Adding Multiple "Lines" of Scrolling String Text to Matrix
Hello all. I am new here. I have been digging into the attached code for a couple days and i am stuck.
I would like to modify this code to be able to have various sentences scroll in the loop. There are 7 colors that i have listed. The current Writetext says Happy Birthday James.
The way the code is written, it will scroll “Happy birthday James” 7 times in the different colors. I would rather it be
Sentence 1 - Color 0
Sentence 2 - Color 1
Sentence 3 - Color 2
Sentence 4 - Color 3
Sentence 5 - Color 4
Sentence 6 - Color 5
Sentence 7 - Color 6
The issue is if i add more writetext commands, it sites the code at the bottom, and causes the same loop of 7 colors to play out per string text after writetext.
After digging in, i think i need to add some lines allowing me to modify the string text referred to as (string msg). I think it is likely i need to do this around this point in the code:
x = matrix.width(); // After Scrolling by scrollingMax pixels, RESET Cursor Position and Start String at New Position on the Far Right;
++clr; // INCREMENT COLOR/REPEAT LOOP COUNTER AFTER MESSAGE COMPLETED;
matrix.show(); // DISPLAY the Text/Image
delay(40); // SPEED OF SCROLLING or FRAME RATE;
clr = 0; // Reset Color/Loop Counter;
I feel like this should be a simple edit, but i am really stuck and would appreciate any guidance.
Thank you!
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
//   NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
//     Position of the FIRST LED in the matrix; pick two, e.g.
//     NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
//   NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
//     rows or in vertical columns, respectively; pick one or the other.
//   NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
//     in the same order, or alternate lines reverse direction; pick one.
//   See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
int matrixW = 32;
int matrixH = 8;
#define PIN 6 // OUTPUT PIN FROM ARDUINO TO MATRIX D-In
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(matrixW, matrixH, PIN,
                            NEO_MATRIX_TOP     + NEO_MATRIX_LEFT +
                            NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
                            NEO_GRB            + NEO_KHZ800);
const uint16_t colors[] = {
  matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(255, 255, 0), matrix.Color(0, 0, 255), matrix.Color(255, 0, 255), matrix.Color(0, 255, 255), matrix.Color(255, 255, 255)
#define arr_len( x )  ( sizeof( x ) / sizeof( *x ) ) // Calculation of Array Size;
int pixelPerChar = 6; // Width of Standard Font Characters is 8X6 Pixels
int x = matrix.width(); // Width of the Display
int pass = 0; // Counter
int i = 0; // Counter
int clr = 0; // Counter for Indexing Array of Colors
char msg[] = "-------------------"; // BLANK Message of Your Choice;
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(5);
  matrix.setTextColor(colors[0]);
  int arrSize = arr_len( colors );
  char exampleText[] = "Happy Birthday James!"; // SCROLLING Message of Your Choice;
  writeText(exampleText);
  matrix.print(msg); //Print the Message String;
  matrix.show();
  /*  Commands for Debugging  */
  char msgText[] = "Let's Start Over";
  matrix.print(msgText); // Scrolling Print the Message String;
  matrix.show();
  writeText("End of Loop"); //Print the Message String;
  // LATHER - RINSE - REPEAT Is Why coders never leave the Shower;
/* --------------------  FUNCTIONS BELOW  --------------------  */
void writeText(String msg) {
  int arrSize = arr_len( colors ); // Array of Text Colors;
  int msgSize = (msg.length() * pixelPerChar) + (2 * pixelPerChar); // CACULATE message length;
  int scrollingMax = (msgSize) + matrix.width(); // ADJUST Displacement for message length;
  x = matrix.width(); // RESET Cursor Position and Start Text String at New Position on the Far Right;
  clr = 0; // RESET Color/Repeat Index;
  while (clr <= arrSize) {
    /* Change Color with Each Pass of Complete Message */
    matrix.setTextColor(colors[clr]);
    matrix.fillScreen(0); // BLANK the Entire Screen;
    matrix.setCursor(x, 0); // Set Starting Point for Text String;
    matrix.print(msg); // Set the Message String;
    /* SCROLL TEXT FROM RIGHT TO LEFT BY MOVING THE CURSOR POSITION */
    if (--x < -scrollingMax ) {
      /*  ADJUST FOR MESSAGE LENGTH  */
      // Decrement x by One AND Compare New Value of x to -scrollingMax;
     // This Animates (moves) the text by one pixel to the Left;
/* LATHER - RINSE - REPEAT - Why coders have such nice hair */
That is their sketch. What is your sketch?
I have never made my own sketch. I am learning as I go. If I am struggling to modify this sketch I definitely am unable to write a sketch from scratch.
