Adjust Chimes hours count
Hi, I download the clock mantle code from the website https://www.instructables.com/3D-Printed-Mantel-Style-Clock/. And I want to adjust hour chimes to start play at 5:00 am till 22:00 pm. how can I adjust the hours chimes??
//                                 Mantel Clock With Chimes And Daylight Savings                            //
//                                 Copyright (c) 2018 By Zumwalt Properties, LLC.                           //
//                                             All Rights Reserved.                                         //
// Purchased components.
//  1) Feather esp32                : https://www.adafruit.com/product/3405
//  2) Feather Music Maker          : https://www.adafruit.com/product/3436
//  3) Speakers                     : https://www.amazon.com/gp/product/B01LN8ONG4/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
//  4) Stepper motor and controller : https://www.amazon.com/gp/product/B077YGWRHK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
// Change log.
// 2018/12/03, Version 01.00.00.
//  1) Initial build.
// User settings.
    // Compiler.
    #define         HOME_SWITCH_CALIBRATE false             // home switch calibrate (true) or not (false)
    #define         USE_SERIAL_PRINTF     false             // use serial.printf (true) or not (false)
    // Daylight savings time.
    const int             nDstEndMonth    = 0;             // end month of year (1 == January, 0 for dst off)
    const int             nDstEndDay      = 0;              // 0 for end on first Sunday, 1 through 28-31 for specific date
    const int             nDstEndHour     = 0;              // end hour (0 through 23)
    const int             nDstStartMonth  = 0;              // start month of year (1 == January, 0 for dst off)
    const int             nDstStartDay    = 0;              // 0 for start on second Sunday, 1 through 28-31 for specific date
    const int             nDstStartHour   = 0;              // start hour (0 through 23)
    // Time zone.
    const unsigned long   nTimeZone       = -4;             // offset from utc to your timezone (code was designed in Oklahoma, US central time zone)
    // Wifi.
    const char            chPassword[]    = "50A5DC7425B5"; // your network password
    const char            chSSID[]        = "ARRIS-25B5";     // your network SSID
    //LED Lights
    // On and Off Times (as int, max=32secs)
const unsigned int onTime = 3600000;
const unsigned int offTime = 7200000;
// Tracks the last time event fired
unsigned long previousMillis=0;
// Interval is how long we wait
int interval = onTime;
// Used to track if LED should be on or off
boolean LED13state = true;
// Includes.
    #include <SD.h>                                         // for sd card
    #include <SPI.h>                                        // for spi
    #include <WiFi.h>                                       // for wifi
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #include <Wire.h>
// Constants.
  //"Adafruit Feather Music Maker".
    // Communication.
      #define VS1053_DATA_XFER_SIZE               32          // vs1053 maximum data transfer size
      #define VS1053_SCI_READ                     0x03        // vs1053 read
      #define VS1053_SCI_WRITE                    0x02        // vs1053 write
      #define VS1053_REG_MODE                     0x00        // vs1053 address of mode register
      #define VS1053_REG_STATUS                   0x01        // vs1053 address of status register
      #define VS1053_REG_CLOCKF                   0x03        // vs1053 address of clock frequency register
      #define VS1053_REG_VOLUME                   0x0B        // vs1053 address of volume register
      #define VS1053_MODE_SM_RESET                0x0004      // vs1053 reset command
      #define VS1053_MODE_SM_SDINEW               0x0800      // vs1053 sdi new command
    // Pins.
      #define SCK                                 5           // spi clock pin number
      #define MISO                                19          // spi master input slave output pin number
      #define MOSI                                18          // spi master output slave input pin number
      #define SD_CS                               14          // sd card chip select pin number
      #define VS1053_CS                           32          // vs1053 chip select pin number
      #define VS1053_DCS                          33          // vs1053 data/command select pin pin number
      #define VS1053_DREQ                         15          // vs1053 data request pin number
  // Clock structure.
  // A modified version of the tm structure.
  struct tmClock
    // tm structure styled variables.
    int           tm_sec;                                   // 0 through 59
    int           tm_min;                                   // 0 through 59
    int           tm_hour;                                  // 0 through 23
    int           tm_mday;                                  // 1 through 28 - 31
    int           tm_mon;                                   // 0 through 11
    int           tm_year;                                  // 1970 through 2036ish
    int           tm_wday;                                  // 0 (Sunday) through 6 (Saturday)
    int           tm_yday;                                  // not currently implemented
    int           tm_isdst;                                 // 1 if daylight savings time is on, 0 if not
    // Modifications.
    unsigned long ulTime;                                   // time in seconds since 1970
    unsigned long ulDstStart;                               // daylight savings time start in seconds since 1970
    unsigned long ulDstEnd;                                 // daylight savings time end in seconds since 1970
    bool          bDstValid;                                // daylight savings time start and end is valid (true) or not (false)
  // Motor.
