I was testing the ADE9153A shield ( EV-ADE9153ASHIELDZ ) with Arduino UNO and i keep getting this message
" ADE9153A Shield not detected. Plug in Shield and reset the Arduino "
==> I tried different possible CS pins and SPI speeds and the communication still fails .
This is the link for the EV-ADE9153ASHIELDZ user guide :
The sketch i have been using :
#define ARM_MATH_CM0PLUS
#include <SPI.h>
#include <ADE9153A.h>
#include <ADE9153AAPI.h>/* Basic initializations */
#define SPI_SPEED 1000000 //SPI Speed
#define CS_PIN 8 //8-->Arduino Zero. 15-->ESP8266
// Different alternatives for pin 8 also don't work
#define ADE9153A_RESET_PIN 4 //On-board Reset Pin
#define USER_INPUT 5 //On-board User Input Button Pin
#define LED 6 //On-board LED pin
ADE9153AClass ade9153A;struct EnergyRegs energyVals; //Energy register values are read and stored in EnergyRegs structure
struct PowerRegs powerVals; //Metrology data can be accessed from these structures
struct RMSRegs rmsVals;
struct PQRegs pqVals;
struct AcalRegs acalVals;
struct Temperature tempVal;void readandwrite(void);
void resetADE9153A(void);int ledState = LOW;
int inputState = LOW;
unsigned long lastReport = 0;
const long reportInterval = 2000;
const long blinkInterval = 500;void setup() {
/* Pin and serial monitor setup */
// pinMode(CS_PIN,OUTPUT);
pinMode(LED, OUTPUT);
pinMode(USER_INPUT, INPUT);
pinMode(ADE9153A_RESET_PIN, OUTPUT);
digitalWrite(ADE9153A_RESET_PIN, HIGH);
Serial.begin(115200);resetADE9153A(); //Reset ADE9153A for clean startup
/SPI initialization and test/
bool commscheck = ade9153A.SPI_Init(SPI_SPEED,CS_PIN); //Initialize SPI
if (!commscheck) {
Serial.println("ADE9153A Shield not detected. Plug in Shield and reset the Arduino");
while (!commscheck) { //Hold until arduino is reset
}ade9153A.SetupADE9153A(); //Setup ADE9153A according to ADE9153AAPI.h
/* Read and Print Specific Register using ADE9153A SPI Library */
Serial.println(String(ade9153A.SPI_Read_32(REG_VERSION_PRODUCT), HEX)); // Version of IC
ade9153A.SPI_Write_32(REG_AIGAIN, -268435456); //AIGAIN to -1 to account for IAP-IAN swap
}void loop() {
/* Main loop /
/ Returns metrology to the serial monitor and waits for USER_INPUT button press to run autocal */
unsigned long currentReport = millis();if ((currentReport - lastReport) >= reportInterval){
lastReport = currentReport;
readandwrite();
}inputState = digitalRead(USER_INPUT);
if (inputState == LOW) {
Serial.println("Autocalibrating Current Channel");
ade9153A.StartAcal_AINormal();
runLength(20);
ade9153A.StopAcal();
Serial.println("Autocalibrating Voltage Channel");
ade9153A.StartAcal_AV();
runLength(40);
delay(100);ade9153A.ReadAcalRegs(&acalVals); Serial.print("AICC: "); Serial.println(acalVals.AICC); Serial.print("AICERT: "); Serial.println(acalVals.AcalAICERTReg); Serial.print("AVCC: "); Serial.println(acalVals.AVCC); Serial.print("AVCERT: "); Serial.println(acalVals.AcalAVCERTReg); long Igain = (-(acalVals.AICC / 838.190) - 1) * 134217728; long Vgain = ((acalVals.AVCC / 13411.05) - 1) * 134217728; ade9153A.SPI_Write_32(REG_AIGAIN, Igain); ade9153A.SPI_Write_32(REG_AVGAIN, Vgain); Serial.println("Autocalibration Complete"); delay(2000);}
}void readandwrite()
/* Read and Print WATT Register using ADE9153A Read Library */
ade9153A.ReadPowerRegs(&powerVals); //Template to read Power registers from ADE9000 and store data in Arduino MCU
ade9153A.ReadRMSRegs(&rmsVals);
ade9153A.ReadPQRegs(&pqVals);
ade9153A.ReadTemperature(&tempVal);Serial.print("RMS Current:\t");
Serial.print(rmsVals.CurrentRMSValue/1000);
Serial.println(" A");Serial.print("RMS Voltage:\t");
Serial.print(rmsVals.VoltageRMSValue/1000);
Serial.println(" V");Serial.print("Active Power:\t");
Serial.print(powerVals.ActivePowerValue/1000);
Serial.println(" W");Serial.print("Reactive Power:\t");
Serial.print(powerVals.FundReactivePowerValue/1000);
Serial.println(" VAR");Serial.print("Apparent Power:\t");
Serial.print(powerVals.ApparentPowerValue/1000);
Serial.println(" VA");Serial.print("Power Factor:\t");
Serial.println(pqVals.PowerFactorValue);Serial.print("Frequency:\t");
Serial.print(pqVals.FrequencyValue);
Serial.println(" Hz");Serial.print("Temperature:\t");
Serial.print(tempVal.TemperatureVal);
Serial.println(" degC");Serial.println("");
Serial.println("");
}void resetADE9153A(void)
digitalWrite(ADE9153A_RESET_PIN, LOW);
delay(100);
Serial.println("Reset Done");
}void runLength(long seconds)
unsigned long startTime = millis();while (millis() - startTime < (seconds*1000)){
digitalWrite(LED, HIGH);
delay(blinkInterval);
digitalWrite(LED, LOW);
