The code I started with was the alarmhandler.pde (Miles Burton ) I have pasted it below. I used the straight Burton code without my additions as they don't relate to this (I'm sure my additions will feature in another post asking for help soon
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
// function that will be called when an alarm condition exists during DallasTemperatures::processAlarms();
void newAlarmHandler(uint8_t* deviceAddress)
Serial.println("Alarm Handler Start");
printAlarmInfo(deviceAddress);
printTemp(deviceAddress);
Serial.println("Alarm Handler Finish");
void printCurrentTemp(DeviceAddress deviceAddress)
printAddress(deviceAddress);
void printAddress(DeviceAddress deviceAddress)
Serial.print("Address: ");
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress < 16) Serial.print("0");
_ Serial.print(deviceAddress*, HEX);_
_ }_
_ Serial.print(" ");_
_}_
void printTemp(DeviceAddress deviceAddress)
_{_
_ float tempC = sensors.getTempC(deviceAddress);_
if (tempC != DEVICE_DISCONNECTED)
_ {_
_ Serial.print("Current Temp C: ");
Serial.print(tempC);_
_ }_
_ else Serial.print("DEVICE DISCONNECTED");
Serial.print(" ");_
_}_
void printAlarmInfo(DeviceAddress deviceAddress)
_{_
_ char temp;_
_ printAddress(deviceAddress);_
_ temp = sensors.getHighAlarmTemp(deviceAddress);_
_ Serial.print("High Alarm: ");
Serial.print(temp, DEC);
Serial.print("C");
Serial.print(" Low Alarm: ");_
_ temp = sensors.getLowAlarmTemp(deviceAddress);_
_ Serial.print(temp, DEC);
Serial.print("C");
Serial.print(" ");_
_}_
void setup(void)
_{_
_ // start serial port*_
_ Serial.begin(9600);
Serial.println("Dallas Temperature IC Control Library Demo");_
* // Start up the library*
* sensors.begin();*
* // locate devices on the bus*
_ Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
* // search for devices on the bus and assign based on an index*
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
Serial.print("Device insideThermometer ");
* printAlarmInfo(insideThermometer);*
Serial.println();_
_ Serial.print("Device outsideThermometer ");
* printAlarmInfo(outsideThermometer);*
Serial.println();_
* // set alarm ranges*
_ Serial.println("Setting alarm temps...");_
* sensors.setHighAlarmTemp(insideThermometer, 26);*
* sensors.setLowAlarmTemp(insideThermometer, 22);*
* sensors.setHighAlarmTemp(outsideThermometer, 25);*
* sensors.setLowAlarmTemp(outsideThermometer, 21);*
_ Serial.print("New insideThermometer ");
Serial.println();_
_ Serial.print("New outsideThermometer ");
Serial.println();_
* // attach alarm handler*
* sensors.setAlarmHandler(&newAlarmHandler);*
void loop(void)
* // ask the devices to measure the temperature*
* sensors.requestTemperatures();*
* // if an alarm condition exists as a result of the most recent*
* // requestTemperatures() request, it exists until the next time*
* // requestTemperatures() is called AND there isn't an alarm condition*
* // on the device*
* if (sensors.hasAlarm())*
_ Serial.println("Oh noes! There is at least one alarm on the bus.");_
* // call alarm handler function defined by sensors.setAlarmHandler*
* // for each device reporting an alarm*
* sensors.processAlarms();*
* if (!sensors.hasAlarm())*
* // just print out the current temperature*
* printCurrentTemp(insideThermometer);*
* printCurrentTemp(outsideThermometer);*
* delay(1000);*
[/quote]