    #define MOTOR_STEP_FAST                     1           // fast step speed
    #define MOTOR_STEP_NORMAL                   4           // normal step speed
    #define MOTOR_STEPS_PER_HOUR                4096        // steps for one full revolution
  // Ntp.
    enum    NtpPacketMode {REQUEST, SENT, RECEIVED};        // possible values for an NtpPacketMode variable.
    #define NTP_PACKET_LENGTH                   48          // size, in bytes, of an ntp packet
    #define PACKET_DELAY_RESET                  5           // delay (in seconds at 1hz loop()) before resending an ntp packet request
  // Pins.
    #define LED_PIN                             13          // on board led drive pin number
    #define MOTOR_PHASE_A                       A0          // motor phase a pin number
    #define MOTOR_PHASE_B                       A1          // motor phase b pin number
    #define MOTOR_PHASE_C                       A5          // motor phase c pin number
    #define MOTOR_PHASE_D                       21          // motor phase d pin number
    #define SWITCH_PIN                          27          // 12:00 switch input pin number
  // Serial_printf() control.
  #if USE_SERIAL_PRINTF
      #define Serial_printf                     Serial.printf
  #else
      #define Serial_printf                     //
  #endif
  // Time.
    #define SECONDS_PER_MINUTE                  60UL
    #define SECONDS_PER_HOUR                    (SECONDS_PER_MINUTE * 60UL)
    #define SECONDS_PER_DAY                     (SECONDS_PER_HOUR * 24UL)
  // UDP.
    #define UDP_PORT                            4000        // ntp time server udp port
// Global Variables.
  // Adafruit 2900 oled.
    //Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32, & Wire);
    #define OLED_RESET 4
    Adafruit_SSD1306 display(OLED_RESET);
    //#elif defined(ESP32)
    //#define BUTTON_A 15
    //#define BUTTON_B 32
    //#define BUTTON_C 14
    //#define Wire
  // Clock.
    bool          bClockHandsUpdated            = false;  // clock hands have been updated (true) or not (false)
    bool          bClockStatsValid              = false;  // clock statistics are valid (true) or not (false)
  // Days of the week.
    const  char*  chDaysOfWeek[]                 = {
                                                      "Sun",
                                                      "Mon",
                                                      "Tue",
                                                      "Wed",
                                                      "Thu",
                                                      "Fri",
                                                      "Sat"
    // Interrupts.
    hw_timer_t *                timerLoop             = NULL;
    volatile SemaphoreHandle_t  timerLoopSemaphore;
    // Months of the year.
    const char*   chMonth[]                       = {
                                                      "Jan",
                                                      "Feb",
                                                      "Mar",
                                                      "Apr",
                                                      "May",
                                                      "Jun",
                                                      "Jul",
                                                      "Aug",
                                                      "Sep",
                                                      "Oct",
                                                      "Nov",
                                                      "Dec"
  // mp3.
    File            fMp3Current;                            // mp3 file pointer
    char            chMp3CurrentName[81];                   // mp3 file name
    unsigned long   nMp3CurrentPosition           = 0;      // mp3 file position
    unsigned long   nMp3CurrentSize               = 0;      // mp3 file size
    int             nMp3CurrentVolume             = 0;     // mp3 playback volume
    bool            bMp3PlackEnabled              = false;  // play mp3 (true) or not (false)
    bool            bMp3Playing                   = false;  // mp3 is playing is playing (true) or not (false)
  // ntp.
    byte            chNtpPacket[NTP_PACKET_LENGTH];         // ntp packet
  // Stats.
    unsigned long ulMicrosAverage                 = 0;
    unsigned long ulMicrosCurrent                 = 0;
    unsigned long ulMicrosHigh                    = 0;
    unsigned long ulMicrosLow                     = 4294967295UL;
  // Stepper motor.
    int             nMillisecondsStepHold         = MOTOR_STEP_FAST;    // time in milliseconds between motor steps
    bool            bStepperInUse                 = false;              // stepper motor in use (true) or not (false)
  // Time.
    struct tmClock  tmTime = {0, 0, 0, 1, 0, 2022, 0, 0, 0, 0, 0, false}; // where time occurs
    bool            bTimeStatsValid                = false;
  // Udp.
    WiFiUDP         Udp;                                    // udp structure
// Interrupts.
// onTimer
// Called by interrupt service.
// Entry   : nothing
// Returns : nothing
// Notes   :
//  1) Via xSemaphoreGiveFromISR(), enable the next loop() pass.
void IRAM_ATTR onTimer()
  // Give semaphore.
  xSemaphoreGiveFromISR(timerLoopSemaphore, NULL);
// Tasks.
// taskClockHome
// Task to home the clock to the 12:00 position.
