Adding pause to servo sweep
Hi
Im new to the forum.
I have found a sketch that is exactlly what I want for my project, but I want to modify it.
The sketch does the following: the push-button is pushed once, the servo goes from 0 to 180 degrees and back to 0.
I want to add a pause when the servoe reaches 180. So it goes from 0 to 180, pauses for X seconds, and goes back to 0 without further input.
I have tried adding the delay-function into the code I have but I cant seem to find the right place.
Would delay(5000); be the proper function to use?
My question is: where do I supplement the code that I have with the proper function to make it pause at 180 degrees?
Here is the code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
#define servoPin 3 //~
#define pushButtonPin 2
int angle =90;    // initial angle  for servo (beteen 1 and 179)
int angleStep =10;
const int minAngle = 0;
const int maxAngle = 180;
const int type =2;//watch video for details. Link is at the top of this code (robojax)
int buttonPushed =0;
  // Servo button demo by Robojax.com
  Serial.begin(9600);          //  setup serial
  myservo.attach(servoPin);  // attaches the servo on pin 3 to the servo object
  pinMode(pushButtonPin,INPUT_PULLUP);
   Serial.println("Robojax Servo Button ");
   myservo.write(angle);//initial position
  if(digitalRead(pushButtonPin) == LOW){
    buttonPushed = 1;
   if( buttonPushed ){
  // change the angle for next time through the loop:
  angle = angle + angleStep;
    // reverse the direction of the moving at the ends of the angle:
    if (angle >= maxAngle) {
      angleStep = -angleStep;
        if(type ==1)
            buttonPushed =0;
    if (angle <= minAngle) {
       if(type ==2)
            buttonPushed =0;
    myservo.write(angle); // move the servo to desired angle
      Serial.print("Moved to: ");
      Serial.print(angle);   // print the angle
      Serial.println(" degree");
  delay(100); // waits for the servo to get there
The code is from Youtube: Control Servo motor with a Push Button: Move Servo and Return SPB-1 - Robojax
I know that I dont need the serial.print stuff, but hey...
All response highly appreciated. Thanks.
Try this, dirty but but maybe working. Look for "Railroader" in the code.
#include <Servo.h>
int angle = 90;   // initial angle  for servo (beteen 1 and 179)
int angleStep = 10;
const int type = 2; //watch video for details. Link is at the top of this code (robojax)
int buttonPushed = 0;
  pinMode(pushButtonPin, INPUT_PULLUP);
  if (digitalRead(pushButtonPin) == LOW) {
    buttonPushed = 1;
  if ( buttonPushed ) {
      delaye(5000);//                               added by Railroader
      if (type == 1)
        buttonPushed = 0;
      if (type == 2)
        buttonPushed = 0;
or you can just put a delay inbetween the 2 for loops...
idv7:
Where can you see any for loops in the code from the original post that you're replying to?
Steve
/* Sweep
 by BARRAGAN <http://barraganstudio.com>
 This example code is in the public domain.
 modified 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
delay(3000);
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
dinoclassic:
Yes, if 'X' is equal to 5.
dinoclassic:
Right after:
Thanks guys!
It works as intended!
Awesome.
Thanks for telling! Well done!
