Adding timer with LCD display
Hello I have been making a coin operated machine where a user has to insert a coins into the machine in order to enable a relay and a timer, eventually the relay will stop after the timer goes down and each coins inserted is equivalent to 1 minute time
But I notice when I insert too many coins the timer goes off and add seconds to the timer, it shouldn’t have seconds for the timer only adds up minutes, 1 minute + 1 minute = 2 minutes (2:00) but why does it have seconds? (2:05)
How can I prevent this? is there some part of the code can I fix?
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h> //i2c pins
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))    //clear bit in byte at sfr adress
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))     //set bit in byte at sfr adress
#define seconds() (millis()/1000)  //capture secods
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//pins to use
const int coinPin = 2;
const int button1 = 8, button2 = A0, button3 = 3;
const int relay1 = 10, relay2 = 11, relay3 = 12;
const int button1pushed = 0b00110000;
const int button2pushed = 0b00101000;
const int button3pushed = 0b00011000;
//variables used in the Interrupt Service Routine (ISR) need to be 'volatile'
volatile long unsigned eventTime;
volatile long unsigned previousEventTime;
volatile long unsigned timeSinceLastEvent;
volatile byte portDstatus;
volatile byte eventFlag0, eventFlag1, eventFlag2, eventFlag3;
//additonal variables
long timeSpent = 0, startTime = 0, coinTimeVal = 10000;
long timeLeft = 0;
int event, pulse = 0;
bool event1running = false, event2running = false, event3running =false;
void setup(){
  Serial.begin(9600);//start serial communication
  //define the pins:
  pinMode(button1, INPUT);//define pin as INPUT
  digitalWrite(button1, HIGH);//connect the internal pull-up resistor - this will yield a HIGH readout if the switch is open.
  pinMode(button2, INPUT);
  digitalWrite(button2, HIGH);
  pinMode(button3, INPUT);
  digitalWrite(button3, HIGH);
  pinMode(relay1, OUTPUT);
  digitalWrite(relay1, HIGH);
  pinMode(relay2, OUTPUT);
  digitalWrite(relay2, HIGH);
  pinMode(relay3, OUTPUT);
  digitalWrite(relay3, HIGH);
  //setting up the interrupt: (see chapter 12 in the ATmega328p data sheet for an explanation which register does what etc...)
  cli();
  PCICR |= 0b00000011;    // turn on all ports
  PCMSK0 |= 0b00000001;    // turn on pin PB0, which is PCINT0, pin 8
  PCMSK1 |= 0b00000001;    // turn on pin PC4, which is PCINT12, pin A0
  //PCMSK2 |= 0b00010000;    // turn on pin 4
  sei();
  attachInterrupt(digitalPinToInterrupt(button3), button3event, RISING);
  //lcd init
  lcd.begin(16, 2);
  //coin slot machine
  attachInterrupt(digitalPinToInterrupt(coinPin), coinInterrupt, RISING);
//  if (eventFlag0 == 1){ //&& (eventTime-previousEventTime<100)){
//      previousEventTime=eventTime;
//      pulse += 1;
//      eventFlag0 = 0;
//      if (not(pulse % 6)){
//        timeLeft += coinTimeVal;
//        pulse = 0;
  if (timeLeft <= 0){
    if (timeLeft < 0){timeLeft=0;}
    welcomeInsertCoinMessage();
    if (event1running){
      switchRelay(relay1, event1running);
      event1running = !event1running;
    else if (event2running){
      switchRelay(relay2, event2running);
      event2running = !event2running;
    else if (event3running){
      switchRelay(relay3, event3running);
      event3running = !event3running;
  else {
    printTime(timeLeft);
    Serial.println(int(timeLeft/1000));
    if (eventFlag1 == 1 && (eventTime-previousEventTime>100)){
      previousEventTime=eventTime;//note the present event time as last time for the next event
      Serial.println(event1running);
      if (event1running){
        startTime = millis();
        printStatus("Wash...");
      }else{
        printStatus("Washing paused");
      eventFlag1 = 0;//reset the event flag for the next event
    else if (eventFlag2 == 1 && (eventTime-previousEventTime>100)){
      if (event2running){
        printStatus("Soap...");
      }else{
        printStatus("Soap paused");
      eventFlag2 = 0;//reset the event flag for the next event
    else if (eventFlag3 == 1 && (eventTime-previousEventTime>100)){
      if (event3running){
        printStatus("Dry...");
      }else{
        printStatus("Dry paused");
      eventFlag3 = 0;//reset the event flag for the next event
    if (event1running || event2running || event3running){
      //Serial.println("running...");
      timeLeft -= (millis() - startTime);
  }delay(100);
ISR (PCINT0_vect){
  eventTime=millis();//note the time of the ISR call
  eventFlag1=1;//set the event flag that tells the main loop that a button was pressed.
ISR (PCINT1_vect){
  eventFlag2=1;//set the event flag that tells the main loop that a button was pressed.
//ISR (PCINT3_vect){
//  eventTime=millis();//note the time of the ISR call
//  eventFlag3=1;//set the event flag that tells the main loop that a button was pressed.
void button3event(){
void coinInterrupt(){
//  eventFlag0 = 1;
void welcomeInsertCoinMessage(){
    lcd.clear();
    lcd.setCursor(4, 0); //Start at character 4 on line 0
    lcd.print("WELCOME!");
    lcd.setCursor(0, 1);
    lcd.print(" ->Insert Coin<-");
void printTime(long timer){
    long mins, secs, real_sec;
    String t;
    //lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("               ");
    real_sec = timer/1000;
    //mins =(long)(timer/(60*1000));
    mins = real_sec/60;
    secs = real_sec%60;
    Serial.println(secs, mins);
    if (mins > 9 and secs >9){
      t = String("Time  ") + String(mins) + String(":") + String(secs);
    }else if (mins > 9 and secs < 10){
    }else if (mins < 10 and secs > 9){
      t = String("Time  ") + String("0") + String(mins) + String(":") + String(secs);
    }else{
      t = String("Time  ") + String("0") + String(mins) + String(":") + String("0") + String(secs);
    lcd.print(t);
//    delay(100);
//    lcd.setCursor(0, 1);
//    lcd.print(statusAction);
void printStatus(String s){
  lcd.print("               ");
  lcd.print(s);
void switchRelay(int relaynum, bool onOff){
  digitalWrite(relaynum, onOff);
If you must use pin change interrupts for reading buttons and switches, it is better to use a standard function to set them such as void pciSetup(byte pin) in the example here: Arduino Playground - PinChangeInterrupt . It is then a bit clearer what you are doing without referring to the data sheet.
You are doing some things which can give erratic results, for example setting a 4 byte variable in an interrupt service routine, then reading it in the loop() without taking any measures to prevent the ISR changing its value concurrently with a read attempt.
This may not be your main problem, though.
Hi I am a beginner at Arduino and got this code from YouTube, can you tell me which part of the code I can experiment to remove unnecessary seconds in timer?
  1. Can you post a link to the Youtube video and a link to the source of the program.
  2. Check the comments in the video (if not in English) to see if people have complained about the same problem.
  3. You've said this: "But I notice when I insert too many coins the timer goes off and add seconds to the timer" . How many coins is too many ?
  4. Can you duplicate the error and copy the messages from the serial console into this thread.
  5. I think you may have misunderstood the intended behaviour of the system. Adding coins updates an indicator of the time left only. If the there is a gap in seconds between entering coins, the amount of time left will not go up in units of exact minutes.