// Entry   : pointer to tmClock structure
void  taskClockHome(void * tmTime)
  // Check stepper motor availability.
  if(bStepperInUse)
    // Debug.
    Serial_printf("taskHome(): stepper motor in use, task terminated.\n");
    // Stepper motor in use, end this task.
    vTaskDelete(NULL);
  // Stepper motor not in use,  but it is now.
  bStepperInUse = true;
  // Debug.
  Serial_printf("taskHome(): homing clock to 00:00.\n");
  // Turn on the on board led.
  digitalWrite(LED_PIN, HIGH);
  // Speed up.
  // Move off of the 12:00 switch.
  while(!digitalRead(SWITCH_PIN))
    Step(1);
  digitalWrite(LED_PIN, LOW);
  // Move onto the 12:00 switch.
  while(digitalRead(SWITCH_PIN))
    Step(1);
  // Turn off the on board led.
  // Remove motor power.
  MotorOff();
  // Resume normal speed.
  nMillisecondsStepHold = MOTOR_STEP_NORMAL;
  // Clock is homed.
    // Debug.
    Serial_printf("taskHome(): clock homed at 00:00.\n");
    // Hour, minutes and seconds to zero.
    ((tmClock *)tmTime)->tm_hour = ((tmClock *)tmTime)->tm_min = ((tmClock *)tmTime)->tm_sec = 0;
    DateAndTimeToSeconds((tmClock *)tmTime);
  // Stepper no longer in use.
  // End of task.
  vTaskDelete(NULL);
// taskMp3Play
// Task to perform sd card mp3 playbock on the vs1053 via spi.
// Entry   : pointer to arguments
void  taskMp3Play(void * chMp3Name)
  // mp3 is playing.
  bMp3Playing = true;
  // Make a local copy of the filename.
  char  chMp3NameLocal[81];
  strcpy(chMp3NameLocal, (char *)chMp3Name);
  // Check for play enabled.
  while(bMp3PlackEnabled)
      // Play is enabled, check the vs1053.
      if(digitalRead(VS1053_DREQ))
      // vs1053 is ready for more data, check for availability of more mp3 data.
        if(fMp3Current.available())
          // More mp3 data is available, read mp3 data from sd card.
          unsigned char chBuffer[VS1053_DATA_XFER_SIZE + 1];
          int nByteCount = fMp3Current.read(chBuffer, VS1053_DATA_XFER_SIZE);
          // Send mp3 data to the vs1053.
          SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
          digitalWrite(VS1053_DCS, LOW);
          SPI.writeBytes(chBuffer, nByteCount);
          digitalWrite(VS1053_DCS, HIGH);
          SPI.endTransaction();
          // Update nMp3CurrentPosition.
          nMp3CurrentPosition += nByteCount;
          // If VS1053_DREQ just transitioned low (e.g. the buffer just became
          // full), give up some time.
          if(! digitalRead(VS1053_DREQ))
            // Give up some time.  I measured the time between the falling edge
            // of VS1053_DREQ to the next rising edge of VS1053_DREQ to be about
            // 23.6ms for each VS1053_DATA_XFER_SIZE size data transfer, so any
            // delay "comfortably" less than 23.6ms should work, I chose 20ms.
            vTaskDelay(20);
          // No more mp3 data available, stop play.
          // Debug.
          Serial_printf("taskMp3Play(): end of mp3 \"%s\".\n", chMp3NameLocal);
  // taskMp3Play no longer running.
  // Done.
  vTaskDelete(NULL);
// taskMp3Start
// Task to start sd card mp3 playbock on the vs1053 via spi.
// Entry   : pointer to name of file to play on sd card
void taskMp3Start(void * chMp3Name)
  // Disable mp3 play.
  // Wait for taskMp3Play to stop.
    while(bMp3Playing)
      // taskMp3Play is still running, delay awhile then check again.
      vTaskDelay(40);
      // Debug.
      Serial_printf("taskMp3Start(): waiting for taskMp3Play() to stop.\n");
  // taskMp3Play has stopped, it is now safe to close the current mp3 file.
  fMp3Current.close();
  // Reset the vs1053.
  vs1053Reset();
  // Open the new mp3.
    // Attempt to open the file.
    fMp3Current = SD.open((char *)chMp3Name, "rb");
    if(! fMp3Current)
      // Debug.
      Serial_printf("taskMp3Start(): mp3 %s could not be opened.\n", chMp3Name);
      // Attempt failed.
      vTaskDelete(NULL);
    // Attempt succeeded, obtain mp3 size and reset mp3 position
    // and task call count.
    nMp3CurrentSize = fMp3Current.size();
  // Wait for vs1053 to become ready.
  while(! digitalRead(VS1053_DREQ))
    // Not yet ready, delay.
    vTaskDelay(100);
    // Check again for ready.
      // Still not ready, reset and check again.
      vs1053Reset();
      // Debug.
