// A
int yellowPin = PB14;
int analogPin = PA6;
pinMode(yellowPin, OUTPUT);
int val = analogRead(analogPin);
int mapVal = map(val, 2000, 2500, 0, 3);
switch(mapVal)
case 0:
setLights(LOW, LOW, HIGH);
case 1: setLights(LOW, HIGH, LOW);
case 2: setLights(HIGH, LOW, LOW);
void setLights(int red, int yellow, int green)
digitalWrite(yellowPin, yellow);
B
// Moving Average Example
// Shows how to use an FIR filter as a moving average on a simple
// set of data that can be easily verified by hand.
#include <FIR.h> // you may need to install FIR Filter Arduino Library
to have it
// Make an instance of the FIR filter. In this example we’ll use
// floating point values and an 8 element filter. For a moving average
// that means an 8 point moving average.
FIR<float, 8> fir;
Serial.begin(115200); // Start a serial port
// For a moving average we want all of the coefficients to be unity.
float coef[8] = { 1., 1., 1., 1., 1., 1., 1., 1.};
// Set the coefficients
fir.setFilterCoeffs(coef);
Serial.print("Gain set: ");
Serial.println(fir.getGain());
// Calculate the moving average for a time series with the elements.
// 0, 1, 2, …, 13, 14, 15
for (float i=0; i < 16; i++) {
Serial.println(fir.processReading(i));
while (true) {}; // Spin forever
// LED pulses program
int yellowPin = PB14; // pulses otput
int analogPin = PA6; // signal input
int mapVal = map(val, 2300, 2500, 0, 3);
switch(mapVal)
case 0:
