Adding more servos
I've been trying to add more servos to this code and it doesn't work.
I have 6 servos and 6 maxbotix range finder:
Maxbotix- analog In Pin 0 to 5
Servos - Digital pin 2 to 7
And the analog pins (maxbotix) outputs the numbers to max jitter.
I got here so far- but when I get to void move and repeat everything- it goes back to moveTo- int redefinition.
Can someone please help me :wink:
#include <Servo.h>
Servo myservo0;
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
int pos = 0;
int pos2 = 0;
myservo0.attach(2); // analog 0
myservo1.attach(3); // analog 1
myservo2.attach(4); // analog 2
myservo3.attach(5); // analog 3
myservo4.attach(6); // analog 4
myservo5.attach(7); // analog 5
// servo 0 analog 0
if (analogRead(0)< 110){
Serial.print (analogRead(0));
myservo0.write(170);
myservo0.write(10);
// servo 1 analog 1
if (analogRead(1)< 110){
Serial.print (analogRead(1));
myservo1.write(170);
myservo1.write(10);
// servo 2 analog 2
if (analogRead(2)< 110){
Serial.print (analogRead(2));
myservo2.write(170);
myservo2.write(10);
// servo 3 analog 3
if (analogRead(3)< 110){
Serial.print (analogRead(3));
myservo3.write(170);
myservo3.write(10);
// servo 4 analog 4
if (analogRead(4)< 110){
Serial.print (analogRead(4));
myservo4.write(170);
myservo4.write(10);
// servo 5 analog 5
if (analogRead(5)< 110){
Serial.print (analogRead(5));
myservo5.write(170);
myservo5.write(10);
// move to the given position
// degreesPerStep of 4 moves 160 degrees in a little under a second
// degreesPerStep of 1 moves 160 degrees in around 3.2 seconds
void moveTo(int newPosition){
int degreesPerStep = 1; // decrease this to slow movement
int currentPos = myservo0.read();
int movement = newPosition - currentPos; // the number of degrees to move
if(movement < 0){
while(currentPos > newPosition){
currentPos = currentPos - degreesPerStep;
myservo0.write( currentPos);
delay(20);
else{ // movement is >0 )
while(currentPos < newPosition){
currentPos = currentPos + degreesPerStep;
delay(20);
I also tried this- but it didnt work
  • Arduino2Max
  • Send pin values from Arduino to MAX/MSP
  • Arduino2Max.pde
  • This version: .4, October 2007
  • Copyleft: use as you like
  • by Daniel Jolliffe
  • Based on a sketch and patch by Thomas Ouellet Fredericks tof.danslchamp.org
#include <Servo.h>
Servo myservo0;
Servo myservo1;
Servo myservo2;
Servo myservo3;
int pos = 0;
int pos2 = 0;
int x = 0; // a place to hold pin values
//int ledpin = 13;
Serial.begin(9600); // 115200 is the default Arduino Bluetooth speed
digitalWrite(13,HIGH); ///startup blink
delay(600);
digitalWrite(13,LOW);
pinMode(13,INPUT);
myservo0.attach(9); //analog 0
myservo1.attach(6); //analog 1
myservo2.attach(5); //analog 2
myservo3.attach(3); //analog 3
if (Serial.available() > 0){ // Check serial buffer for characters
if (Serial.read() == 'r') { // If an 'r' is received then read the pins
for (int pin= 0; pin<=5; pin++){ // Read and send analog pins 0-5
x = analogRead(pin);
sendValue (x);
for (int pin= 2; pin<=13; pin++){ // Read and send digital pins 2-13
x = digitalRead(pin);
sendValue (x);
Serial.println(); // Send a carriage returnt to mark end of pin data.
delay (5); // add a delay to prevent crashing/overloading of the serial port
void sendValue (int x){ // function to send the pin value followed by a "space".
Serial.print(x);
Serial.print(32, BYTE);
if (x< 110){
moveTo(170);
else{
moveTo(10);
int degreesPerStep = 4; // decrease this to slow movement
if (x==0){
if(movement < 0){
delay(20);
delay(20);
else if (x==1){
int currentPos = myservo1.read();
if(movement < 1){
myservo1.write( currentPos);
delay(20);
delay(20);
else if (x==2){
int currentPos = myservo2.read();
if(movement < 1){
myservo2.write( currentPos);
delay(20);
delay(20);
else if (x==3){
int currentPos = myservo3.read();
if(movement < 1){
myservo3.write( currentPos);
delay(20);
delay(20);
Thankssss, Larissa ::slight_smile:
Could you put the code in between [ code] [ /code] tags?
It makes it a lot more comfortable to go through the code...
#include <Servo.h>
Servo myservo0;
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
int pos = 0;
int pos2 = 0;
void setup()  {
void loop()  {
// servo 0 analog 0
   myservo0.write(10);
 // servo 1 analog 1
   myservo1.write(10);
 // servo 2 analog 2
   myservo2.write(10);
 // servo 3 analog 3
   myservo3.write(10);
 // servo 4 analog 4
   myservo4.write(10);
 // servo 5 analog 5
   myservo5.write(10);
 if(movement < 0){
     delay(20);
     delay(20);
*  Arduino2Max
*  Send pin values from Arduino to MAX/MSP
*  Arduino2Max.pde
*  This version: .4, October 2007
*  Copyleft: use as you like
*  by Daniel Jolliffe
*  Based on a sketch and patch by Thomas Ouellet Fredericks  tof.danslchamp.org
#include <Servo.h>
Servo myservo0;
Servo myservo1;
Servo myservo2;
Servo myservo3;
int pos = 0;
int pos2 = 0;
//int ledpin = 13;
 delay(600);
 pinMode(13,INPUT);
   sendValue (x);
   sendValue (x);
Serial.print(x);
 if (x< 110){
   moveTo(170);
 else{
   moveTo(10);
if (x==0){
 if(movement < 0){
     delay(20);
     delay(20);
else if (x==1){
 if(movement < 1){
     delay(20);
     delay(20);
else if (x==2){
 if(movement < 1){
     delay(20);
     delay(20);
else if (x==3){
 if(movement < 1){
     delay(20);
     delay(20);
Sorry :-[
For future reference, it is neater to just modify your original post, rather than make a new reply, which doesn't make it any neater. You can just highlight your code in the original post and click the code button.
if (x==[glow]3[/glow]){
 int currentPos = myservo[glow]3[/glow].read();
This screams "array" and "for" loop.
