTN_PIN, true, true);
OneButton btn2 = OneButton(BTN2_PIN, true, true);
OneButton btn3 = OneButton(BTN3_PIN, true, true);
int a = 4;
int b = 30;
int c = 40;
int d = 40;
int e = 40;
int f = c;
int x = 0;
int y = 0;
int z = 100;
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
  btn.attachClick(nextPattern);
  btn2.attachClick(nextPattern2);
  btn3.attachClick(nextPattern3);
 switch (patternCounter) {
 switch (patternCounter2) {
 switch (patternCounter3) {
fadeToBlackBy(leds, NUM_LEDS, a);
  FastLED.show();
  btn.tick();
  btn2.tick();
  btn3.tick();
void nextPattern() {
  patternCounter = (patternCounter + 1) % 21;
void nextPattern2() {
  patternCounter2 = (patternCounter2 + 1) % 3;
void nextPattern3() {
  patternCounter3 = (patternCounter3 + 1) % 16;
//colour
//Brightness
//Pattern
  • Example:
myButton.attachDoubleClick(myButtonDoubleClick);
void myButtonDoubleClick()
   //do something
There must be dozens of button libraries that can do dbl click, or you could try writing your own.
Yes - the library he is already using supports double click detection. As @LarryD indicated it’s just about registering the callback for it and providing that callback.
OOPS, didn't notice that.
Also depending on the platform OP might want to read about the deferred initialization
