Address inputs from two cascaded 74HC615 Shift Registers
Dear all,
I am trying to use two cascaded 74HC615 Shift Registers to obtain 16 digital inputs, I am using a code I found on the internet and it works but what I want is to process the data incoming from the shift registers. for example when input on bit 14 of the cascaded shift registers is HIGH then an LED on pin 13 will turn on.
This is the code I am using (and unfortunately don't know how to adjust!)
 * SN74HC165N_shift_reg
 * Program to shift in the bit values from a SN74HC165N 8-bit
 * parallel-in/serial-out shift register.
 * This sketch demonstrates reading in 16 digital states from a
 * pair of daisy-chained SN74HC165N shift registers while using
 * only 4 digital pins on the Arduino.
 * You can daisy-chain these chips by connecting the serial-out
 * (Q7 pin) on one shift register to the serial-in (Ds pin) of
 * the other.
 * Of course you can daisy chain as many as you like while still
 * using only 4 Arduino pins (though you would have to process
 * them 4 at a time into separate unsigned long variables).
/* How many shift register chips are daisy-chained.
#define NUMBER_OF_SHIFT_CHIPS   2
/* Width of data (how many ext lines).
#define DATA_WIDTH   NUMBER_OF_SHIFT_CHIPS * 8
/* Width of pulse to trigger the shift register to read and latch.
#define PULSE_WIDTH_USEC   5
/* Optional delay between shift register reads.
#define POLL_DELAY_MSEC   400
/* You will need to change the "int" to "long" If the
 * NUMBER_OF_SHIFT_CHIPS is higher than 2.
#define BYTES_VAL_T unsigned int
int ploadPin        = 3;  // PL  "pin 1" the 165
int clockPin        = 5; //  CP  "pin 2" the 165
int dataPin         = 6; //  Q7 "pin 7" the 165, if connected to Q7 pin 9 only 8 bits will be read!
/* To cascade connect the second IC PL and CP pins to the PL and CP pins on
the main IC and connect Q7 "PIN 9 "of the main one to the DS "PIN-10" of the next IC */
BYTES_VAL_T pinValues;
BYTES_VAL_T oldPinValues;
/* This function is essentially a "shift-in" routine reading the
 * serial Data from the shift register chips and representing
 * the state of those pins in an unsigned integer (or long).
BYTES_VAL_T read_shift_regs()
    byte bitVal;
    BYTES_VAL_T bytesVal = 0;
    /* Trigger a parallel Load to latch the state of the data lines,
    digitalWrite(ploadPin, LOW);
    delayMicroseconds(PULSE_WIDTH_USEC);
    digitalWrite(ploadPin, HIGH);
    /* Loop to read each bit value from the serial out line
     * of the SN74HC165N.
    for(int i = 0; i < DATA_WIDTH; i++)
        bitVal = digitalRead(dataPin);
        /* Set the corresponding bit in bytesVal.
        bytesVal |= (bitVal << ((DATA_WIDTH-1) - i));
        /* Pulse the Clock (rising edge shifts the next bit).
        digitalWrite(clockPin, HIGH);
        digitalWrite(clockPin, LOW);
    return(bytesVal);
/* Dump the list of zones along with their current status.
void display_pin_values()
        if((pinValues >> i) & 1)
            Serial.print("1");
            Serial.print("0");
        Serial.print(",");
    /* Initialize our digital pins...
    pinMode(ploadPin, OUTPUT);
    pinMode(clockPin, OUTPUT);
    pinMode(dataPin, INPUT);
    /* Read in and display the pin states at startup.
    pinValues = read_shift_regs();
    display_pin_values();
    oldPinValues = pinValues;
    /* Read the state of all zones.
    /* If there was a chage in state, display which ones changed.
    if(pinValues != oldPinValues)
        Serial.print("*Pin value change detected*\r\n");
    delay(POLL_DELAY_MSEC);
This is an example of the output as 8 pins of one shift register is pulled-up and the other is pulled-down:
0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,
Welcome to the forum
    for (int i = 0; i < DATA_WIDTH; i++)
        bytesVal |= (bitVal << ((DATA_WIDTH - 1) - i));
This function returns an int variable that contains the data that has been read. You can test whether any of the bits that it is made up of is set to 0 or 1 by using the bitRead() function and act on the result
That function looks at each bit and prints a '0' or '1' which is basically what you are asking, except only for the 14th bit (when i == 14 [or maybe 13 if you count from 0])
