Adding more if statements
Hi.
I made a topic a few days ago with a code I made many years ago that stopped working suddenly, instead of fixing it, I tried to make a new one now based on another webserver example I found.
Basic premise:
Webserver hooked to a radio transmitter, when you press the links, it broadcasts a signal to a wireless powerplug.
What I am trying to do now:
Add more if statements to the code, but when I add "if statements" I get an error, so I think my formatting is wrong.
The base code (which works without errors:) (But only the first 2 links (1-on/1-off) work
#include "SPI.h"
#include "Ethernet.h"
#include <NewRemoteTransmitter.h>
const unsigned long TRANSMITTER_ADDRESS = 27612394; //My personal transmitter address
const int PIN_TRANSMITTER = 8;
NewRemoteTransmitter transmitter(TRANSMITTER_ADDRESS, PIN_TRANSMITTER, 260, 3);
uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // MAC Address
uint8_t ip[] = { 192,168,1,50 };                        // IP Address
EthernetServer server(80);                           // Server Port 80
// RemoteTransmitter configuration
// Connect Transmitter to Pin 11 and receiver to pin 2 (all digital)
// FAN 1 ON/OFF:
// Addr 27612394 unit 0 on, period: 267us.
// Addr 27612394 unit 0 off, period: 267us.
// FAN 2 ON/OFF:
// Addr 27612394 unit 1 on, period: 266us.
// Addr 27612394 unit 2 off, period: 267us.
// FAN 3 ON/OFF:
// Addr 27612394 unit 2 on, period: 267us.
// Addr 27612394 unit 1 off, period: 266us.
// ALL POWER OFF:
// Addr 27612394 group off, period: 267us.
String controlString; // Captures out URI querystring;;
int blueLEDPin = 2; // pin where our blue LED is connected
void setup(){
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  digitalWrite(3, HIGH);
  Ethernet.begin(mac, ip);
  server.begin();
  pinMode(PIN_TRANSMITTER, OUTPUT);
  Serial.print("Serial Write turned on");
void loop(){
    // Create a client connection
    if (client) {
        while (client.connected()) {
            if (client.available()) {
                char c = client.read();
                //read the HTTP request
                if (controlString.length() < 100) {
                    // write characters to string
                    controlString += c;
                //if HTTP request has ended– 0x0D is Carriage Return \n ASCII
                if (c == 0x0D) {
                    digitalWrite(4, HIGH);
                    httpResponseHome(client);
                    delay(10);
                    //stopping client
                    client.stop();
                    // control arduino pin
                    if(controlString.indexOf("?1-on") > -1) //checks for switch1on
                        transmitter.sendGroup(true);
                        httpResponseRedirect(client);
                    else{
                        if(controlString.indexOf("?1-off") > -1) //checks for switch1off
                        transmitter.sendGroup(false);
                    //clearing string for next read
                    controlString="";
void httpResponseHome(EthernetClient c) {
  c.println("HTTP/1.1 200 OK");
  c.println("Content-Type: text/html");
  c.println();
  c.println("<html>");
  c.println("<head>");
  c.println(    "<title>MPC NEXA Webserver</title>");
  c.println(    "<style>");
  c.println(        "body { font-family: Arial, sans-serif; font-size:12px; }");
  c.println(    "</style>");
  c.println("</head>");
  c.println("<body>");
  c.println(    "<h1>MPC NEXA Webserver</h1>");
  c.println(    "<ul>");
  c.println(        "<li><a href=\"./?1-on\">Turn on power</a></li>");
  c.println(        "<li><a href=\"./?1-off\">Turn off power</a></li>");
  c.println(    "</ul>");
  c.println(    "<ul>");
  c.println(        "<li><a href=\"./?2-on\">Turn on power 1</a></li>");
  c.println(        "<li><a href=\"./?2-off\">turn off power 1</a></li>");
  c.println(    "<ul>");
  c.println(        "<li><a href=\"./?3-on\">Turn on power 2</a></li>");
  c.println(        "<li><a href=\"./?3-off\">turn off power 2</a></li>");
  c.println(    "<ul>");
  c.println(        "<li><a href=\"./?4-on\">Turn on power 3</a></li>");
  c.println(        "<li><a href=\"./?4-off\">turn off power 3</a></li>");
  c.println(    "<hr>");
  c.println("</body>");
  c.println("</html>");
void httpResponseRedirect(EthernetClient c) {
  c.println("HTTP/1.1 301 Found");
  c.println("Location: /");
  c.println();
What I am trying to add, but I get errors when I try to add it under my last "else" statement, even if I add an else if behind it, but I am probably doing something wrong?