      Serial_printf("taskMp3Start(): vs1053 not ready, resetting it again.\n");
  // Enable mp3 play.
  bMp3PlackEnabled = true;
  // Start taskMp3Play in cpu core 0.
  xTaskCreatePinnedToCore(taskMp3Play, "taskMp3Play", 4000, chMp3Name, 4, NULL, 0);
  // Debug.
  Serial_printf("taskMp3Start(): starting mp3 \"%s\", size %d bytes.\n", chMp3Name, nMp3CurrentSize);
  // End of task.
  vTaskDelete(NULL);
// taskUpdateClockHands
// Task to perform update of clock hands.
void  taskUpdateClockHands(void * tmTime)
  // Local variables.
  long              nClockwiseMinutes = 0;
  long              nCounterClockwiseMinutes = 0;
  long              nMinutesDelta = 0;
  long              nStepCount = 0;
  long              nStepDirection = 0;
  long              nStepPosition = 0;
  long              nStepPositionN1 = 0;
  long              nTimeInMinutes = 0;
  static long       nTimeInMinutesIndicated = 0;
  // Check for stepper motor availability.
  if(bStepperInUse)
    // Debug.
    Serial_printf("taskUpdateClockHands(): stepper motor in use, task terminated.\n");
    vTaskDelete(NULL);
  // Stepper motor not in use, calculate nTimeInMinutes.
  nTimeInMinutes = (((((tmClock *)tmTime)->tm_hour + ((tmClock *)tmTime)->tm_isdst) % 12) * 60) + ((tmClock *)tmTime)->tm_min;
  // Check if update is needed.
  if(nTimeInMinutesIndicated != nTimeInMinutes)
    // Clock hands need update, stepper motor is now in use.
    // Calculate clockwise and counterclockwise time in minutes
    // required to drive indicated time to actual time.
    if(nTimeInMinutes > nTimeInMinutesIndicated)
      nClockwiseMinutes = nTimeInMinutes - nTimeInMinutesIndicated;
      nCounterClockwiseMinutes = (nTimeInMinutesIndicated + (12 * 60)) - nTimeInMinutes;
    else if(nTimeInMinutes < nTimeInMinutesIndicated)
      nClockwiseMinutes = (nTimeInMinutes + (12 * 60)) - nTimeInMinutesIndicated;
      nCounterClockwiseMinutes = nTimeInMinutesIndicated - nTimeInMinutes;
    // Determine shortest direction.
    if(nClockwiseMinutes < nCounterClockwiseMinutes)
      // Clockwise movement is shorter.
      nStepDirection = 1;
      nMinutesDelta = nClockwiseMinutes;
      // Counterclockwise movement is shorter.
      nStepDirection = -1;
      nMinutesDelta = nCounterClockwiseMinutes;
    // Drive indicated time to time.
    while(nTimeInMinutes != nTimeInMinutesIndicated)
      // Set stepping speed.
      if(nMinutesDelta > 5)
        // > 5 minutes remain, go fast.
        // <= 5 minutes remain, go slow.
      // Update minutes to go.
      nMinutesDelta --;
      // Calculate current position.
      nStepPositionN1 = ((nTimeInMinutesIndicated % 60) * MOTOR_STEPS_PER_HOUR) / 60;
      // Update minutes.
      nTimeInMinutesIndicated = (nTimeInMinutesIndicated + nStepDirection) % (12 * 60);
      nTimeInMinutesIndicated = (nTimeInMinutesIndicated < 0) ? (12UL * 60UL) + nTimeInMinutesIndicated : nTimeInMinutesIndicated;
      // Calculate target position.
      nStepPosition = ((nTimeInMinutesIndicated % 60) * MOTOR_STEPS_PER_HOUR) / 60;
      // Calculate step count.
      nStepCount = ((nStepDirection > 0) ? nStepPosition - nStepPositionN1 : nStepPositionN1 - nStepPosition);
      nStepCount = (nStepCount < 0) ? MOTOR_STEPS_PER_HOUR + nStepCount : nStepCount;
      // Step the required steps.
      while(nStepCount)
        // Step.
        Step(nStepDirection);
        // Count steps.
        nStepCount = nStepCount - 1;
    MotorOff();
    // Clock hands are updated.
    bClockHandsUpdated = true;
    // Finished with the stepper motor.
    // Debug.
    Serial_printf("taskUpdateClockHands(): clock hands updated.\n");
  // Finished with task.
  vTaskDelete(NULL);
// Arduino.
// setup
  // Serial.
    pinMode(13, OUTPUT);
    while(!Serial){};
    Serial_printf("setup(): starting setup.\n");
#endif
    // Debug.
