Adding Screen - ERROR while compiling - NEWBIE
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
#include <MIDI.h>
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
void setup(void) {
  u8g2.begin();
void loop(void) {
  u8g2.clearBuffer();         // clear the internal memory
  u8g2.setFont(u8g2_font_logisoso28_tr);  // choose a suitable font at https://github.com/olikraus/u8g2/wiki/fntlistall
  u8g2.drawStr(8, 32, "STRING "); // write something to the internal memory
  u8g2.sendBuffer();         // transfer internal memory to the display
  delay(800);
  u8g2.drawStr(0, 32, "VELOCTY"); // write something to the internal memory
  delay(800);
  static const unsigned ledPin = LED_BUILTIN; // use onboard LED as activity indicator
  static const byte switchPin[] = {2, 3, 4}; // pins for footswitch inputs
  static const byte switchCount = 2; // number of footswitches used
  static bool switchPressed[switchCount]; // current state of footswitches
  static bool switchLastState[switchCount]; //previous state of footswitches (used for long press detection)
  static unsigned long lastPressMillis[switchCount]; // when the last button press was detected
  static unsigned long lastReleaseMillis[switchCount]; // when the last button was released
  // Created and binds the MIDI interface to the default hardware Serial port
  MIDI_CREATE_DEFAULT_INSTANCE();
  void errBlink(int errCode) {
    byte blinkTime = 200; // duration for each blink
    byte blinkGap = 200; // gap between each blink
    int burstWait = 1000; // wait time between bursts
    for (;;) { // loop forever
      for (int i = 1; i <= errCode; i++) {
        digitalWrite(ledPin, HIGH);
        delay(blinkTime);
        digitalWrite(ledPin, LOW);
        delay(blinkGap);
      delay(burstWait);
  } // end of errBlink()
    pinMode(ledPin, OUTPUT);  // setup activity LED pin for output
    MIDI.begin(MIDI_CHANNEL_OMNI);  // Listen to all incoming messages
    // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
    if (!display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR)) { // Address 0x3C for my 128x64 variant
      errBlink(ERR_DISP_ALLOC);
    // Initialise switches and related variable arrays
    for (int i = 0; i < switchCount; i++) {
      pinMode(switchPin[i], INPUT_PULLUP); // add pullup resistors to all footswitch input pins
      switchPressed[i] = false; //initialise switch state
      switchLastState[i] = false; //initialse last switch state
      lastReleaseMillis[i] = millis(); // initialise time switch last released
      lastPressMillis[i] = lastPressMillis[i] - 1; // initialise time switch last pressed
  } // end of setup
    readButtons();
    displayUpdate();
    midiSend();
  } // end of loop
     Input related declarations and functions
  static const bool switchDown = LOW; // because we are using pullup resistor and switch to GND
  static const byte debounceTime = 1000; // after processing a button press, ignore further input for some milliseconds
  static const byte debounceDelay = 3; // amount of time to wait before retesting debounceTime
  static const int longPressTime = 600; // how long a switch has to be held to count as a long press
  static int switchPressedCounter = 0; // how many switches are currently pressed
  static byte nextCommand = -1; // most important pending action - the switch that was last pressed, or other command via multi or long press
  static byte lastCommand = -1; // last command sent (used for display confirmation)
  static unsigned long commandMillis = millis(); // the time that nextCommand was last set - ie the last switch to be pressed
  static const byte pagePatchReset = 5 * switchCount + 3;
  static const byte pageUp = 5 * switchCount + 2;
  static const byte pageDn = 5 * switchCount + 1;
  static byte currentPage = 0; // the current page / bank to be displayed
  static const byte pageCount = 5; // how many pages we have configured
  void readButtons() {
      switchPressed[i] = ( digitalRead(switchPin[i]) == switchDown ); // set array element to true if switch is currently pressed, or false if not
      if (switchPressed[i] != switchLastState[i]) { //potential press or release detected
        if (switchPressed[i]) { // potential new press detected
          if ( millis() > (lastPressMillis[i] + debounceTime) ) { // genuine press and not switch bounce
            lastPressMillis[i] = millis();
            switchLastState[i] = true;
            nextCommand = i;
        else if (!switchPressed[i]) { //potential switch release detected
          if ( millis() > (lastReleaseMillis[i] + debounceTime ) ) { // genuine release and not switch bounce
        switchPressedCounter++;  //increment counter used to check multiple presses
        if (  millis() > (lastPressMillis[i] + longPressTime)  ) { // long press detected
          lastPressMillis[i] = millis(); // reset timer so it doesn't re-trigger every loop
          nextCommand = i + switchCount; // use the next n numbers as a second bank of commands representing long press actions
    static bool comboActive = false; // remembers whether multiple presses were detected to avoid re-triggering every loop
    if (switchPressedCounter > 1 ) { // multiple presses detected
      if (!comboActive) {
        comboActive = true;
        if ( switchPressed[0] && switchPressed[1]) { // first two switches -> Page Down
          nextCommand = pageDn;
          changePageDown();
        else if ( switchPressed[1] && switchPressed[2]) { // second two switches -> Page Up
          nextCommand = pageUp;
          changePageUp();
    else {
      comboActive = false; // we can reset this as no more than one switch currently pressed
    lastCommand = nextCommand;