                    else{
                        if(controlString.indexOf("?2-on") > -1) //checks for switchon
                        transmitter.sendUnit(0, true);
                    else{
                        if(controlString.indexOf("?2-off") > -1) //checks for switchoff
                        transmitter.sendUnit(0, false);
                    else{
                        if(controlString.indexOf("?3-on") > -1) //checks for switchon
                        transmitter.sendUnit(1, true);
                    else{
                        if(controlString.indexOf("?3-off") > -1) //checks for switchoff
                        transmitter.sendUnit(1, false);
                    else{
                        if(controlString.indexOf("?4-on") > -1) //checks for switchon
                        transmitter.sendUnit(2, true);
                    else{
                        if(controlString.indexOf("?4-off") > -1) //checks for switchoff
                        transmitter.sendUnit(2, false);
Please use the "Copy error messages" button in the IDE and post the error text here in code tags
Hey.
Sure thing!
Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
G:\Dropbox\Dropbox\Arduino\RemoteControllFansNewWorks\RemoteControllFansNewWorks.ino: In function 'void loop()':
RemoteControllFansNewWorks:78:21: error: expected '}' before 'else'
                     else{
RemoteControllFansNewWorks:85:21: error: expected '}' before 'else'
                     else{
RemoteControllFansNewWorks:92:21: error: 'else' without a previous 'if'
                     else{
RemoteControllFansNewWorks:99:21: error: 'else' without a previous 'if'
                     else{
RemoteControllFansNewWorks:106:21: error: 'else' without a previous 'if'
                     else{
RemoteControllFansNewWorks:113:21: error: 'else' without a previous 'if'
                     else{
G:\Dropbox\Dropbox\Arduino\RemoteControllFansNewWorks\RemoteControllFansNewWorks.ino: At global scope:
RemoteControllFansNewWorks:126:5: error: expected declaration before '}' token
Multiple libraries were found for "NewRemoteTransmitter.h"
 Used: C:\Users\MPC\Documents\Arduino\libraries\NewRemoteSwitch
 Not used: C:\Program Files (x86)\Arduino\libraries\NewRemoteSwitch
exit status 1
option enabled in File -> Preferences.
I tried changing else to else if but that didnt seem to work.
Thanks for the errors. Please post the full code that produced them so that we know exactly what you have done to it
Sorry !
Should have done this in the first post. My bad:
#include "SPI.h"
// FAN 1 ON/OFF:
// FAN 2 ON/OFF:
// FAN 3 ON/OFF:
// ALL POWER OFF:
void setup(){
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  server.begin();
void loop(){
    if (client) {
                    controlString += c;
                if (c == 0x0D) {
                    delay(10);
                    //stopping client
                    client.stop();
                    if(controlString.indexOf("?1-on") > -1) //checks for switchon
                    else{
                        if(controlString.indexOf("?1-off") > -1) //checks for switchoff
                    else{
                    else{
                    else{
                    else{
                    else{
                    else{
                    controlString="";
  c.println();
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<hr>");
  c.println();
Your if/else syntax is invalid.
                    else{
                    else{
                    else{
You've got a bunch of elses, all seemingly dependent on one if.
remove the { from the else{
and remove the } that was the one you had it matched with.
At least.
Go look at the BNF chart or wherever you go to see why you've screwed up on the basic syntax.
# include <stdio.h>
int a, b, c;
int main()
    b = 2;
    printf("Hello World!\n");
	if (a == 1) //checks for switchon
	  printf("a is 1\n");
	else if (b == 2) //checks for switchoff
	  printf("b is 2\n");
	else if (c == 3) //checks for switchon
	  printf("c is 3\n");
	  printf("Goodbye World!\n");
    return 0;
a7
Thanks man. Yeah, I'm not really good with if that then this commands and need to read up on the syntax, but your solution worked perfectly. Thanks!
Working code:
#include "SPI.h"
// FAN 1 ON/OFF:
// FAN 2 ON/OFF:
// FAN 3 ON/OFF:
// ALL POWER OFF:
void setup(){
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  server.begin();
void loop(){
    Serial.print("Launching Ethernet WebServer");
    if (client) {
                    controlString += c;
                if (c == 0x0D) {
                    Serial.print("Website is up");
                    delay(10);
                    //stopping client
                    client.stop();
                    digitalWrite(4, LOW);
                    controlString="";
  c.println();
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<ul>");
  c.println(    "<hr>");
  c.println();
