I'm trying to update the keypad library so that it can use the Arduino pins or an I2C port expander but I can't get past a problem with the Arduino IDE. It won't pass a #define from the sketch into the library.
What I'm trying to do is let the user #define USE_I2C_PINS so the keypad will use the port expander. Otherwise it just uses the arduino pins. The other thing is that I would like to be able to add new hardware without making any changes to the keypad library itself, just to hal.h.
In the following code I have cut it to the bare minimum to demonstrate what I am trying to accomplish. Let me know if I should post the entire source code for the keypad library.
minimal.ino sketch
#include <Reduced.h>
#include <Wire.h>#define USE_I2C_PINS // This is where I would like to select the hardware but it makes no difference what I do.
Reduced red;
red.setHoldTime(42); // Prints one thing when using arduinoPins and something else for I2CxPins.
}void loop() {}
Inside hal.h is where I do the heavy lifting. It should select the correct header file and then create a pins object that can be used later by Reduced.cpp.
// hal.h
#include "Arduino.h" // for digitalRead, digitalWrite, etc#define USE_I2C_PINS // This works but it's not ideal. It should be passed in from the sketch but it doesn't work that way.
#if defined USE_I2C_PINS
#include "I2CxPins.h"
I2CxPins pins;
#else
#include "arduinoPins.h"
arduinoPins pins;
#endif
This is Reduced.cpp where I #include "hal.h" which should select either arduinoPins.h or I2CxPins.h. I call pins.pin_mode which will Serial.print() something different depending on which header file was loaded.
#include "utility/hal.h" // Provides the "pins" object.
void Reduced::setHoldTime(unsigned int hold) {
holdTime = hold;
pins.pin_mode(); // Prints one thing when using arduinoPins and something else for I2CxPins.
So how can I get this to work if the Arduino IDE won't pass through the #define's from the sketch?
Reduced.zip (77.8 KB)
