Hi can someone help me add Mqtt user name and password to this code as I can not get it to work without errors so frustrating not sure what to do....
// Reads HRV TTL serial data and sends to an MQTT broker. Assumes you have HASSIO with MQTT running and configured.
// Requires:
// - ESP8266-01 (other 3.3V versions should work) see: https://github.com/esp8266/esp8266-wiki/wiki/Hardware_versions
// - TTL serial logic level converter (5V -> 3.3V) see: https://www.sparkfun.com/products/12009
// - AMS1117 3.3V voltage regulator (or similar, between HRV VCC and ESP VCC)
// - 1N5817 schottky diode (to stop HRV control panel resetting on ESP power on)
// - 10K ohm resistor (pullup resistor between 3.3 Voltage Regulator and ESP CH_PD)
// - 10V 100uF capacitor (or similar, to smooth out inbound power from HRV)
// - 10V 10uF capacitor (or similar, to smooth out outbound power to ESP)
// - Optional push button to reset the ESP
// Author: Mike Davis
// Date: 15 Nov 2021
// Version: 1
// LEDs to indicate operation (for newer ESP's with LED onboard)
// LED on solid = no serial data detected
// LED turned off = no WIFI connection detected
// LED blinking fast 10 times = no MQTT broker connection
// LED blinking every 1-2 seconds = normal operation, sending MQTT data
// Credit to: http://www.hexperiments.com/?page_id=47 for data structure
// Credit to: https://github.com/benrugg/Arduino-Hex-Decimal-Conversion for Dec/Hex conversion
#include <PubSubClient.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <ArduinoOTA.h>
#include "basicOTA.h"
// HRV constants
#define MSGSTARTSTOP 0x7E
#define HRVROOF 0x30
#define HRVHOUSE 0x31
// MQTT subs
#define HASSIOHRVSTATUS "hassio/hrv/status"
#define HASSIOHRVSUBHOUSE "hassio/hrv/housetemp"
#define HASSIOHRVSUBROOF "hassio/hrv/rooftemp"
#define HASSIOHRVSUBCONTROL "hassio/hrv/controltemp"
#define HASSIOHRVSUBFANSPEED "hassio/hrv/fanspeedInfo"
// MQTT pubs
#define HASSIOTESTINGPOWERCONTROL "hassio/hrv/powercontrol"
#define HASSIOTESTINGBURNTTOASTMODE "hassio/hrv/burnttoast"
#define HASSIOTESTINGVENTERLATIONLEVEL "hassio/hrv/venterlationlevel"
#define HASSIOTESTINGTEMPCONTROL "hassio/hrv/tempcontol"
// Wifi
const char* ssid = "SSID";
const char* password = "Password";
// MQTT Broker
IPAddress MQTT_SERVER(192, 168, 1, 0);
// TTL hrvSerial on GPIO ports (HRV does not like RX/TX ports!)
SoftwareSerial hrvSerial(D1, D2); // RX, TX
// The MAC address of the Arduino
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Define message buffer and publish string
char message_buff[16];
String pubString;
int iTotalDelay;
// TTL hrvSerial data indicators
bool bStarted = false;
bool bEnded = false;
// Temperature from Roof or House?
char eTempLoc;
// TTL hrvSerial data array, bIndex, bIndex of checksum and temperature
int iLoop;
byte inData[10];
byte bIndex;
byte bChecksum;
// Temperature for sending to MQTT
float fHRVTemp;
int iHRVControlTemp;
int iHRVFanSpeed;
// Maintain last temperature data, don't send MQTT unless changed
float fHRVLastRoof;
float fHRVLastHouse;
int iHRVLastControl;
int iHRVLastFanSpeed;
// Wifi Client
WiFiClient wifiClient;
IPAddress ipadd;
// Callback to Arduino from MQTT (inbound message arrives for a subscription)
// Potential future use...
/*void callback(char* topic, byte* payload, unsigned int length) {
// Messaging inbound from MQTT broker
int iChar = 0;
for(iChar=0; iChar<length; iChar++) {
message_buff[iChar] = payload[iChar];
message_buff[iChar] = '\0';
Serial.println("MQTT callback");
// This could be used in a future revision to control the HRV control panel remotely?