    Serial_printf("setup(): initializing Adafruit 2900 oled.\n");
    // Initialize with the I2C addr 0x3C.
    display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
    //Serial.println("OLED begun");
    // Clear the display.
    display.clearDisplay();
    display.display();
    // Set text size and color.
    display.setTextSize(1);
    display.setTextColor(WHITE);
  // Pins.
    // vs1053 chip select.
    pinMode(VS1053_CS, OUTPUT);
    digitalWrite(VS1053_CS, HIGH);
    // vs1053 data / control select.
    pinMode(VS1053_DCS, OUTPUT);
    // vs1053 data request.
    pinMode(VS1053_DREQ, INPUT);
    // Stepper motor contoller.
    pinMode(MOTOR_PHASE_A, OUTPUT);
    pinMode(MOTOR_PHASE_B, OUTPUT);
    pinMode(MOTOR_PHASE_C, OUTPUT);
    pinMode(MOTOR_PHASE_D, OUTPUT);
    // esp32 on board led.
    pinMode(LED_PIN, OUTPUT);
    // 12:00 o'clock position reed switch.
    pinMode(SWITCH_PIN, INPUT_PULLUP);
#if HOME_SWITCH_CALIBRATE
  // Home switch position calibration.
    // Rotate counter clockwise 90 degrees.
    for(int nCount = 0; nCount < MOTOR_STEPS_PER_HOUR / 4; nCount ++)
      Step(-1);
    // Home the clock.
    ClockHome(& tmTime);
    delay(100);
    while(bStepperInUse)
      delay(100);
    // On board led on.
    // Rotate clockwise until the 00:00 switch activates.
      Step(1);
    // On board led off.
    // Motor off.
    MotorOff();
    // Loop forever (reset the esp32 to restart the test).
    while(1){};
#endif
  // Clock hands.
  // Wifi.
    // Debug.
    Serial_printf("setup(): initializing wifi connection.\n");
    // Start wifi.
    WiFi.mode(WIFI_STA);
    WiFi.begin(chSSID, chPassword);
    // Check wifi status.
      // Debug.
      Serial_printf("setup(): awaiting wifi connection.");
      // Wait for wifi to connect.
      while(WiFi.status() != WL_CONNECTED)
          Serial_printf(".");
    // Connected.
    // Debug.
    Serial_printf("\nsetup(): wifi connected to \"%s\", ip address = %s.\n", chSSID, WiFi.localIP().toString().c_str());
  // Sd card service.
  // Notes:
  //  1) The sd card library uses hardware spi, thus it initializes the
  //     spi hardware and as such SPI.begin() is not necessary.
    // Begin sd service.
    if(!SD.begin(SD_CS))
      // Debug.
      Serial_printf("setup(): sd service failed or sd card not present.\n");
      // sd service failed or sd card not present.
      while (1);
    // sd service started.
    // Debug.
    Serial_printf("setup(): sd card found.\n");
  // Ntp time.
    // Begin udp service.
    Udp.begin(UDP_PORT);
  // Interrupt service.
    // Create onTimer() and loop() semaphore.
    timerLoopSemaphore = xSemaphoreCreateBinary();
    // Use timer 0 (4 available from 0 through 3), with a prescale of 80.
    timerLoop = timerBegin(0, 80, true);
    // Attach onTimer() to timer.
    timerAttachInterrupt(timerLoop, & onTimer, true);
    // Set alarm to call onTimer function every second (value in microseconds)
    // with repeat (third parameter).
    timerAlarmWrite(timerLoop, 1000000, true);
    // Start the alarm.
    timerAlarmEnable(timerLoop);
  // Wait for the clock to home.
    delay(4000);
    Serial_printf("setup(): waiting for clock to home.\n");
  Serial_printf("setup(): clock homed.\n");
  // End of setup.
  Serial_printf("setup(): setup complete.\n");
// loop
// Notes:
//  1) On the first pass through the loop:
//      a) setup() has intialized the time to 0, which represents the date and
//         time of Thu, Jan 1st, 1970, 00:00:00am, Dst off.
//      b) The call to UpdateNtp() by UpdateTime() immediatedly sends the first
//         ntp request since minutes == 0.  While waiting for the ntp server to
//         reply, the clock will update from the initialized time until ntp time
//         is received from the ntp server, thus the clock will be incorrect.
//      c) UpdateChimes() will start playing the top of hour chimes without the
//         hours count chimes, detected by the local variable bChimeColdStart.
//         This is simply the power up tune to indicate the audio is functional.
   // Set Pin 13 to state of LED13state each timethrough loop()
   // If LED13State hasn't changed, neither will the pin
   digitalWrite(13, LED13state);
   // Grab snapshot of current time, this keeps all timing
   // consistent, regardless of how much code is inside the next if-statement
   // Compare to previous capture to see if enough time has passed
   if ((unsigned long)(currentMillis - previousMillis) >= interval) {
      // Change wait interval, based on current LED state
      if (LED13state) {
         // LED is currently on, set time to stay off
         interval = offTime;
         // LED is currently off, set time to stay on
         interval = onTime;
      // Toggle the LED's state, Fancy, eh!?
