Adding IR Remote Control to a Sketch
Greetings everyone
I have an Arduino sketch "WS2812B_Analogue_Digital_Clock_2Strip" made for Led strips and, I would like to add an IR Remote Control as in the attached drawing https://europe1.discourse-cdn.com/arduino/original/3X/e/c/ecbf0033bd2945c03f90ba59102fcacfcf9c7673.jpg, simply to turn the Led strip ON and OFF but, I don't have enough knowledge to do it, so I would like the help of noble friends. here's the sketch:
WS2812B_Analogue_Digital_Clock_2Strip.ino (8.3 KB)
My thanks in advance
PS.: If it is necessary to place the sketch between Tags I will place it!
Yes, please post code here as well as drawing, no Fritzing.
Helpers don't like spending time digging for documentation, watching videos etc.
If You want helpers to get interested, make their work as easy as ever can be.
Hello
and good morning
For your approach you have check the usage of the Arduino timers for the selected libries first. Under bad circumstances their might be some conflicts.
I am unable to see the code. Post it here.
If the code uses the FastLED library, the show() function disables all interrupts. That can mess with IR code reception. Not sure how to get around that.
Open source here:
  Wol Clock ESP8266-12E + 60 LED WS2812B Analogue Digital Clock by Jon Fuge
  https://www.instructables.com/Wol-Clock-ESP8266-12E-60-LED-WS2812B-Analogue-Digi/
  referência de cores rgb: https://rgb.to/255,128,0
  forum.arduino: https://forum.arduino.cc/t/ajuda-com-projeto-de-relogio-com-tira-de-led-ws2812-e-esp8266/859445
// *************** Declare included libraries *****************
#include <NTPClient.h>
#include <Time.h>
#include <TimeLib.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
// ************* Declara estruturas *****************
//Cria uma estrutura para informações de LED RGB
struct RGB {
  byte r, g, b;
//Cria uma estrutura para informações de tempo
struct TIME {
  byte Hour, Minute;
// ************* Opções editáveis ***************************
//A cor do ponteiro "12H" para dar referência visual ao topo
const RGB Twelve = { 128, 0, 128 };  //roxo forte
//A cor dos ponteiros 3H, 6H e 9H para dar referência visual
const RGB Quarters = { 64, 0, 40 };  //roxo fraco
//A cor das "divisões" 1min,2min,4min,5min,7min,8min,10min e 11min para dar referência visual
const RGB Divisions = { 32, 0, 20 }; //azul fraco
//Todos os outros pixels sem informação
const RGB Background = { 1, 3, 10 };  //azul fraco
//O ponteiro das horas
const RGB Hour = { 255, 0, 0 };  //vermelho
//O ponteiro dos minutos
const RGB Minute = { 0, 128, 0 };  //verde
//O ponteiro dos segundos
const RGB Second = { 0, 0, 255 };  //azul intenso
// Faz o relógio avançar ou retroceder (dependendo do tipo de tira de Led)
const char ClockGoBackwards = 0;
//Define o brilho por tempo para o modo noturno e diurno
const TIME WeekNight = {21, 30}; //escurecimento na semana à noite
const TIME WeekMorning = {6, 15}; //clarear pela manhã na semana
const TIME WeekendNight = {21, 30}; //escurecimento à noite nos fins de semana
const TIME WeekendMorning = {9, 30}; //clarear pela manhã nos fins de semana
const int day_brightness = 255;
const int night_brightness = 16;
//Define o seu fuso horário em horas de diferença do GMT
const int hours_Offset_From_GMT = -4;
//Define os detalhes do seu Wi-Fi para que a placa possa se conectar e obter o tempo da internet
const char *ssid      = "Dancopy";      // seu SSID de rede (nome)
const char *password  = "dsjjg015085";  // sua senha de rede
byte SetClock;
// Por padrão 'time.nist.gov' é usado.
