adding to the library
Hi, I have downloaded' IR Lib2 -master zip' which is supposed to contain an infra red example. I selected sketch>include library>add zip library and selected the zip file I downloaded. Got the answer the file does not contain a valid library.
I used a link I found on the arduino web site to get the IR Lib2 file.
Can somebody please give me a link to a valid library for infra red examples. thanks.
Look for the library by Ken Shiriff; should be in library manager.
Here it is, in a file you can use with the add library from ZIP method
missdrew:
Did you forget an attachment?
Hi Missdrew, You forgot the attachment as somebody pointed out.
IDE menu Sketch -> Include Library -> Manage Libraries
In the popup window, filter irremote. You will find irremote by shirriff, z3t0, arminjo.
Click it and an install button will appear. Click the install button.
