Hello All
I am new to Ubuntu, I would like to add pgmspace.h library as shown in the following link
https://github.com/mikalhart/galileo-Pgmspace.h
Ubuntu is not allowing me to add files directly by dragging files to respective location. any help through command or terminal mode.
I am forced to use Ubuntu because I tried to install Arduino IDE latest version in WIndows 7, the program disappears after several clicks.
Atleast Ubuntu does have the problem.
Kind help pls.
Durai
India
durai_ALD:
Do you have the latest version of Java?
And to add library, I guess the Linux version also has the Add .ZIP library function under Sketch -> include Library. This should work.
Thanks for your reply, the pgmspace need to be added as it given in the github link, which is mandatory to run LED matrix, I need a kind help in doing so
Then click on download zip op the GitHub and use the add .Zip Library in Arduino
It is a third party hardware library, it needs to be added in specific location
C:/...arduino/hardware/arduino/x86/cores/arduino/avr/pgmspace.h.
In general, I have experience in adding LedControl.h and Matrix.h library using Sketch -> include Library.
But this is specific to particular hardware folder, I had already downloaded the pgmspace.zip files, ubuntu is not allowing me to add the file to particular location. Permission restricted
Thanks for reply, pls expand the command so that I will try
In a terminal window
sudo cp /full/path/to/file/now.h /full/path/to/Arduino/location/
