Adding multiple lines of input and running it line by line
You called some pumpReq function.
But I can't see any pumpReq function defined in the whole program.
that code is ifdef'd out. presumably there's no need to immediately process a "program" because it should only be queued and processed only after the start signal
How do I give new inputs through serial?
enable the Serial code, #if 1 and call queue() with buf
there's no acknowledgement that wat i posted is what you're trying to do
You really need to do a few things.
First is to draw a flow diagram showing exactly what you are trying to do, secondly write pseudo code for how you envisage this process to work.
You say you are taking in a serial value, but you don't say where these value are coming from and at what rate.
There is no use going into writing a load of code if people are flailing around trying to understand what the issue is.
thank you, I have tested the code with my project it is working, I also want to give a signal(88) for terminating the program in middle just like a abort function. I am also attaching the modified code.
#include <RCA.h>
RCA modone;
int s1    = 22;
int s2    = 23;
int s3    = 24;
int s4    = 25;
int s5    = 26;
int s6    = 27;
int s7    = 28;
int s8    = 29;
int c1    = 30;
int c2    = 31;
int c3    = 32;
int c4    = 33;
int c5    = 34;
int c6    = 35;
int s11    = 36;
int s22    = 37;
int s33    = 38;
int s44    = 39;
int s55    = 40;
int s66    = 41;
int s77    = 42;
int s88    = 43;
int c11    = 44;
int c22    = 45;
int c33    = 46;
int c44    = 47;
int c55    = 48;
int c66    = 49;
char s   [80];
//const char *programs [] = {};
//int progIdx;
char buf [80];
unsigned long msec;
int pinS,pinC,pinS1,pinC1;
enum { Off = HIGH, On = LOW };
#define MaxTok  20
char *toks [MaxTok];
int   vals [MaxTok];
#define NcmdQ 20
struct Q {
    char  cmdQ [NcmdQ][30];
    int   head;
    int   tail;
    int   cnt;
struct Pump {
    byte          pul,stp,dir;
    const char   *label;
    bool          active;
    Q             q;
    int           pwm;
    int           solenoid0;
    int           solenoid1;
    unsigned long msecLst;
    unsigned long period;
Pump pumps [] = {
    { 3, "pump-0" },
    { 9,10,11, "pump-1" },
    { 8,12,13, "pump-2" },
#define Npump   (sizeof(pumps)/sizeof(Pump))
void setup (){
    Serial.begin (9600);
    modone.PinSetup();
    Serial.println ("ready");
int tokenize (char *s,const char *sep ){
    unsigned n = 0;
    toks [n] = strtok (s, sep);
    vals [n] = atoi (toks [n]);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void queue (const char *buf,struct Q   *q,const char *label ){
    sprintf (s, "queue: %s - %s", label, buf);
    Serial.println (s);
    if (NcmdQ <= q->cnt)  {
        sprintf (s, "queue: full");
        Serial.println (s);
    memcpy (q->cmdQ [q->head++], buf, strlen(buf));
    if (NcmdQ <= q->head)
        q->head = 0;
    q->cnt++;
char *dequeue (Q *q){
    if (0 == q->cnt)
        return NULL;
    char *buf = q->cmdQ [q->tail++];
    if (NcmdQ <= q->tail)
        q->tail = 0;
    q->cnt--;
    sprintf (s, " dequeue: %s", buf);
    Serial.println (s);
    return buf;
void Pumprun (char *buf ){
    if (4 > tokenize (buf, ","))  {
        sprintf (s, "Error: wrong # of values - %s", s);
        Serial.println (s);
        return;
    unsigned idx = vals [0];
    Pump *p = & pumps [idx];
    p->pwm       = vals [1];
    p->solenoid0 = vals [2];
    p->solenoid1 = vals [3];
    p->period    = vals [4] * 1000L;
    p->msecLst   = msec;
    p->active    = true;
    if (idx == 1){
      rusolenoid(p->solenoid0);
      rdsolenoid(p->solenoid1);
      if (pinS){
        digitalWrite(pinS, HIGH);
      if (pinC){
        digitalWrite(pinC, HIGH);
    else if (idx == 2){
      lusolenoid(p->solenoid0);
      ldsolenoid(p->solenoid1);
      if (pinS1){
        digitalWrite(pinS1, HIGH);
      if (pinC1){
        digitalWrite(pinC1, HIGH);
    analogWrite (p->pul, p->pwm);
    digitalWrite(p->stp, On);
    digitalWrite(p->dir, On);
    sprintf (s, "  pumpRun: %s On (%lu ms)", p->label, p->period);
    Serial.println (s);
void Pumpmonitor (){
    Pump *p = pumps;
    for (unsigned n = 0; n < Npump; n++, p++)  {
        if (p->active && (msec - p->msecLst) >= p->period)  {
            analogWrite (p->pul, 0);
            digitalWrite(p->stp, Off);
            digitalWrite(p->dir, Off);
            if (idx == 1){
              modone.line1_soff();
            else if (idx == 2){
              modone.line2_soff();
            p->active    = false;
            sprintf (s, "   pumpRun: %s Off", p->label);
            Serial.println (s);
            char *buf = dequeue (& p->q);
            if (NULL != buf)
                Pumprun (buf);
            else  {
                sprintf (s, "   pumpRun: %s is done", p->label);
                Serial.println (s);
void Pumpstart (){
    Pump *p = pumps;
        if (! p->active)  {
            if (NULL != buf)
                Pumprun (buf);
        else {
            sprintf (s, "%s: pump %d active", __func__, n);
            Serial.println (s);
void rusolenoid(int sval){
      if(sval == 1){
        pinS = s1;
      else if(sval == 2){
        pinS = s2;
      else if(sval == 3){
        pinS = s3;
      else if(sval == 4){
        pinS = s4;
      else if(sval == 5){
        pinS = s5;
      else if(sval == 6){
        pinS = s6;
      else if(sval == 7){
        pinS = s7;
      else if(sval == 8){
        pinS = s8;
      else {
        Serial.println("Select from solenoid");
void rdsolenoid(int cval){
      if(cval == 1){
        pinC = c1;
      else if(cval == 2){
        pinC = c2;
      else if(cval == 3){
        pinC = c3;
      else if(cval == 4){
        pinC = c4;
      else if(cval == 5){
        pinC = c5;
      else if(cval == 6){
        pinC = c6;
      else {
        Serial.println("Select to solenoid");
void lusolenoid(int svalone){
      if(svalone == 1){
        pinS1 = s11;
      else if(svalone == 2){
        pinS1 = s22;
      else if(svalone == 3){
        pinS1 = s33;
      else if(svalone == 4){
        pinS1 = s44;
      else if(svalone == 5){
        pinS1 = s55;
      else if(svalone == 6){
        pinS1 = s66;
      else if(svalone == 7){
        pinS1 = s77;
      else if(svalone == 8){
        pinS1 = s88;
      else {
void ldsolenoid(int cvalone){
      if(cvalone == 1){
        pinC1 = c11;
      else if(cvalone == 2){
        pinC1 = c22;
      else if(cvalone == 3){
        pinC1 = c33;
      else if(cvalone == 4){
        pinC1 = c44;
      else if(cvalone == 5){
        pinC1 = c55;
      else if(cvalone == 6){
        pinC1 = c66;
      else {
void loop (){
    msec = millis ();
    Pumpmonitor ();
    if (Serial.available ())  {
        int n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        unsigned idx = atoi (buf);
        if (3 == idx){
            Pumpstart ();}
        else{
            queue (buf, & pumps [idx].q, pumps [idx].label);}
