adding several libraries
I tried to add several libraries but after adding two the third one was not accepted I tried so hard it it didnt work even though the library is commonly known (utft) I'm
Hi. Is this one the library you are trying to import? UTFT - Rinky-Dink Electronics
In this case the problem seems to be that the archive is too large (the limit is 1MB). Try removing the Documentation and the unnecessary files.
We will make sure that whenever something like that happens the reason will be clear.
Thanks for your time.