// Define Publish / Subscribe client (must be defined after callback function above if in use)
PubSubClient mqttClient(MQTT_SERVER, 1883, wifiClient);
// Setup the ESP for operation
// Setup Firmware update over the air (OTA)
setup_OTA();
// Set builtin LED as connection indicator
pinMode(LED_BUILTIN, OUTPUT);
// LED ON to show powering up but no connection
digitalWrite(LED_BUILTIN, LOW);
// Start HRV software serial (HRV sends at 1200 baud)
hrvSerial.begin(1200);
// Debug USB Serial
//Serial.setDebugOutput(true);
myDelay(10);
// Initialize defaults
bIndex = 0;
bChecksum = 0;
iTotalDelay=0;
// Check for OTA updates
ArduinoOTA.handle();
// If not MQTT connected, try connecting
if (!mqttClient.connected())
// Check its not cause WiFi dropped
startWIFI();
// If not MQTT connected, blink LED 5 times in succession
Serial.println("Connecting to MQTT Broker...");
int iRetries;
// If we lost MQTT connection, set last variables to arbitary figure to force a resend on next connection
iHRVLastFanSpeed = 255;
iHRVLastControl = 255;
fHRVLastRoof = 255;
fHRVLastHouse = 255;
// WiFi must be connected, try connecting to MQTT
while (mqttClient.connect("hrvwireless", HASSIOHRVSTATUS, 0, 0, "0") != 1)
Serial.println("Error connecting to MQTT (State:" + String(mqttClient.state()) + ")");
for (int iPos=1; iPos <= 10; iPos++)
// 10 fast blinks for no MQTT connection, also waits between attempts
myDelay(75);
digitalWrite(LED_BUILTIN, HIGH);
myDelay(75);
Serial.print(".");
// Double check WiFi state or # retries while in this loop just incase we timed it badly!
if (WiFi.status() != WL_CONNECTED || iRetries > 5)
Serial.println("No MQTT connection...");
// Make sure we're not stuck here forever, loop and reconnect WiFi if needed
iRetries++;
// Delay a couple seconds to settle before proceeding
myDelay(2000);
// LED back on solid if no serial data
if (hrvSerial.available() == 0)
Serial.println("No serial data detected!");
// Data available, LED off
// Only if we're plugged in...
while (hrvSerial.available() > 0)
// Read hrvSerial data
int inChar = hrvSerial.read();
// Start or stop marker or data too long - which is it? Wait til next loop
if (inChar == MSGSTARTSTOP || bIndex > 8)
// Start if first time we've got the message
if (bIndex == 0)
bStarted = true;
bChecksum = bIndex-1;
bEnded = true;
// Grab data
if (bStarted == true)
// Double check we actually got something
if (sizeof(inChar) > 0)
//Serial.print(inChar, HEX);
//Serial.print(",");
inData[bIndex] = inChar;
bIndex++;
// Time for WDT
myDelay(1);
// Validate data, or if not enough data will fail
if (bStarted && bEnded && bChecksum > 0)
int iChar;
int iLess;
// Checks
byte bCalc;
String sCalc;
byte bCheck;
String sCheck;
// Subtract from zero
iChar = 0;
// Subtract each byte in ID and data
for (int iPos=1; iPos < bChecksum; iPos++)
iLess = inData[iPos];
iChar = iChar - iLess;
// Convert calculations
bCalc = (byte) (iChar % 0x100);
sCalc = decToHex(bCalc, 2);
bCheck = (byte) inData[bChecksum];
sCheck = decToHex(bCheck, 2);
// Mod result by 256 and compare to checksum, or not enough data
if (sCalc != sCheck || bIndex < 6)
// Checksum failed, reset
bStarted = false;
bEnded = false;
bIndex = 0;
// Need to flush, maybe getting the end marker first
hrvSerial.flush();
// Reset checksum
bChecksum = 0;
// We got both start and end messages, process the data
if (bStarted && bEnded)
// Only process if we got enough data, minimum 6 characters
if (bIndex > 5)
String sHexPartOne;
String sHexPartTwo;
int iPos;
// Pull data out of the array, position 0 is 0x7E (start and end of message)
for (int iPos=1; iPos <= bIndex; iPos++)
// Position 1 defines house or roof temperature
if (iPos==1) { eTempLoc = (char) inData[iPos]; }
// Position 2 and 3 are actual temperature, convert to hex
if (iPos == 2) { sHexPartOne = decToHex(inData[iPos], 2); }
if (iPos == 3) { sHexPartTwo = decToHex(inData[iPos], 2); }
// Fan speed
if (eTempLoc == HRVHOUSE && iPos == 4) { iHRVLastFanSpeed = inData[iPos]; }
// If temperature is from control panel
if (eTempLoc == HRVHOUSE && iPos == 5) { iHRVControlTemp = inData[iPos]; }
// Concatenate first and second hex, convert back to decimal, 1/16th of dec + rounding
