Adding Startup Message To Code
hi there I’m quite new to arduino an I was wondering if anyone could help, I have a code for a bike speedometer which uses a 16x2 LCD display, I wanted to add a startup message so when the device is turned on it would say “Henrys Bike” for 10 seconds and then run the code.
would anyone be able to modify the code for me?
Thanks for your time :slight_smile:
#include <LiquidCrystal.h>
LiquidCrystal lcd(13,12,11,10,9,8);
#define reed A0//pin connected to read switch
//storage variables
float radius = 13.5;// tire radius (in inches)- CHANGE THIS FOR YOUR OWN BIKE
int buttonInt=0;
int mode1=1;
int mode2=2;
int mode3=3;
volatile int selectedmode=mode1;
volatile int nselectedmode1=mode2;
volatile int nselectedmode2=mode3;
int reedVal;
long timer = 0;
float mph = 0.00;
float distance=0.00;
float circumference;
boolean backlight;
int maxReedCounter = 100;
int reedCounter;
void setup(){
  reedCounter = maxReedCounter;
  circumference = 2*3.14*radius;
  pinMode(1,OUTPUT);
  pinMode(2,INPUT);
  pinMode(reed, INPUT);
  lcd.begin(16,2);
  attachInterrupt(buttonInt,swap,RISING);
  Serial.write(12);
  cli();
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
  OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
  TCCR1B |= (1 << WGM12);
  TCCR1B |= (1 << CS11);
  TIMSK1 |= (1 << OCIE1A);
  sei();//allow interrupts
  //END TIMER SETUP
void swap()
  if(selectedmode==mode1)
  selectedmode=mode2;
  nselectedmode1=mode3;
  nselectedmode2=mode1;
  else if(selectedmode==mode2)
  selectedmode=mode3;
  nselectedmode1=mode1;
  nselectedmode2=mode2;
  selectedmode=mode1;
ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
  reedVal = digitalRead(reed);//get val of A0
  if (reedVal){//if reed switch is closed
    if (reedCounter == 0){//min time between pulses has passed
      mph = (56.8*float(circumference))/float(timer);//calculate miles per hour
      timer = 0;//reset timer
      reedCounter = maxReedCounter;//reset reedCounter
    else{
      if (reedCounter > 0){//don't let reedCounter go negative
        reedCounter -= 1;//decrement reedCounter
  else{//if reed switch is open
  if (timer > 2000){
    mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
  else{
    timer += 1;//increment timer
 if(digitalRead(2)==LOW)
 distance +=mph;
 {distance=0;
void displayMPH(){
  Serial.write(12);//clear
  Serial.write("Speed =");
  Serial.write(13);//start a new line
  Serial.println(mph);
  Serial.write(" MPH ");
  //Serial.write("0.00 MPH ");
void loop(){
  //print mph once a second
  displayMPH();
  lcd.setCursor(0,0);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,0);
  lcd.print("Speed=");
  lcd.setCursor(6,0);
  lcd.print(mph);
  lcd.setCursor(0,1);
  lcd.print("Distance=");
  lcd.setCursor(10,1);
  lcd.print(distance/3600000);
  float check1=20;
  float distA=distance/3600000;
  float percent=distA/check1;
  float percent1 =percent*100;
  lcd.setCursor(0,0);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,0);
  lcd.print("Cover ");
  lcd.setCursor(6,0);
  lcd.print(check1);
  lcd.setCursor(9,0);
  lcd.print("miles");
  if(distA<check1)
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("% complete=");
  lcd.setCursor(12,1);
  lcd.print(percent1);
  lcd.setCursor(0,0);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,0);
  lcd.print("Congratulations");
  lcd.setCursor(0,1);
  lcd.print("You pass");
  lcd.setCursor(0,0);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,0);
  lcd.print("Cover 30mph");
  if(mph<30)
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("speed=");
  lcd.setCursor(6,1);
  lcd.print(mph);
  lcd.setCursor(0,0);
  lcd.print("                ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("Light Rider");
speedometer.ino (4.48 KB)
You are able to do that yourself.
Put the code in "void setup ()". Do so after the initialisation of the display, and use delay (10000) to have it pause for 10 seconds.
What's up with all these empty lines ?
