Hello, I am trying to view data coming from an ADIS16470 IMU using an ESP32. The eventual intent is to use the WiFi capability of the ESP32 to transmit the IMU data wireless. However, I am very new to Arduino and the IDE, and the only known code I could find applicable to this sensor is below (found on this GitHub repo), originally intended for a Teensy 3.2. The only changes made were for the pins used for Chip Select, Data Ready, and Interrupt so that it is compatible with the ESP32 pins. When I run the code, it does not print anything to serial, and just hangs whenever restarted.
The code compiles and uploads without error. I have found that if I put my own Serial.print statement anytime after this line:
IMU.configSPI(); // Configure SPI communication
I get a backwards question mark instead of the statement I am printing. I am not experienced with this sensor, and fairly new to ESP32. Any help to get this running would be appreciated, especially if there are differences between the Teensy and the ESP that would affect this. Please let me know if any other information is needed.
Below is the code I am using, and I have also attached the wiring schematic I am using (right now, the 5V voltage regulator is not being used, the IMU is being powered through the plugged in ESP)
#include <ADIS16470.h>
#include <SPI.h>
// Uncomment to enable debug
//#define DEBUG
// Initialize Variables
// Temporary Data Array
uint16_t *burstData;
// Checksum variable
int16_t burstChecksum = 0;
// Accelerometer
float AXS, AYS, AZS = 0;
// Gyro
float GXS, GYS, GZS = 0;
// Control registers
int MSC = 0;
int FLTR = 0;
int DECR = 0;
// Temperature
float TEMPS = 0;
// Delay counter variable
int printCounter = 0;
// Call ADIS16470 Class
ADIS16470 IMU(5,22,21); // Chip Select, Data Ready, Reset Pin Assignments
Serial.begin(115200); // Initialize serial output via USB
delay(500); // Give the part time to start up
IMU.regWrite(MSC_CTRL, 0xC1); // Enable Data Ready, set polarity
IMU.regWrite(FILT_CTRL, 0x04); // Set digital filter
IMU.regWrite(DEC_RATE, 0x00), // Disable decimation
// Read the control registers once to print to screen
MSC = IMU.regRead(MSC_CTRL);
FLTR = IMU.regRead(FILT_CTRL);
DECR = IMU.regRead(DEC_RATE);
attachInterrupt(22, grabData, RISING); // Attach interrupt to pin 2. Trigger on the rising edge
// Function used to read register values when an ISR is triggered using the IMU's DataReady output
void grabData()
burstData = {};
IMU.configSPI(); // Configure SPI before the read. Useful when talking to multiple SPI devices
burstData = IMU.wordBurst(); // Read data and insert into array
// Function used to scale all acquired data (scaling functions are included in ADIS16470.cpp)
void scaleData()
GXS = IMU.gyroScale(*(burstData + 1)); //Scale X Gyro
GYS = IMU.gyroScale(*(burstData + 2)); //Scale Y Gyro
GZS = IMU.gyroScale(*(burstData + 3)); //Scale Z Gyro
AXS = IMU.accelScale(*(burstData + 4)); //Scale X Accel
AYS = IMU.accelScale(*(burstData + 5)); //Scale Y Accel
AZS = IMU.accelScale(*(burstData + 6)); //Scale Z Accel
TEMPS = IMU.tempScale(*(burstData + 7)); //Scale Temp Sensor
// Main loop. Print data to the serial port. Sensor sampling is performed in the ISR
printCounter ++;
if (printCounter >= 50000) // Delay for writing data to the serial port
detachInterrupt(22); //Detach interrupt to avoid overwriting data
scaleData(); // Scale data acquired from the IMU
burstChecksum = IMU.checksum(burstData); // Calculate checksum based on data array
//Clear the serial terminal and reset cursor
//Only works on supported serial terminal programs (Putty)
Serial.print("\033[2J");
Serial.print("\033[H");
// Print header
Serial.println(" ");
Serial.println("ADIS16470 Teensy Burst Read Example Program");
Serial.println("Juan Chong - November 2017");
// Print control registers to the serial port
Serial.println("Control Registers");
Serial.print("MSC_CTRL: ");
Serial.println(MSC,HEX);
Serial.print("FLTR_CTRL: ");
Serial.println(FLTR,HEX);
Serial.print("DEC_RATE: ");
Serial.println(DECR,HEX);
Serial.println("Raw Output Registers");
// Print scaled gyro data
Serial.print("XGYRO: ");
Serial.println(GXS);
Serial.print("YGYRO: ");
Serial.println(GYS);
Serial.print("ZGYRO: ");
Serial.println(GZS);
// Print scaled accel data
Serial.print("XACCL: ");
Serial.println(AXS);
Serial.print("YACCL: ");
Serial.println(AYS);
Serial.print("ZACCL: ");
Serial.println(AZS);
Serial.println("Status Registers");
// Print Status Registers
Serial.print("DIAG_STAT: ");
Serial.println((*(burstData + 0)));
Serial.print("TIME_STMP: ");
Serial.println((*(burstData + 8)));
Serial.print("CHECKSUM: ");
Serial.println((*(burstData + 9)));
// Report if checksum is good or bad
Serial.print("CHECKSUM OK? ");
if (burstChecksum == *(burstData + 9))
Serial.println("YES");
Serial.println("NO");
// Print scaled temp data
Serial.print("TEMP: ");
Serial.println(TEMPS);
#ifdef DEBUG
// Print unscaled gyro data
Serial.println((*(burstData + 1)));
Serial.println((*(burstData + 2)));
Serial.println((*(burstData + 3)));
// Print unscaled accel data
Serial.println((*(burstData + 4)));
Serial.println((*(burstData + 5)));
Serial.println((*(burstData + 6)));
// Print unscaled temp data
Serial.println((*(burstData + 7)));
#endif
printCounter = 0;
