//This is the loop part
if (alarmActivated == true){
currentDistance = getDistance() + 10;
if ( currentDistance < initialDistance) {
tone(buzzer,1000);
lcd.clear();
enterPassword();
// function for calling and checking pass
void enterPassword() {
int k=5;
tempPassword = "";
activated = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" *** ALARM *** ");
lcd.setCursor(0,1);
lcd.print("Pass>");
while(activated) {
keypressed = myKeypad.getKey();
if (keypressed != NO_KEY){
if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
keypressed == '8' || keypressed == '9' ) {
tempPassword += keypressed;
lcd.setCursor(k,1);
lcd.print("*");
k++;
if (k > 9 || keypressed == '#') {
tempPassword = "";
k=5;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
if ( keypressed == '*') {
if ( tempPassword == password ) {
activated = false;
alarmActivated = false;
noTone(buzzer);
screenOffMsg = 0;
else if (tempPassword != password) {
lcd.setCursor(0,1);
lcd.print("Wrong! Try Again");
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
tone(buzzer,1000);
lcd.clear();
enterPassword();
int k=5;
tempPassword = "";
activated = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
while(activated) {
lcd.setCursor(k,1);
lcd.print("*");
k++;
tempPassword = "";
k=5;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
activated = false;
noTone(buzzer);
screenOffMsg = 0;
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
Please provide full code, not snippets.
To post code properly, use the edit → copy for forum in the IDE and paste it here. There are other ways but this will be the easiest.
I’ve merged your cross-posts @aayugs .
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the “community guidelines.”. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
#include <LiquidCrystal.h> // includes the LiquidCrystal Library
#include <Keypad.h>
#define buzzer 8
#define trigPin 9
#define echoPin 10
long duration;
int distance, initialDistance, currentDistance, i;
int screenOffMsg =0;
String password=“1234”;
String tempPassword;
boolean activated = false; // State of the alarm
boolean isActivated;
boolean activateAlarm = false;
boolean alarmActivated = false;
boolean enteredPassword; // State of the entered password to stop the alarm
boolean passChangeMode = false;
boolean passChanged = false;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keypressed;
//define the cymbols on the buttons of the keypads
char keyMap[ROWS][COLS] = {
{‘1’,‘2’,‘3’,‘A’},
{‘4’,‘5’,‘6’,‘B’},
{‘7’,‘8’,‘9’,‘C’},
{’*’,‘0’,’#’,‘D’}
byte rowPins[ROWS] = {14, 15, 16, 17}; //Row pinouts of the keypad
byte colPins[COLS] = {18, 19, 20, 21}; //Column pinouts of the keypad
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, ROWS, COLS);
LiquidCrystal lcd(1, 2, 4, 5, 6, 7); // Creates an LC object. Parameters: (rs, enable, d4, d5, d6, d7)
lcd.begin(16,2);
pinMode(buzzer, OUTPUT); // Set buzzer as an output
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
if (activateAlarm) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Alarm will be”);
lcd.setCursor(0,1);
lcd.print(“activated in”);
int countdown = 9; // 9 seconds count down before activating the alarm
while (countdown != 0) {
lcd.setCursor(13,1);
lcd.print(countdown);
countdown--;
tone(buzzer, 700, 100);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Alarm Activated!");
initialDistance = getDistance();
alarmActivated = true;
tone(buzzer, 1000); // Send 1KHz sound signal
lcd.clear();
enterPassword();
if (!alarmActivated) {
if (screenOffMsg == 0 ){
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“A - Activate”);
lcd.setCursor(0,1);
lcd.print(“B - Change Pass”);
screenOffMsg = 1;
if (keypressed ==‘A’){ //If A is pressed, activate the alarm
tone(buzzer, 1000, 200);
activateAlarm = true;
else if (keypressed ==‘B’) {
lcd.clear();
int i=1;
tone(buzzer, 2000, 100);
tempPassword = “”;
lcd.setCursor(0,0);
lcd.print(“Current Password”);
lcd.setCursor(0,1);
lcd.print(">");
passChangeMode = true;
passChanged = true;
while(passChanged) {
if (keypressed == ‘0’ || keypressed == ‘1’ || keypressed == ‘2’ || keypressed == ‘3’ ||
keypressed == ‘4’ || keypressed == ‘5’ || keypressed == ‘6’ || keypressed == ‘7’ ||
keypressed == ‘8’ || keypressed == ‘9’ ) {
lcd.setCursor(i,1);
lcd.print("");
i++;
if (i > 5 || keypressed == ‘#’) {
tempPassword = “”;
i=1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">");
if ( keypressed == '’) {
i=1;
if (password == tempPassword) {
tempPassword="";
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Set New Password”);
lcd.setCursor(0,1);
lcd.print(">");
while(passChangeMode) {
lcd.setCursor(i,1);
lcd.print("");
i++;
tempPassword = “”;
i=1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">");
i=1;
password = tempPassword;
screenOffMsg = 0;
int k=5;
tempPassword = “”;
activated = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" *** ALARM *** “);
lcd.setCursor(0,1);
lcd.print(“Pass>”);
while(activated) {
lcd.setCursor(k,1);
lcd.print(”");
k++;
if (k > 9 || keypressed == ‘#’) {
tempPassword = “”;
k=5;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(“Pass>”);
activated = false;
noTone(buzzer);
screenOffMsg = 0;
lcd.setCursor(0,1);
lcd.print(“Wrong! Try Again”);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(“Pass>”);
// Custom function for the Ultrasonic sensor
long getDistance(){
//int i=10;
//while( i<=10 ) {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration*0.034/2;
//sumDistance += distance;
//int averageDistance= sumDistance/10;
return distance;
Sorry for the mistake.
See How to write Timers and Delays in Arduino
and re-write your sketch as a series of tasks as detailed in my tutorial
Multi-tasking in Arduino
I came across it while reaching for a solution, the issue is when the enterPassword() function is called it blocks everything else unless the password is entered. So no other command can be switched with it.