      LED13state = !(LED13state);
      // Save the current time to compare "later"
  // Wait for alarm tick (set to 1hz. in setup()).
  if(xSemaphoreTake(timerLoopSemaphore, portMAX_DELAY) == pdTRUE)
    // For testing, read the current microseconds and set the led pin high (for
    // oscilliscope use).
    unsigned long ulMicrosStart = micros();
    //digitalWrite(LED_PIN, HIGH);
    // Update time.
    UpdateTime(& tmTime);
    // Update chimes.
    UpdateChimes(& tmTime);
    // Update oled.
    UpdateOled(& tmTime);
    // Update clock hands.
    if(!bStepperInUse)
      // bStepperInUse not in use, use it.
      // Note that during dst transitions, the clock hands will move forward
      // (off to on) or backward (on to off) one hour.  During that foward or
      // backward movement, although the software will not allow it, another
      // taskUpdateClockHands should not be created until the clock completes
      // the hour transition.
      xTaskCreatePinnedToCore(taskUpdateClockHands, "taskUpdateClockHands", 4000, & tmTime, 2, NULL, 1);
    // For testing the loop execution time with an oscilliscope,
    // at the end of each loop pass turn the led off.
    //digitalWrite(LED_PIN, LOW);
    // For testing via the Arduino serial monitor, capture the time.
    unsigned long ulMicrosEnd = micros();
    // For testing, update statistics.
      // Local variables.
      #define AVERAGE_DELTAS 40
      static unsigned long ulDeltas[AVERAGE_DELTAS];
      unsigned long        ulDeltasAverage = 0;
      static unsigned long ulDeltasCount = 0;
      static unsigned long ulDeltasPointer = 0;
      // Statistic calculations start after clock hands are updated.
      if(bClockHandsUpdated)
        // Calculate loop time.
          // Adjust for overflow.
          if(ulMicrosEnd < ulMicrosStart)
            // Micros overflowed.
            ulMicrosEnd = 4294967295UL - (ulMicrosStart - ulMicrosEnd) + 1;
            ulMicrosStart = 0UL;
          ulMicrosCurrent = ulMicrosEnd - ulMicrosStart;
          // Update high and low loop times.
          if(ulMicrosLow > ulMicrosCurrent)
            ulMicrosLow = ulMicrosCurrent;
          if(ulMicrosHigh < ulMicrosCurrent)
            ulMicrosHigh = ulMicrosCurrent;
          // Update average loop time.
            // Add the current loop time to the average array.
            ulDeltas[((ulDeltasPointer += 1) %= AVERAGE_DELTAS)] = ulMicrosCurrent;
            // Update the count of deltas in the averages array.
            ulDeltasCount = (ulDeltasCount >= AVERAGE_DELTAS) ? AVERAGE_DELTAS : ulDeltasCount + 1;
            // Sum the contents of the deltas array.
            for(int nCount = 0; nCount < ulDeltasCount; nCount ++)
              ulDeltasAverage += ulDeltas[nCount];
            // Calculate the average.
            ulDeltasAverage /= ulDeltasCount;
            ulMicrosAverage = ulDeltasAverage;
          // Clock stats are now valid.
          bTimeStatsValid = true;
    // Debug.
    Serial_printf("loop(): date and time  : %s, %s %d%s, %4d, %02d:%02d:%02d%s, dst is %s.\nloop(): execution time : cur. = %luus, %d cnt. avg. = %lus, high = %luus, low = %luus.\n\n",
                   chDaysOfWeek[tmTime.tm_wday],
                   chMonth[tmTime.tm_mon],
                   tmTime.tm_mday,
                   (tmTime.tm_mday == 1) ? "st" : (tmTime.tm_mday == 2) ? "nd" : (tmTime.tm_mday == 3) ? "rd" : "th",
                   tmTime.tm_year,
                   ((tmTime.tm_hour + tmTime.tm_isdst) % 24) ? ((tmTime.tm_hour + tmTime.tm_isdst) % 24) : 0,
                   tmTime.tm_min,
                   tmTime.tm_sec,
                   (((tmTime.tm_hour + tmTime.tm_isdst) % 24) >= 0) ? "pm" : "am",
                   (tmTime.tm_isdst) ? "on" : "off",
                   ulMicrosEnd - ulMicrosStart,
                   AVERAGE_DELTAS,
                   ulDeltasAverage,
                   ulMicrosHigh,
                   ulMicrosLow);
    Serial_printf("loop(): this should never execute.\n");
// Utilities.