// Note: rounding is weird - it varies between roof and house, MQTT sub rounds to nearest 0.5
fHRVTemp = hexToDec(sHexPartOne + sHexPartTwo);
fHRVTemp = (fHRVTemp * 0.0625);
// Send data to MQTT broker
SendMQTTMessage();
// Reset defaults for processing
bStarted = false;
bEnded = false;
bIndex = 0;
// Wait for hrvSerial to come alive
myDelay(2000);
// Send I'm alive message every 30 seconds
if (WiFi.status() == WL_CONNECTED && mqttClient.connected() && iTotalDelay >= 30000)
Serial.println("Telling HASSIO we're still alive");
mqttClient.publish(HASSIOHRVSTATUS, "1");
iTotalDelay=0;
mqttClient.loop();
// Convert from decimal to hex
String decToHex(byte decValue, byte desiredStringLength)
String hexString = String(decValue, HEX);
while (hexString.length() < desiredStringLength) hexString = "0" + hexString;
return hexString;
// Convert from hex to decimal
unsigned int hexToDec(String hexString)
unsigned int decValue = 0;
int nextInt;
for (int i = 0; i < hexString.length(); i++) {
nextInt = int(hexString.charAt(i));
if (nextInt >= 48 && nextInt <= 57) nextInt = map(nextInt, 48, 57, 0, 9);
if (nextInt >= 65 && nextInt <= 70) nextInt = map(nextInt, 65, 70, 10, 15);
if (nextInt >= 97 && nextInt <= 102) nextInt = map(nextInt, 97, 102, 10, 15);
nextInt = constrain(nextInt, 0, 15);
decValue = (decValue * 16) + nextInt;
return decValue;
void SendMQTTMessage()
// Get an exception when MQTT publishing without wifi connection, so quick check first
if (WiFi.status() == WL_CONNECTED && mqttClient.connected())
// Convert data to nearest 0.5 of a degree then convert to char array
int iHRVTemp;
iHRVTemp = (int) ((fHRVTemp * 2) + 0.5);
fHRVTemp = (float) iHRVTemp / 2;
pubString = String(fHRVTemp);
pubString.toCharArray(message_buff, pubString.length()+1);
// What data are we sending?
if (eTempLoc == HRVHOUSE)
Serial.print("House ");
Serial.println(message_buff);
// Only send if changed
if (fHRVTemp != fHRVLastHouse)
Serial.println("(sending)");
fHRVLastHouse = fHRVTemp;
mqttClient.publish(HASSIOHRVSUBHOUSE, message_buff);
else if (eTempLoc == HRVROOF)
Serial.print("Roof ");
// Only send if changed by +/- 0.5 degrees
if (fHRVTemp != fHRVLastRoof)
fHRVLastRoof = fHRVTemp;
mqttClient.publish(HASSIOHRVSUBROOF, message_buff);
// Control Panel Set temperature in whole degrees, send if changed
if (iHRVControlTemp != iHRVLastControl || iHRVLastFanSpeed == 255)
pubString = String(iHRVControlTemp);
iHRVLastControl = iHRVControlTemp;
Serial.print("Control Panel: ");
mqttClient.publish(HASSIOHRVSUBCONTROL, message_buff);
// If anything has changed
if (iHRVLastFanSpeed != iHRVLastFanSpeed || iHRVControlTemp != iHRVLastControl || (eTempLoc == HRVROOF && fHRVTemp != fHRVLastRoof) || (eTempLoc == HRVHOUSE && fHRVTemp != fHRVLastHouse))
iHRVLastFanSpeed = iHRVLastFanSpeed;
if (iHRVLastFanSpeed == 0)
pubString = "Off";
else if (iHRVLastFanSpeed == 5)
pubString = "Idle";
else if (iHRVLastFanSpeed == 100)
pubString = "Full";
// Heating or Cooling?
if (iHRVLastControl >= fHRVLastRoof && fHRVLastRoof > fHRVLastHouse)
pubString = pubString + " (heating)";
else if (fHRVLastRoof <= iHRVLastControl && fHRVLastRoof < fHRVLastHouse)
pubString = pubString + " (cooling)";
pubString = String(iHRVLastFanSpeed) + "%";
Serial.print("Fan speed: ");
mqttClient.publish(HASSIOHRVSUBFANSPEED, message_buff);
// Flash LED real quick to indicate we're still working, then chill a bit
myDelay(50);
myDelay(1000);
// This function yields back to the watchdog to avoid random ESP8266 resets
void myDelay(int ms)
int i;
for(i=1; i!=ms; i++)
delay(1);
if(i%100 == 0)
ESP.wdtFeed();
yield();
iTotalDelay+=ms;
// Starts WIFI connection
void startWIFI()
// If we are not connected
if (WiFi.status() != WL_CONNECTED)
int iTries;
iTries=0;
Serial.println("Starting WIFI connection");
WiFi.mode(WIFI_STA);
WiFi.disconnect();
WiFi.begin(ssid, password);
// If not WiFi connected, retry every 2 seconds for 15 minutes
while (WiFi.status() != WL_CONNECTED)
iTries++;
Serial.print(".");
delay(2000);
// If can't get to Wifi for 15 minutes, reboot ESP Default 450
if (iTries > 50)
Serial.println("TOO MANY WIFI ATTEMPTS, REBOOTING!");
ESP.reset();
Serial.println("");
Serial.println("WiFi connected");
// Let network have a chance to start up
myDelay(1500);
