Adding two unsigned long long variables on arduino due
Hello, i am quite new to arduino programming and i am using IDE 1.8.10 on a Windows 10 computer with an ArduinoDue (64 bits). The Proglem is: I cant add two unsigned long long variables!
My Program:
unsigned long long F_OUT = 100000000 ;
int Counter = 0 ;
int i;
unsigned long long FrequencyCorrection = F_OUT;
if (Counter == 0 ) {
for (i=1; i<=32; i++) {
FrequencyCorrection = F_OUT / 1000000 * 8;
unsigned long long F_OUT_CORRECTED = F_OUT + FrequencyCorrection;
Serial.print((float)F_OUT); //Conversion to float, because Serial.print() cant print out unsigned long long...
Serial.print(" + ");
Serial.print((float)FrequencyCorrection);
Serial.print(" = ");
Serial.println((float)F_OUT_CORRECTED);
F_OUT += 100000000;
delay(3000);
Counter++;
The results, monitored over te serial Interface, things get a bit funny @ F_OUT=700000000.00: 700000000.00 + 5600.00 = 700005632.00
All Results, printed over the serial Interface:
100000000.00 + 800.00 = 100000800.00
200000000.00 + 1600.00 = 200001600.00
300000000.00 + 2400.00 = 300002400.00
400000000.00 + 3200.00 = 400003200.00
500000000.00 + 4000.00 = 500004000.00
600000000.00 + 4800.00 = 600004800.00
800000000.00 + 6400.00 = 800006400.00
900000000.00 + 7200.00 = 900007168.00
1000000000.00 + 8000.00 = 1000008000.00
1100000000.00 + 8800.00 = 1100008832.00
1200000000.00 + 9600.00 = 1200009600.00
1300000000.00 + 10400.00 = 1300010368.00
1400000000.00 + 11200.00 = 1400011264.00
1500000000.00 + 12000.00 = 1500012032.00
1600000000.00 + 12800.00 = 1600012800.00
1700000000.00 + 13600.00 = 1700013568.00
1800000000.00 + 14400.00 = 1800014336.00
1900000000.00 + 15200.00 = 1900015232.00
2000000000.00 + 16000.00 = 2000016000.00
2100000000.00 + 16800.00 = 2100016768.00
2200000000.00 + 17600.00 = 2200017664.00
2300000000.00 + 18400.00 = 2300018432.00
2400000000.00 + 19200.00 = 2400019200.00
2500000000.00 + 20000.00 = 2500019968.00
2600000000.00 + 20800.00 = 2600020736.00
2700000000.00 + 21600.00 = 2700021504.00
2800000000.00 + 22400.00 = 2800022528.00
2900000000.00 + 23200.00 = 2900023296.00
3000000000.00 + 24000.00 = 3000024064.00
3100000000.00 + 24800.00 = 3100024832.00
3200000000.00 + 25600.00 = 3200025600.00
Does anybody now a solution to this Problem, iam quite confused, obviouslyi cant add two simple unsigned long long variables...
This is only a simple sketch i made show my problems
With best regards
Werner Pichl
You only get about 6 digits of precision in a float.
EDIT (because I just remembered) - On the due you can use double (8-byte floating point type).
Nick Gammon's Big Number library may provide an answer, to the cost or more memory usage and slower calculation.
Thank you!
This seems to work for me!
I exchanged all variables to double!:
double F_OUT = 100000000 ;
int Counter = 0 ;
int i;
double FrequencyCorrection = F_OUT;
double F_OUT_CORRECTED = F_OUT + FrequencyCorrection;
Serial.print((double)F_OUT); //Conversion to float, because Serial.print() cant print out unsigned long long...
Serial.print((double)FrequencyCorrection);
Serial.println((double)F_OUT_CORRECTED);
F_OUT += 100000000;
delay(3000);
Counter++;
Output now as desired:
700000000.00 + 5600.00 = 700005600.00
900000000.00 + 7200.00 = 900007200.00
1100000000.00 + 8800.00 = 1100008800.00
1300000000.00 + 10400.00 = 1300010400.00
1400000000.00 + 11200.00 = 1400011200.00
1500000000.00 + 12000.00 = 1500012000.00
1700000000.00 + 13600.00 = 1700013600.00
1800000000.00 + 14400.00 = 1800014400.00
1900000000.00 + 15200.00 = 1900015200.00
2100000000.00 + 16800.00 = 2100016800.00
2200000000.00 + 17600.00 = 2200017600.00
2300000000.00 + 18400.00 = 2300018400.00
2500000000.00 + 20000.00 = 2500020000.00
2600000000.00 + 20800.00 = 2600020800.00
2700000000.00 + 21600.00 = 2700021600.00
2800000000.00 + 22400.00 = 2800022400.00
2900000000.00 + 23200.00 = 2900023200.00
3000000000.00 + 24000.00 = 3000024000.00
3100000000.00 + 24800.00 = 3100024800.00
OE7WPA:
Thank you!
Glad you're working. But I meant for you to just use double to get around the problem with Serial.print, like this:
int Counter = 0 ;
int i;
    Serial.print((float)F_OUT); //Conversion to double, because Serial.print() cant print out unsigned long long...
    F_OUT += 100000000;
    delay(3000);
  Counter++;
using double instead of unsigned long long solved the problem for me, now my program is working as it should...
Working on a programmable Synthesizer that outputs 20 to 3200 MHz with programmable amplitude and frequency. The PLL in this Project puts out Frequencies that are 6-8 ppm off the desired Frequencies, so i had to implement some sort of correction at certain frequencies!
Thanks again, it is now working like a charm!!
With best regards
Werner
