adding variables in a loop for the naalog
Hi! I created a simple alarm system using arduino board and it’s working perfectly. however, our professor asked me to upgrade it by adding 2 lasers and 2 LDR. the LDR is connected on the A0 analog. my problem is, can I add another variable to the loop for the input of the LDR in the analog?
const int triggeredLED = 7;
const int triggeredLED2 = 8;
const int RedLED = 4;
const int GreenLED = 5;
const int inputPin = A0; //this is the variable for the LDR which receives the laser light
const int speakerPin = 12;
const int armButton = 6;
boolean isArmed = true;
boolean isTriggered = false;
int buttonVal = 0;
int prev_buttonVal = 0;
int reading = 0;
int threshold = 0;
const int lowrange = 2000;
const int highrange = 4000;
void setup(){
pinMode(triggeredLED, OUTPUT);
pinMode(triggeredLED2, OUTPUT);
pinMode(RedLED, OUTPUT);
pinMode(GreenLED, OUTPUT);
pinMode(armButton, INPUT);
digitalWrite(triggeredLED, HIGH);
digitalWrite(triggeredLED, LOW);
calibrate();
setArmedState();
void loop(){
reading = analogRead(inputPin);
int buttonVal = digitalRead(armButton);
if ((buttonVal == HIGH) && (prev_buttonVal == LOW)){
setArmedState();
if ((isArmed) && (reading < threshold)){
isTriggered = true;}
if (isTriggered){
for (int i = lowrange; i <= highrange; i++)
tone (speakerPin, i, 250);
for (int i = highrange; i >= lowrange; i–)
delay(50);
delay (50);
digitalWrite(triggeredLED2, HIGH);
delay (50);
digitalWrite(triggeredLED2, LOW);
delay (50);
delay(20);
void setArmedState(){
if (isArmed){
digitalWrite(GreenLED, HIGH);
digitalWrite(RedLED, LOW);
isArmed = false;
digitalWrite(GreenLED, LOW);
digitalWrite(RedLED, HIGH);
tone(speakerPin, 220, 125);
delay(200);
tone(speakerPin, 196, 250);
isArmed = true;
void calibrate(){
int sample = 0;
int baseline = 0;
const int min_diff = 200;
const int sensitivity = 50;
int success_count = 0;
for (int i=0; i<10; i++){
sample += analogRead(inputPin);
delay (50);
delay (50);
do
sample = analogRead(inputPin);
if (sample > baseline + min_diff){
success_count++;
threshold += sample;
delay (100);
delay (100);
success_count = 0;
threshold = 0;
} while (success_count < 3);
threshold = (threshold/3) - sensitivity;
delay(200);
int reading = 0;
You already have, so what is your actual problem ?
Your code is not easy to understand because the variable names and comments never mention any lasers anywhere! But if you just want to add a second LDR then connect it to pin A1 (call it LDR2pin) then you can have
  int reading2 = 0;
  reading2 = analogRead(LDR2pin);
Then you can do what you like with the readings.
If you meant something else try asking the question again a bit more clearly.
Steve
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Does your laser just output a HIGH and LOW signal?
If so you can configure the analog input pins as digital input pins.
Tom.. :slight_smile:
