Use the </> button on the menu, it opens a box
that you then paste your code into.
hanica:
, I know that line is incorrect , might be helpful if you Identified the problem ?
. int ampreq = A3;
hanica:
Yes that would be Ideal.
I need the code written with the correct syntax so I can fill in my pins etc .
This is a simple 'for' loop. Study it, make an attempt and someone will be glad to help.
how about this:
int ar = A1; //amps read analog read(acs 712 sensor)
int ampreq = A3; //amps required read pot(0-1024)
int j;// for amplevel calcs
int actamp; //actual amps=mapped value
int ms = 2; // motor step
int md = 3; // motor direction
pinMode(ar, INPUT); //amps read analog read(acs 712 sensor)
pinMode(ampreq, INPUT); //amps required read pot
analogRead(ar); //acs715 (A1)
analogRead(ampreq); //required amps pot(A3)
for (int j = 0; j < 10; i++)
Sum = Sum + ar; //Sum for averaging
actamp = (Sum/10);
if (actamp>=ampreq) //then compare actamp with ampreq
for (j = 0; j <= 200; j++)
{ digitalWrite(md, LOW); //rapid up
digitalWrite (ms, HIGH);
delayMicroseconds (200);
digitalWrite (ms, LOW);
for (j = 175; j >= 0; j--) //return distance
{ digitalWrite(md, HIGH); //rapid up
ar is a pin number
Reads the analogue pin and throws away the answer
Sum will be 10 times the pin number, or it would be if Sum were declared and defined as zero. Is that what you want ?
Declare Sum and set its value to zero. Read the input 10 times and add each reading to Sum then divide Sum by 10 to get the average
cheers Bob,
how do I add each reading to sum?
is it:
int sum; // declared place for added readings
[color=#000000][color=#222222]for (int j = 0; j < 10; i++)[/color][/color]
[color=#000000]{[/color]
[color=#000000]sum=[color=#222222]analogRead(ar)+sum[/color][/color]
[color=#000000][color=#222222]actamp = (Sum/10);[/color][/color]
analogRead(ampreq);
if (actamp>=ampreq) Again, the same problem
actamp is used in an earlier part of the code :
actamp = map( analogRead(ar), 513, 1024, 0, 1024); // mapped amps value(51 points per amp - 8= 408)
//because the + amps start at 2.5v out of the acs712 which is actually an ac device
...and ampreq has the value ..?
These two lines read analog values and throw them away. They are a waste of time:
Here you are comparing your average to a pin value:
if (actamp>=ampreq)
sum = sum + reading;
"Here you are comparing your average to a pin value:"
yes the analogread of A3
No. You have thrown the reading away - there is no assignment of the return value of analogRead to a variable.
All you did was waste 100 us or so
hanica:
analogRead(ampreq); //required amps pot(A3)"Here you are comparing your average to a pin value:"
Nope. You are actually comparing to the pin number not the analog value.