// ClockHome
// Home the clock to 12:00.
void  ClockHome(tmClock * tmTime)
  // Start taskHome with tmTime.
  xTaskCreatePinnedToCore(taskClockHome, "taskClockHome", 4000, tmTime, 2, NULL, 1);
// DateAndTimeToSeconds
// Convert year, month, day, hours, minutes and seconds to seconds since 1970.
// Returns : time in seconds since 1970
// Notes   :
// 1) Derived from this excellent document:  http://howardhinnant.github.io/date_algorithms.html
unsigned long DateAndTimeToSeconds(tmClock * tmTime)
    long          lYear = (long)tmTime->tm_year - ((((long)tmTime->tm_mon + 1UL) <= 2UL) ? 1UL : 0UL);
    unsigned long ulEra = ((lYear >= 0UL) ? lYear : lYear - 399UL) / 400UL;
    unsigned long ulMonthOfEra = (lYear - (ulEra * 400UL));
    unsigned long ulDayOfYear = (153UL * (((long)tmTime->tm_mon + 1UL) + (((long)tmTime->tm_mon + 1UL) > 2UL ? -3UL : 9UL)) + 2UL) / 5UL + tmTime->tm_mday - 1UL;
    unsigned long ulDayOfEra = (ulMonthOfEra * 365UL) + (ulMonthOfEra / 4UL) - (ulMonthOfEra / 100UL) + ulDayOfYear;
    return (((ulEra * 146097UL + ulDayOfEra - 719468UL) * (SECONDS_PER_DAY)) +
            ((long)tmTime->tm_hour * SECONDS_PER_HOUR) +
            ((long)tmTime->tm_min * SECONDS_PER_MINUTE) +
             (long)tmTime->tm_sec);
// FirstSunday
// Given the week day of the first day of the month, returns the day of the month of the first Sunday.
// Entry   : weekday (0 through 6 for Sunday through Saturday) of the first day of the month
// Returns : monthday (1 through 7) of the first Sunday of the current month
// Notes   :
//  1) Example:
//    a) If the first weekday of the month == 0 (Sun) then return 1 (first Sun on the 1st day of the month)
//    b) If the first weekday of the month == 1 (Mon) then return 7 (first Sun on the 7th day of the month)
//    c) If the first weekday of the month == 2 (Tue) then return 6 (first Sun on the 6th day of the month)
//    d) If the first weekday of the month == 3 (Wed) then return 5 (first Sun on the 5th day of the month)
//    e) If the first weekday of the month == 4 (Thu) then return 4 (first Sun on the 4th day of the month)
//    f) If the first weekday of the month == 5 (Fri) then return 3 (first Sun on the 3rd day of the month)
//    g) If the first weekday of the month == 6 (Sat) then return 2 (first Sun on the 2nd day of the month)
int   FirstSunday(int nDayOfWeek)
  static const int  nFirstSundayDayOfMonthByDayOfWeek[] = {1, 7, 6, 5, 4, 3, 2};
  return(nFirstSundayDayOfMonthByDayOfWeek[nDayOfWeek % 6]);
// IsDst
// Returns true if daylight savings time is on, false is not.
// Returns : 1 if dst is on, 0 if not
// Notes   :
// 1) The return value is true if (current time in seconds >= daylight savings time
//    start in seconds) and (current time in seconds < daylight savings time end
//    in seconds), false if not.
int  IsDst(tmClock * tmTime)
  if((tmTime->ulTime >= tmTime->ulDstStart) && (tmTime->ulTime < tmTime->ulDstEnd) && nDstEndMonth && nDstStartMonth)
    // dst is on.
    return 1;
    // dst is off.
    return 0;
// MotorOff
// Turn off motor drive.
// Entry   : nothing
void  MotorOff()
  digitalWrite(MOTOR_PHASE_A, LOW);
  digitalWrite(MOTOR_PHASE_B, LOW);
  digitalWrite(MOTOR_PHASE_C, LOW);
  digitalWrite(MOTOR_PHASE_D, LOW);
// Mp3Start
// Start sd card mp3 playbock on the vs1053 via spi.
void Mp3Start(char * chMp3Name)
  // Set chMp3CurrentName.
  strcpy(chMp3CurrentName, chMp3Name);
  // Start taskMp3Start with chMp3CurrentName.
  xTaskCreatePinnedToCore(taskMp3Start, "taskMp3Start", 4000, & chMp3CurrentName, 0, NULL, 0);
// SecondSunday
// Given the week day of the first day of the month, returns the day of the month of the second Sunday.
