Adding Serial.begin() Causes LPD6803 to stop working
    IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
                        INCLUDE
/* IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
     INCLUDE - LED LPD6803
#include <TimerOne.h>    // I Dont think this is needed.
#include "LPD6803.h"
// Example to control LPD6803-based RGB LED Modules in a strand
// Original code by Bliptronics.com Ben Moyes 2009
// Use this as you wish, but please give credit, or at least buy some of my LEDs!
// Code cleaned up and Object-ified by ladyada, should be a bit easier to use
// Choose which 2 pins you will use for output.
// Can be any valid output pins.
int dataPin = 2;       // 'yellow' wire
int clockPin = 3;      // 'green' wire
// Don't forget to connect 'blue' to ground and 'red' to +5V
// Timer 1 is also used by the strip to send pixel clocks
// Set the first variable to the NUMBER of pixels. 20 = 20 pixels in a row
LPD6803 strip = LPD6803(50, dataPin, clockPin);
    SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
                        SETUP
  /* SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
       SETUP - GPIO Hardware Input/Output Devices
       SETUP - LPD6803
  // The Arduino needs to clock out the data to the pixels
  // this happens in interrupt timer 1, we can change how often
  // to call the interrupt. setting CPUmax to 100 will take nearly all all the
  // time to do the pixel updates and a nicer/faster display,
  // especially with strands of over 100 dots.
  // (Note that the max is 'pessimistic', its probably 10% or 20% less in reality)
  strip.setCPUmax(50);  // start with 50% CPU usage. up this if the strand flickers or is slow
  // Start up the LED counter
  strip.begin();
  // Update the strip, to start they are all 'off'
  strip.show();
  //Serial.begin(9600);  // CAN NOT RUN SERIAL with CODE. MUST COMMENT OUT FOR THE LED'S TO WORK
    Serial.println("Start");
    Serial.println(Color(255, 255, 255)); // = 32767
    Serial.println(Color(127, 127, 127)); // = 32767 MAX VALUE for each color. Anything over 127 will give the same result.
    Serial.println(Color(126, 127, 127)); // = 32766
    Serial.println(Color(99, 99, 99)); // = 03171
    Serial.println(Color(00, 00, 60)); // = 28672
    Serial.println(Color(00, 63, 00)); // = 992
    Serial.println(Color(63, 00, 00)); // = 31
    Serial.println(Color(90, 00, 00)); // = 26
    LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
                        LOOP
  /* LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
     LOOP - Basic LED Send out values.
  // strip.setPixelColor accepts 2 formats:
  // strip.setPixelColor(Cell Number, Decimal number)
  // strip.setPixelColor(Cell Number, Blue, Green, Red)  // Value UP TO 127 accepted.
  strip.setPixelColor(0, 32767);  // setPixelColor take the 5 digit bit, combines it will 0 to create the 6th multiple.
  //strip.setPixelColor(1, 896);
  strip.setPixelColor(1, 127, 0, 0);  // BLUE GREEN RED, in that order. Cause it is silly.
  strip.setPixelColor(2, 0, 90, 0);  // = Green
  strip.setPixelColor(3, 0, 00, 90); // = RED
  strip.setPixelColor(4, 0, 00, 90);
  strip.setPixelColor(5, 0, 00, 90);
  strip.setPixelColor(6, 0, 00, 90);
  strip.setPixelColor(7, 0, 00, 90);
  strip.setPixelColor(41, 0, 110, 127);
  strip.setPixelColor(42, 0, 110, 127);
  strip.setPixelColor(43, 0, 110, 127);
  strip.setPixelColor(23, 0, 00, 90);
  // strip.setPixelColor(1, Color(25, 06, 00));
  //strip.setPixelColor(2, Color(25, 25, 25));
  //strip.show();
// BELOW is not needed.
unsigned int Color(byte r, byte g, byte b)
  //Take the lowest 5 bits of each value and append them end to end
  return ( ((unsigned int)b & 0x1F ) << 10 | ((unsigned int)g & 0x1F) << 5 | (unsigned int)r & 0x1F);
/* ////////  LPD6803.h Looks like this: /////////////
  #if ARDUINO >= 100
  #include "Arduino.h"
  #else
  #include "WProgram.h"
  #endif
  class LPD6803 {
  private:
  uint8_t cpumax;
  public:
  LPD6803(uint16_t n, uint8_t dpin, uint8_t cpin);
  void begin();
  void show();
  void doSwapBuffersAsap(uint16_t idx);
  void setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b);
  void setPixelColor(uint16_t n, uint16_t c);
  void setCPUmax(uint8_t m);
  uint16_t numPixels(void);
If I un-comment the Serial.begin(). The LED strip will no longer output signal to the LPD6803 led strip I have.
Can anyone look over and see why there might be a conflict? The code is at bare minimum as shown. So not much is going on.
                        INCLUDE
I never thought I would find myself typing these words, but, what the heck, here goes - Way too much comment.
Yes, I know. It just happens to be my way to divide things up so that I can glance quickly for sections. Yes I do use tabs. One my my projects, which involves RS232, Ethernet, PHP, SdCard, Analog sensors, and button inputs, I found using this format makes it easy for me to find different areas of code when I am quick scrolling.
Great - I'm glad it's working for you.
For me, it's noise.
Back to the original question at hand. What where might there be a conflict with the Serial, vs what the Pixel Color (by way of LPD6803.h) be?
No comment version:
  strip.begin();
  strip.show();
  //strip.show();
  #if ARDUINO >= 100
  #else
  #endif
  class LPD6803 {
  private:
  uint8_t cpumax;
  public:
  void begin();
  void show();
