ted
March 13, 2018, 4:52pm
1
adding #3 is disabling - "process key " functionality.
How to fix it ?
button code
process_key(digitalRead(phasep), &right);
process_key(digitalRead(phasen), &left);
process_key_amp(digitalRead(ampp), &up);
process_key_amp(digitalRead(ampn), &down);
delay(100);
#3
emon1.calcVI(20, 2000); // Calculate all. No.of half wavelengths (crossings), time-out
emon1.serialprint(); // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
float realPower = emon1.realPower; //extract Real Power into variable
float apparentPower = emon1.apparentPower; //extract Apparent Power into variable
float powerFActor = emon1.powerFactor; //extract Power Factor into Variable
float supplyVoltage = emon1.Vrms; //extract Vrms into Variable
float Irms = emon1.Irms; //extract Irms into Variable
lcd.setCursor(0, 0);
lcd.print("I="); //A, PA7
lcd.print(Irms ); //A
lcd.setCursor(0, 1);
lcd.print("U="); //B, PA6
lcd.print(supplyVoltage); //B
/*Serial.println(shift);
EEPROM.write(0, shift);*/
void process_key(int val, struct debounce_info *k)
switch (k->state)
case DEBOUNCE_IDLE:
if (val == HIGH)
k->state = DEBOUNCE_ACTIVE;
k->start = millis();
case DEBOUNCE_ACTIVE:
if (val == HIGH)
if (millis() - k->start > DEBOUNCE_DELAY)
shift += k->shift;
Serial.println("increasing");
Serial.println(k->shift);
get_wave(shift);
k->state = DEBOUNCE_IDLE;
void process_key_amp(int val, struct debounce_info *k)
switch (k->state)
case DEBOUNCE_IDLE:
if (val == HIGH)
if (val == HIGH)
amp += (int)k->shift;
get_wave(shift);
to be added - LCD code
Maybe rephrase the question; it's not completely clear to me.
Maybe the keyword you're looking for is conditional compilation?
ted
March 13, 2018, 5:12pm
3
The buttons are working ok without what is added between two backslash lines.
ted:
There are no backslashes anywhere on this page.
ted
March 13, 2018, 5:35pm
6
this is what I did
code A
//buttons code
code B
// LCD code
combined
A+B
buttons code
LCD code
ted
March 13, 2018, 5:39pm
7
GrooveFlotilla:
The firs code on the top of page, just under #3
ted:
Those are forward slashes.
ted
March 13, 2018, 5:56pm
9
I add "void" and error is;
:198: error: expected unqualified-id before '{' token
delay(100);
//#3
void
{ // line # 198
switch (k->state)
case DEBOUNCE_IDLE:
if (val == HIGH)
if (val == HIGH)
shift += k->shift;
get_wave(shift);
switch (k->state)
case DEBOUNCE_IDLE:
if (val == HIGH)
if (val == HIGH)
get_wave(shift);
ted
March 13, 2018, 5:59pm
10
GrooveFlotilla:
GrooveFlotilla:
you right, but problem is not there
Dear God!
When are you going to stop hitting random keys in the increasingly vain hope of getting a working compilable program?
Just work through some basic examples before you get further out of your depth.
ted
March 13, 2018, 6:02pm
12
I am google for that right now
Google does not have all your answers.
You need to work through the basics - what functions look like, what slashes look like, how code should be structured etc, etc
Can anyone really be that dim or is ted just trolling, getting some odd pleasure from all this silliness?
After never getting a straight answer to a single one of my questions I rather lost interest in his "problems".
Steve
ted
March 13, 2018, 11:12pm
18
Ted is learning void loop, ask a specific question and received blah, blah, blah annoying useless answer from guys who do not know the answer.
2+3 = monday
ted
March 14, 2018, 12:44am
20
How to fix it ?
This is my question and your answer is ?
Do you see what I mean.
ted
March 14, 2018, 12:59am
22
Look at my answer no blah, blah, blah.
I didn't say to guy - you need to learn basics ..............
https://forum.arduino.cc/index.php?topic=534868.0
ted
March 14, 2018, 1:05am
25
Delta_G:
Sorry but,
#3
is not a legal line of code. = I didn't ask for that
If you mean to refer to the code that comes after that line in your code it doesn't work because it is not inside any function. It should be throwing compiler errors. = I didn't ask for that
I asked " how to fix it "
ted
March 14, 2018, 1:16am
27
Delta_G:
Are you really too stupid to get that?
Don't do that !!!
I am not here to fight.