  } // end of read_buttons()
  void changePageUp() {
    currentPage++;
    if (currentPage >= pageCount) { // we have gone past the last page
      currentPage = 0; // reset to first page
  void changePageDown() {
    currentPage--;
    if (currentPage > pageCount) { // we have scrolled back past the first page
      currentPage = (pageCount - 1); // reset to last page
     Display related functions
  void invSelection(int i = (lastCommand + 1)) {
    if (lastCommand == i) {
      display.setTextColor(BLACK, WHITE);
    else {
      display.setTextColor(WHITE, BLACK);
  void displayLine(const __FlashStringHelper * str0, const __FlashStringHelper * str1, const __FlashStringHelper * str2, const __FlashStringHelper * str3, int startBtn) {
    display.print(F(""));
    invSelection(0 + startBtn);
    display.print(str0);
    invSelection();
    invSelection(1 + startBtn);
    display.print(str1);
    invSelection();
    invSelection(2 + startBtn);
    display.print(str2);
    invSelection();
    invSelection(3 + startBtn);
    display.print(str3);
    invSelection();
    display.println(F(""));
  void displayUpdate(void) { // maybe change this to put labels in arrays, but this will do for now
    display.clearDisplay();
    display.setCursor(0, 0);     // Start at top-left corner
    switch (currentPage) {
      case 0:
        displayLine(F("    S.V.   "), F("             4"), F("/5   "), F("    FTSW"), 4);
      case 1:
        displayLine(F("    S.V.    "), F("           Pv"), F("/Nxt"), F("     PRST"), 4);
      case 2:
        displayLine(F("    S.V.    "), F("           Pv"), F("/Nxt"), F("     SNPS"), 4);
      case 3:
        displayLine(F("    S.V.    "), F("           Pv"), F("/Nxt"), F("     MODE"), 4);
      case 4:
        displayLine(F("    S.V.    "), F("            T/"), F(""), F("T"), 4);
        display.display();
       MIDI output related functions
    void midiSend() {
      // do something
      if (nextCommand >= 0) {
        if (nextCommand == pagePatchReset) { // SW7 & SW8 should reset page and patch to 0 regardless of which page/patch currently active
          MIDI.sendProgramChange(0, 1);
          case 0: // menu page 0 (1 of 5)
            switch (nextCommand) {
              case 0:
                MIDI.sendControlChange(52, 1, 1); //FS 4
              case 2:
                MIDI.sendControlChange(53, 1, 1); // FS 5
              case 5:  // long press on SW2 (center switch)
                MIDI.sendControlChange(68, 68, 1); //tuner
            } // end of menu page 1
          case 1: // menu page 2 (2 of 5)
              case 0:
                MIDI.sendControlChange(72, 0, 1); //Preset UP
              case 2:
                MIDI.sendControlChange(72, 127, 1); //Preset Dwn
              case 5:  // long press on SW1 (Left switch)
            } // end of menu page 2
          case 2: // menu page 3 (3 of 5)
              case 0:
                MIDI.sendControlChange(69, 9, 1); //Snap Shot Prev
              case 2:
                MIDI.sendControlChange(69, 8, 1); //Snap Shot Nxt
            } // end of menu page 3
          case 3: // menu page 4 (4 of 5)
              case 0:
                MIDI.sendControlChange(71, 5, 1); //Mode Prev
              case 2:
                MIDI.sendControlChange(71, 4, 1); //Mode Nxt
              case 6:  // long press on SW1 (Left switch)
            } // end of menu page 4
          case 4: // menu page 5 (5 of 5)
              case 0: //on
                MIDI.sendControlChange(85, 127, 1); //tap tempo
            } // end of menu page 5
        } // end of outer nested switch case
        nextCommand = -1; // re-initialise this so we don't send the same message repeatedly
    } // end midisend
Are we to guess the nature of the error?
Please post the entire text of the error message. Paraphrasing leaves out important information.
On a cellphone at the moment but you seem to have function definitions inside functions. That would be problem one.
You also seem (to be trying) to use multiple setup() and loop() functions. That will result in compiler errors as well.
You seem to be trying to combine 2 or more programs into one.
Combining Arduino codes tutroials.
Merging Arduino codes.
Combining Arduino codes.
trying to combine 2 codes
error ----
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Nano, ATmega328P"
/Users/mikemcclain/Downloads/oled_0.91inch_128x32/oled_0.91inch_128x32.ino: In function 'void loop()':
oled_0.91inch_128x32:42:30: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:58:16: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:81:15: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:111:22: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:164:23: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:171:25: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:188:30: error: local variable 'lastCommand' may not appear in this context
oled_0.91inch_128x32:188:48: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:219:28: error: a function-definition is not allowed here before '{' token
oled_0.91inch_128x32:344:5: error: expected '}' at end of input
} // end midisend
Using library U8g2 at version 2.34.22 in folder: /Users/mikemcclain/Documents/Arduino/libraries/U8g2
Using library SPI at version 1.0 in folder: /Users/mikemcclain/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI
Using library Wire at version 1.0 in folder: /Users/mikemcclain/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire
Using library MIDI_Library at version 5.0.2 in folder: /Users/mikemcclain/Documents/Arduino/libraries/MIDI_Library
exit status 1
Like @sterretje says, you cannot have a function definition inside of another function.
