Adding multiple analog inputs to code
New to Arduino and cant figure out how to get the code for multiple analog inputs to be read for use in PureData. I want six potentiometers to run as inputs. Any ideas?
Thanks very much.
#include <Firmata.h>
byte analogPin = 0;
void analogWriteCallback(byte pin, int value)
    if (IS_PIN_PWM(pin)) {
        pinMode(PIN_TO_DIGITAL(pin), OUTPUT);
        analogWrite(PIN_TO_PWM(pin), value);
    Firmata.setFirmwareVersion(0, 1);
    Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
    Firmata.begin(57600);
    while(Firmata.available()) {
        Firmata.processInput();
    // do one analogRead per loop, so if PC is sending a lot of
    // analog write messages, we will only delay 1 analogRead
    Firmata.sendAnalog(analogPin, analogRead(analogPin));
    analogPin = analogPin + 1;
    if (analogPin >= TOTAL_ANALOG_PINS) analogPin = 0;
It is NOT done by changing the Arduino code.
J_Sev90: I want six potentiometers to run as inputs. Any ideas?
[/code]
i'm no expert here But i think you can done this by using
val1 = analogRead(pin1);
val2 = analogRead(pin2);
val3 = analogRead(pin3);
val6  = analogRead(pin6)
Or even better, use a for loop
  for (int analogPin = 0; analogPin < 6; analogPin++)
    Serial.println(analogRead(analogPin));
  delay(1000);  //just an example.  Don't use delay() in real code
and array to store values
   val[analogPin] = Serial.println(analogRead(analogPin));
Did either of you look at OP's code? OP is loading Firmata on the Arduino, putting it under PureData's control. Reading multiple analog pins is something that PureData will need to make happen.
and he is asking for help with this in an Arduino programming forum ?
This
byte analogPin;
    pinMode(pin,OUTPUT);
    analogWrite(pin, value);
    Firmata.begin();
    for(analogPin = 0; analogPin < TOTAL_ANALOG_PINS; analogPin++) {
from
http://arduino.cc/en/Reference/Firmata
looks relevant. Haven’t I seen that for loop, or something very like it. somewhere before ?
