Adding extra pins to Mega2560 Definintion
Hi all.
I have built a board, wired PE6, PE7 out to headers. I want to try and edit my pins_arduino.c file to add Arduino pin numbers to these pins.
I want to use them with attachInterrupt and digitalRead functions as if they were pins 70-71.
I've had a read of pins_arduino.c and its just a bit to forign to me to start changing stuff. Can anyone provide a clue as to How I do it? Just add an extra two lines of :
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
 // PIN IN PORT
    _BV( 0 )    , // PE 0 ** 0 ** USART0_RX
    _BV( 1 )    , // PE 1 ** 1 ** USART0_TX
    _BV( 4 )    , // PE 4 ** 2 ** PWM2
and
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
    // PORTLIST
    PE  , // PE 0 ** 0 ** USART0_RX
    PE  , // PE 1 ** 1 ** USART0_TX
    PE  , // PE 4 ** 2 ** PWM2
    PE  , // PE 5 ** 3 ** PWM3
But what about this stuff? :
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
    // TIMERS
    NOT_ON_TIMER    , // PE 0 ** 0 ** USART0_RX
    NOT_ON_TIMER    , // PE 1 ** 1 ** USART0_TX
    TIMER3B , // PE 4 ** 2 ** PWM2
    TIMER3C , // PE 5 ** 3 ** PWM3
    TIMER0B , // PG 5 ** 4 ** PWM4
etc etc...
Hope thats clear enough on what I'm trying to achieve..
Cheers
Matt
You're looking at the right places.
Stick the PEs where you want them to show - at the end if you want them as the next Digital pins.
_BV( 4 ) change these to the port pins you want
NOT_ON_TIMER , add these in next section if they not Timer pins, otherwise add TIMER0B , corresponding to the timer they are.
Make sure to get them in the same place in all three sections.
