Adding parameters to a function in a class
Hi all.
Im with a proyect with Arduino and have an issue. Not a Programmer.
Dont want to bore you so I will just tell you what I want to do.
I have two classes that are related. Both have a read() funtion but one
has parameters defined and the other does not.
void read(bool polling = true);
void read();
I try just typing (bool polling = true) in the second one but I get the error
undefined reference toAdafruit_MultiTrellis::read(bool)'`
Any guide there?
Here is the full Library
 #ifndef _NEO_TRELLIS_H
 #define _NEO_TRELLIS_H
 #include "Adafruit_seesaw.h"
 #include "seesaw_neopixel.h"
 #include <Arduino.h>
 #define NEO_TRELLIS_ADDR 0x2E
 #define NEO_TRELLIS_NEOPIX_PIN 3
 #define NEO_TRELLIS_NUM_ROWS 4
 #define NEO_TRELLIS_NUM_COLS 4
 #define NEO_TRELLIS_NUM_KEYS (NEO_TRELLIS_NUM_ROWS * NEO_TRELLIS_NUM_COLS)
 #define NEO_TRELLIS_MAX_CALLBACKS 32
 #define NEO_TRELLIS_KEY(x) (((x) / 4) * 8 + ((x) % 4))
 #define NEO_TRELLIS_SEESAW_KEY(x) (((x) / 8) * 4 + ((x) % 8))
 #define NEO_TRELLIS_X(k) ((k) % 4)
 #define NEO_TRELLIS_Y(k) ((k) / 4)
 #define NEO_TRELLIS_XY(x, y) ((y)*NEO_TRELLIS_NUM_ROWS + (x))
 typedef void (*TrellisCallback)(keyEvent evt);
 class Adafruit_NeoTrellis : public Adafruit_seesaw {
 public:
   Adafruit_NeoTrellis(uint8_t addr = NEO_TRELLIS_ADDR);
   ~Adafruit_NeoTrellis(){};
   bool begin(uint8_t addr = NEO_TRELLIS_ADDR, int8_t flow = -1);
   void registerCallback(uint8_t key, TrellisCallback (*cb)(keyEvent));
   void unregisterCallback(uint8_t key);
   void activateKey(uint8_t key, uint8_t edge, bool enable = true);
   seesaw_NeoPixel pixels;
   friend class Adafruit_MultiTrellis;
 protected:
   uint8_t _addr;
   TrellisCallback (*_callbacks[NEO_TRELLIS_NUM_KEYS])(
       keyEvent);
 class Adafruit_MultiTrellis {
 public:
   Adafruit_MultiTrellis(Adafruit_NeoTrellis *trelli, uint8_t rows,
                         uint8_t cols);
   ~Adafruit_MultiTrellis(){};
   bool begin();
   void registerCallback(uint16_t num, TrellisCallback (*cb)(keyEvent));
   void registerCallback(uint8_t x, uint8_t y, TrellisCallback (*cb)(keyEvent));
   void unregisterCallback(uint16_t num);
   void unregisterCallback(uint8_t x, uint8_t y);
   void activateKey(uint16_t num, uint8_t edge, bool enable = true);
   void activateKey(uint8_t x, uint8_t y, uint8_t edge, bool enable = true);
   void setPixelColor(uint8_t x, uint8_t y, uint32_t color);
   void setPixelColor(uint16_t num, uint32_t color);
   void show();
   void read();
 protected:
   uint8_t _rows;
   uint8_t _cols;
   Adafruit_NeoTrellis
       *_trelli;
 #endif
you have to add it in cpp too
Why do you want them both to be the same?
YES !!!
Worked.
Thank you