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Pino do ESP8266 que está conectado aos NeoPixels
// #define PIN   14  // Este é o pino D5
// #define PIN2  12  // Este é o pino D6
// ************* Declara funções do usuário ******************************
void Draw_Clock(time_t t, byte Phase);
int ClockCorrect(int Pixel);
void SetBrightness(time_t t);
void SetClockFromNTP ();
bool IsDst();
// ************************** Declara NeoPixel ***************************
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(60, 14, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel pixels2 = Adafruit_NeoPixel(60, 12, NEO_GRB + NEO_KHZ800);
//************* Função Setup para Wol_Clock ******************************
  pixels.begin(); // Inicializa a 1ª tira NeoPixel
  pixels2.begin(); // Inicializa a 2ª tira NeoPixel
  pixels.show();   // Atualiza todos os pixels da 1ª tira de Led
  pixels2.show();  // Atualiza todos os pixels da 2ª tira de Led
  Draw_Clock(0, 1); // Desenha simplesmente um relógio em branco
  WiFi.begin(ssid, password); // Tenta conectar-se ao Wi-Fi
  Draw_Clock(0, 2); // Desenha o fundo do relógio
  while (WiFi.status() != WL_CONNECTED)
    delay (500); // continua esperando até que possamos conectar com sucesso ao WiFi
  Draw_Clock(0, 3); // Adiciona os indicadores de um quarto de hora
  SetClockFromNTP(); // obtém a hora do servidor NTP com correção de fuso horário
  timeClient.update(); // obtém a hora do servidor NTP
  setTime(timeClient.getEpochTime()); // Define a hora do sistema a partir do relógio
  if (IsDst())
    adjustTime((hours_Offset_From_GMT + 1) * 3600); // desloca a hora do sistema com o fuso horário definido pelo usuário (3600 segundos em uma hora)
    adjustTime(hours_Offset_From_GMT * 3600); // desloca a hora do sistema com o fuso horário definido pelo usuário (3600 segundos em uma hora)
bool IsDst()
  if (month() < 3 || month() > 10)  return false;
  if (month() > 3 && month() < 10)  return true;
  int previousSunday = day() - weekday();
  if (month() == 3) return previousSunday >= 24;
  if (month() == 10) return previousSunday < 24;
  return false; // esta linha nunca vai acontecer
// ************* Loop do programa principal para Wol_Clock ******************************
  time_t t = now(); // Obtém a hora atual
  Draw_Clock(t, 4); // Desenha todo o mostrador do relógio com horas, minutos e segundos
  if (minute(t) == 0) // no início de cada hora, atualiza a hora no servidor de tempo
    if (SetClock == 1)
      SetClock = 0;
    delay(200); // Espera somente 0,1 segundos
    SetClock = 1;
// ************* Funções para desenhar o relógio ******************************
  if (Phase <= 0)
    for (int i = 0; i < 60; i++)
      pixels.setPixelColor(i, pixels.Color(0, 0, 0)); // para Phase = 0 ou menos, todos os pixels são pretos
  if (Phase >= 1)
      pixels2.setPixelColor(i, pixels.Color(Background.r, Background.g, Background.b)); // para Phase = 1 ou mais, desenhe os minutos com a cor de fundo
  if (Phase >= 2)
    for (int i = 0; i < 60; i = i + 5)
      pixels2.setPixelColor(i, pixels.Color(Divisions.r, Divisions.g, Divisions.b)); // para Phase = 2 ou mais, desenhe divisões de 5 minutos
  if (Phase >= 3) {
    for (int i = 0; i < 60; i = i + 15)
      pixels.setPixelColor(ClockCorrect(i), pixels.Color(Quarters.r, Quarters.g, Quarters.b)); // para Phase = 3 ou mais, desenhe divisões de 15 minutos
    pixels.setPixelColor(ClockCorrect(0), pixels.Color(Twelve.r, Twelve.g, Twelve.b)); // para Phase = 3 e acima, desenhe o indicador de 12 horas
  if (Phase >= 4) {
    pixels2.setPixelColor(ClockCorrect(second(t)), pixels2.Color(Second.r, Second.g, Second.b)); // desenhe o ponteiro dos segundos primeiro
    if (second() % 2)
      pixels2.setPixelColor(ClockCorrect(minute(t)), pixels2.Color(Minute.r, Minute.g, Minute.b)); // para ajudar na identificação, o ponteiro dos minutos pisca entre a intensidade normal e meia intensidade
      pixels2.setPixelColor(ClockCorrect(minute(t)), pixels2.Color(Minute.r, Minute.g, Minute.b)); // ponteiro dos minutos de menor intensidade
    pixels.setPixelColor(ClockCorrect(((hour(t) % 12) * 5)), pixels.Color(Hour.r, Hour.g, Hour.b)); // desenhe o ponteiro das horas por último
    pixels.show();
    pixels2.show();
    pixels.clear();
    pixels2.clear();
  SetBrightness(t); // Define o brilho do relógio de acordo com a hora
// ************* Função para definir o brilho do relógio ******************************
  int NowHour = hour(t);
  int NowMinute = minute(t);
  if ((weekday() >= 2) && (weekday() <= 6))
    if ((NowHour > WeekNight.Hour) || ((NowHour == WeekNight.Hour) && (NowMinute >= WeekNight.Minute)) || ((NowHour == WeekMorning.Hour) && (NowMinute <= WeekMorning.Minute)) || (NowHour < WeekMorning.Hour))
      pixels.setBrightness(night_brightness);
      pixels.setBrightness(day_brightness);
  else if ((NowHour > WeekendNight.Hour) || ((NowHour == WeekendNight.Hour) && (NowMinute >= WeekendNight.Minute)) || ((NowHour == WeekendMorning.Hour) && (NowMinute <= WeekendMorning.Minute)) || (NowHour < WeekendMorning.Hour))
//************* Testa a função de inversão da ordem dos pixels ***************
  if (ClockGoBackwards == 1)
    return ((60 - Pixel + 30) % 60);
    return (Pixel);
If this change is to compromise the program because it actually uses the show () function, I will keep the original code (without IR control).
