Adding millis to LCD instead of delay, help?
Hello guys,
I'm trying to use millis instead of delay to shift the pages of a 2x16 LCD with a pause of 7 seconds. I want to make it show the first 2 rows for 7 seconds, and then the second 2 rows for 7 seconds. But looks like my code is no bueno, it just stays on the second page.
Does anyone know how can I do it?
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DS18B20 26
#define LCD_milis_1 7000
#define LCD_milis_2 7000
unsigned long lastExecutedMillis_1 = 0;
unsigned long lastExecutedMillis_2 = 0;
OneWire oneWire(DS18B20);
DallasTemperature Sensor(&oneWire);
float temperature;
hd44780_I2Cexp lcd;
  lcd.begin(16, 2);
  Sensor.requestTemperatures();
  temperature = Sensor.getTempCByIndex(0);
  Serial.println(temperature);
  if (currentMillis - lastExecutedMillis_1 >= LCD_milis_1) {
    lastExecutedMillis_1 = currentMillis;
    lcd.backlight();
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("FirstLine  ");
    lcd.print("14");
    lcd.setCursor(0, 1);
    lcd.print("SecondLine ");
    lcd.print("85");
    lcd.print("%  ");
    if (currentMillis - lastExecutedMillis_2 >= LCD_milis_2) {
      lastExecutedMillis_2 = currentMillis;
      lcd.clear();
      lcd.print("Page2Up: ");
      lcd.print("21");
      lcd.print((char)223);
      lcd.print("Page2Down: ");
      lcd.print(temperature, 1);
There is one task to do, so I would use just one millis-timer with one previousMillis variable.
You could count each time the millis-timer gets activated, and do different things for each number of the counter, perhaps also turning off the millis-timer.
You could combine a Finite State Machine with millis. To me that seems over-the-top for your project.
Is it 7 seconds one page and 7 seconds the other page continuous in a loop forever ?
Then you only need a millis-timer of 7 seconds and a counter that is 0 and 1.
Let's not call them first rows and second two rows, but let's stick to "pages".
int page = 0;      // start with page 0
unsigned long previousMillis;
const unsigned long interval = 7000UL;
if (currentMillis - previousMillis >= interval)
  if( page == 0)
    // show page 0
  else if( page == 1)
    // show page 1
  page++;          // next page
  if( page > 1)
    page = 0;      // back to page 0
To avoid your display flickering from constant lcd.clear() and redraw, only do that when the timer expires
#include <Wire.h>
#define DS18B20 26
const unsigned long LCD_milis = 7000;
unsigned long lastExecutedMillis;
bool isFirstPage = true;
hd44780_I2Cexp lcd;
  lcd.begin(16, 2);
  float temperature = Sensor.getTempCByIndex(0);
  if (currentMillis - lastExecutedMillis >= LCD_milis) {
    lastExecutedMillis = currentMillis;
    isFirstPage = !isFirstPage; // toggle page to display
    lcd.clear();
  if ( isFirstPage ) {
    lcd.backlight();
    lcd.print("14");
    lcd.print("85");
    lcd.print("%  ");
  else {
    lcd.print("21");
You can extend that idea to draw all the static text when the page changes and then just update the temperature portion each time through loop()
Thank you blh64, works like a charm!
