Adding more digital ports
Hello,
for a school project I am making a robot using a Arduino UNO. For this project I need more ports then there are available on the Arduino, does anyone have any ideas of how I can create more I/O ports? I already came uppon shift registers, but with those I will not be able to store the date coming in right?
As example I am using a line detecting senor, which is using 5 ports, but if I use a shift register, I wont be able to store the values of the senor anymore right?
google "Arduino Digital I/O Expansion"
here is one hit with lots of ideas ➜ https://www.best-microcontroller-projects.com/digital-i-o.html
No, that doesn't make sense. If you can read the data, you have the data and can store it. You can use shift registers for either input or output. However:
Look at the MCP23017 port expander.
How to Connect an MCP23017 I/O Port Expander to an Arduino
