In the tab “Documents and Drivers” is the datasheet.
Open the datasheet, and go to page 37. The left one is the top-view. With the vent hole at the bottom, the pin 5, SDO, is the lower left pin.
The right one in your photo has also the vent hole at the bottom.
As you can see the pin 5 is going to the middle one of the three copper pads.
The middle one is connected to the left copper pad.
Scratch the connection between the middle and the left copper pad to disconnect those.
Use a sharp knife and don’t be afraid to scratch into the board. I think it is not a multiplayer pcb board, so a deep scratch won’t damage something.
Add a solder blob between the middle and the right one.
Inside the red circle is a copper trace that connects the middle pad to the left pad, remove that by scratching it with a sharp knife. The green circle is where the solder blob should come.
