Additional Analog Pins on Huzzah Esp8266
Is there any means i can give my huzzah esp8266 additional analog pins. im trying to connect my analog accelerometer to it which requires 3 analog pins.
8 channel I2C ADC
http://www.linear.com/product/LTC2309
There are also many modules available. Google "8 channel I2C ADC"
groundfungus: 8 channel I2C ADC
is the Huzzah 3.3 v ? make sure your ADC chip runs on the same voltage. I think almost all do, but check the data sheets.
there are a few boards you can get with the chips already installed. google and use Arduino in the search...
arduino 8 channel adc arduino shoelace.. whatever.
i have a pro trinket 5v which i can use to connect to, but the resistors are my problem. i have seen online someone using 10k resistors and another one using 1k and 2k resistors. i have tried both but no avail, if anyone could lend a hand it will be much appreciated
alif: i have a pro trinket 5v which i can use to connect to, but the resistors are my problem. i have seen online someone using 10k resistors and another one using 1k and 2k resistors. i have tried both but no avail, if anyone could lend a hand it will be much appreciated
please expound on your post. why are you using resistors ? why are you using a trinket when you said Huzzah ?
a simple schematic would help.
i am trying to connect the accelerometer (adxl335) to the pro trinket then pro trinket to the huzzah esp8266. Due to the lack of analog pins on the huzzah esp8266
