I need to be able to run different patterns simultaneously on 5 separate strips of ws2813's from a nodemcu. I can effectively use a function pointer that runs a pattern based on user input, but I would like to load an array of sorts with each selected function so that each strip is either assigned a function or is not assigned. Then I could iterate through the indexs of the array, running the functions assigned. Could anyone help me with this logic please?
#define NUM_LEDS 21
#define NUM_STRIPS 5
#define WS1_PIN 16 // TOP (D0)
#define WS2_PIN 4 // MIDDLE (D1)
#define WS3_PIN 5 // DECK (D2)
#define WS4_PIN 0 // (D3)
#define WS5_PIN 2 // (D4)
Adafruit_NeoPixel ws1 = Adafruit_NeoPixel(NUM_LEDS, WS1_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel ws2 = Adafruit_NeoPixel(NUM_LEDS, WS2_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel ws3 = Adafruit_NeoPixel(NUM_LEDS, WS3_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel ws4 = Adafruit_NeoPixel(NUM_LEDS, WS4_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel ws5 = Adafruit_NeoPixel(NUM_LEDS, WS5_PIN, NEO_GRB + NEO_KHZ800);
////Variables for iteration decoupling///////////////
boolean firstCycle = true;
boolean is_rising = true;
byte last_data = 0;
byte data = 0;
int iter = 0;
const byte numChars = 9;
char receivedChars[numChars];
char tempChars[numChars];
char stripToCommand[numChars] = {0};
//char colorCommanded[numChars] = {0};
int patternCommanded = {0};
boolean newData = false;
digitalWrite(WS1_PIN, HIGH);
pinMode(WS1_PIN, OUTPUT);
// Check for Serial connection
while(!Serial);
ws1.begin();
ws2.begin();
ws3.begin();
ws4.begin();
ws5.begin();
ws1.setBrightness(80);
ws2.setBrightness(80);
ws3.setBrightness(80);
ws4.setBrightness(80);
ws5.setBrightness(80);
ws1.show();
ws2.show();
ws3.show();
ws4.show();
ws5.show();
//Serial.flush();
void (*fun_ptr_arr[])(byte, byte, byte) = {FadeInOut, Strobe};
void (*fun_ass[NUM_STRIPS])(byte) = {0,0,0,0,0};
Serial.flush();
delay(10);
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
newData = false;
cueTheLights();
void recvWithStartEndMarkers(){
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while(Serial.available() > 0 && newData == false){
rc = Serial.read();
if(recvInProgress == true){
if(rc != endMarker){
receivedChars[ndx] = rc;
ndx++;
if(ndx >= numChars){
ndx = numChars - 1;
else{
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if(rc == startMarker){
recvInProgress = true;
void parseData(){ // split data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,",");
strcpy(stripToCommand, strtokIndx); // copy it to stripToCommand
Serial.println(stripToCommand);
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
patternCommanded = atoi(strtokIndx);// convert this part to a integer
Serial.println(patternCommanded);
//assign_to_strip();
void iterate(){
if(is_rising && iter < 256){
iter = iter + 4;
if(iter == 256){
is_rising = false;
else if(!is_rising && iter >= 0){
if(iter == 0){
is_rising = true;
else{
iter = iter - 4;
is_rising = false;
void cueTheLights()
if(patternCommanded == 1){ iterate(); (*fun_ptr_arr[0])(0xff, 0x00, 0x00);/* Serial.println(".");*/}
else if(patternCommanded == 2){ iterate(); (*fun_ptr_arr[0])(0xff, 0xff, 0xff); /*Serial.println("@");*/}
else if(patternCommanded == 3){ iterate(); (*fun_ptr_arr[0])(0x00, 0x00, 0xff); /*Serial.println("#");*/}
else if(patternCommanded == 4){ (*fun_ptr_arr[1])(0xff, 0xff, 0xff); iter = 0;/*Serial.println("$");*/}
else if(patternCommanded == 5){ (*fun_ptr_arr[1])(0xff, 0xff, 0x00); iter = 0; /*Serial.println("%");*/}
delay(2);
void FadeInOut(byte red, byte green, byte blue){
float r, g, b;
//Serial.flush();
r = (iter/256.0)*red;
g = (iter/256.0)*green;
b = (iter/256.0)*blue;
setAll(r,g,b);
showStrip();
delay(1);
void Strobe(byte red, byte green, byte blue){
Serial.flush();
setAll(red,green,blue);
showStrip();
delay(50);
setAll(0,0,0);
showStrip();
delay(50);
