Hi everyone im working in Adiy SIM A7670C Breakoutboard to arduino uno and is not working and automatically reseting when attached sim. I am tried with vi and airtel 4g sim.
External Power supply of 4.2V.
connect the UART in parallel manner i.e TX to TX & RX to RX.
make all GND common.
Set baud rate to 115200
Upload a blank sketch to UNO. XXXXX
Im tried AT commands it not working properly meanwhile i get message repeated I am attached screenshot below.
Adiy SIM A7670C Breakoutboard to arduino uno is not working automatically reseting when attached sim
Please show a diagram of all connected devices including the power supplies and their ratings.
The 76xx draws quite a bit of current at different times during operation.
This unit has two critical ratings. If you exceed the 4.2V you can damage the unit. You are using an UNO which outputs 5V on the I/O pins, this may also damage your unit. You should be using a power supply with at least a 4 Amp rating. As requested by @lastchancename Post an annotated schematic showing exactly how you have wired this. Also post links to the technical information on the hardware.
- Supply Voltage – 3.4V to 4.2V
- Power Consumption – 2-3 Amp
- What is your UART voltage? 5V? 3.3V?
- A7670C is made for the chinese marked. Do you intend to use it i china?
