Will start by admitting I know only enough on the coding side to do very basic troubleshooting on other people code or to change variables etc. I have in the past been able to combine a couple different pieces of code into something that works. However On this I am completely stuck.
I have a 16 channel relay board (actually 2 boards that will get their signals in parallel from the arduino)
I found the code below from a youtube video. I really like that it turns them on/off one at a time and the speed is adjustable, makes for nice aesthetics/sound.
What I would like to do is have a momentary switch on one of the arduino inputs so that when pressed it would turn them all on or off in series like in this code then stop.
My use for this is to put into my arcade/mame machine so that I can switch all the joystick/button controls from the keyboard emulator that goes to my PC/hyperspin setup over to the control interface boards for xbox1/ps4. I have tried just running both in parallel but have had some fairly serious ghosting issues on the inputs going to the pc.
So with this I would run all the control wires to the center common on the relays then wire the pc side to the NC side of the relay and the console to the NO side. Then have 1 button to switch the relays.
Would also be more than happy to tip someone for their assistance with this.
Also feel free to remove whatever lines are needed for the serial monitor as they would not be used in my project.
* Arduino code to control 16 channel relay with Arduino UNO
* Written by Ahmad Shamshiri for Robojax.com on Sunday Oct 08, 2018
* at 10:35 in Ajax, Ontario, Canada
* Watch video instruction for this code: https://youtu.be/Q9aBI4ELKC4
* This code is "AS IS" without warranty or liability. Free to be used as long as you keep this note intact.*
* This code has been download from Robojax.com
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <https://www.gnu.org/licenses/>.
const int controlPin[16] = {2,3,4,5,6,7,8,9,10,11,12,A0,A1,A2,A3,A4}; // define pins
const int triggerType = LOW;// your relay type
int loopDelay = 1000;// delay in loop
int tmpStat =1;
for(int i=0; i<16; i++)
pinMode(controlPin[i], OUTPUT);// set pin as output
if(triggerType ==LOW){
digitalWrite(controlPin[i], HIGH); // set initial state OFF for low trigger relay
}else{
digitalWrite(controlPin[i], LOW); // set initial state OFF for high trigger relay
Serial.begin(9600);// initialize serial monitor with 9600 baud
channelControl(i,tmpStat,200);// turn each relay ON for 200ms
if(tmpStat)
tmpStat=0;
}else{
tmpStat=1;
Serial.println("===============");
//channelControl(6,1, 2000); // turn relay 7 ON for 2 seconds
//channelControl(6,0, 5000); // turn relay 7 OFF for 5 seconds
//channelControl(9,1, 3000); // turn relay 10 OFF for ever
delay(loopDelay);// wait for loopDelay ms
* funciton: channelControl
* turns ON or OFF specific relay channel
* @param relayChannel is integer value channel from 0 to 15
* @param action is 1 for ON or 0 for OFF
* @param t is time in melisecond
void channelControl(int relayChannel, int action, int t)
int state =LOW;
String statTXT =" ON";
if(triggerType == LOW)
if (action ==0)// if OFF requested
state = HIGH;
statTXT = " OFF";
digitalWrite(controlPin[relayChannel], state);
if(t >0 )
delay(t);
Serial.print ("Channel: ");
Serial.print(relayChannel);
Serial.print(statTXT);
Serial.print(" - ");
Serial.println(t);
}else{
if (action ==1)// if ON requested
state = HIGH;
}else{
statTXT = " OFF";
if(t >0 )
delay(t);
Serial.println(t);