// Entry   : weekday (0 through 6 for Sunday through Saturday) of the first day of the current month
// Returns : monthday (8  through 14) of the first Sunday of the current month
// Notes   :
//  1) Example:
//    a) If the first weekday of the month == 0 (Sun) then return  8 (second Sun on the 8th day of the month)
//    b) If the first weekday of the month == 1 (Mon) then return 14 (second Sun on the 14th day of the month)
//    c) If the first weekday of the month == 2 (Tue) then return 13 (second Sun on the 13th day of the month)
//    d) If the first weekday of the month == 3 (Wed) then return 12 (second Sun on the 12th day of the month)
//    e) If the first weekday of the month == 4 (Thu) then return 11 (second Sun on the 11th day of the month)
//    f) If the first weekday of the month == 5 (Fri) then return 10 (second Sun on the 10th day of the month)
//    g) If the first weekday of the month == 6 (Sat) then return  9 (second Sun on the 9th day of the month)
int   SecondSunday(int nDayOfWeek)
  return (FirstSunday(nDayOfWeek) + 7);
// SecondsToDateAndTime
// Convert seconds since 1970 to year, month, day, hours, minutes and seconds.
// Notes   :
void  SecondsToDateAndTime(tmClock * tmTime)
    unsigned long ulZ = (tmTime->ulTime / SECONDS_PER_DAY) + 719468UL;
    unsigned long ulEra = ((ulZ >= 0UL) ? ulZ : ulZ - 146096UL) / 146097UL;
    unsigned long ulDayOfEra = (ulZ - ulEra * 146097UL);
    unsigned long ulYearOfEra = (ulDayOfEra - (ulDayOfEra / 1460UL) + (ulDayOfEra / 36524UL) - (ulDayOfEra / 146096UL)) / 365UL;
    unsigned long ulYear = ulYearOfEra + (ulEra * 400UL);
    unsigned long ulDayOfYear = ulDayOfEra - ((365UL * ulYearOfEra) + (ulYearOfEra / 4UL) - (ulYearOfEra / 100UL));
    unsigned long ulMonthNumber = (5UL * ulDayOfYear + 2UL) / 153UL;
    unsigned long ulDayOfMonth = ulDayOfYear - (153UL * ulMonthNumber + 2UL) / 5UL + 1UL;
    unsigned long ulMonthOfYear = ulMonthNumber + (ulMonthNumber < 10UL ? 3UL : -9UL);
    long          lDays = (tmTime->ulTime / SECONDS_PER_DAY);
    tmTime->tm_year = ulYear + ((ulMonthOfYear <= 2) ? 1 : 0);
    tmTime->tm_mon = ulMonthOfYear - 1;
    tmTime->tm_mday = ulDayOfMonth;
    tmTime->tm_hour = (tmTime->ulTime % SECONDS_PER_DAY) / SECONDS_PER_HOUR;
    tmTime->tm_min = (tmTime->ulTime % SECONDS_PER_HOUR) / SECONDS_PER_MINUTE;
    tmTime->tm_sec = (tmTime->ulTime % SECONDS_PER_MINUTE);
    tmTime->tm_wday = (lDays >= - 4) ? (lDays + 4) % 7 : (lDays + 5) % 7 + 6;
    return;
// Step
// Step the stepper motor.
// Entry   : direction (1 = clockwise, -1 = counter clockwise)
// Notes   : 1) for this stepper motor, 1 step is 1 / MOTOR_STEPS_PER_HOUR degrees.
//           2) forward clock motion is performed in 8 steps:
//              a) Phase d
//              b) Phase d and c
//              c) phase c
//              d) phase c and b
//              e) phase b
//              f) phase b and a
//              g) phase a
//              h) phase a and d
//            3) Reverse clock motion is performed in the reverse order of 2).
void  Step(int nDirection)
  // Local variables.
  static  int nPhase = 0;
  // Update phase.
  nPhase = ((nDirection < 0) ? (nPhase + 1) : (nPhase - 1)) & 7;
  // Step this phase.
  switch(nPhase)
    case 0:
      digitalWrite(MOTOR_PHASE_D, HIGH);
    case 1:
      digitalWrite(MOTOR_PHASE_C, HIGH);
    case 2:
    case 3:
      digitalWrite(MOTOR_PHASE_B, HIGH);
    case 4:
    case 5:
      digitalWrite(MOTOR_PHASE_A, HIGH);
    case 6:
    case 7:
  // Hold this step for nMillisecondsStepHold milliseconds.
  delay(nMillisecondsStepHold);
// UpdateChimes
// Update chimes.
void  UpdateChimes(tmClock * tmTime)
  // Local variables.
  static bool           bChimeColdStart = true; // cold start wakeup chime (initialized to true to avoid hour chime count on cold start)
  static int            nChimeHours = 0;        // chime hours count (0 if off, 1 through 12 for hour chime count)
  static int            nMinutesN1 = -1;        // minutes n - 1 (initialized to -1 in order to immediately detect a change in minutes)
  static bool           bMp3PlayingN1 = false;  // bMp3Playing n - 1
  // Start chimes only if there on no hours chimes being
  // played, and minutes have changed.
  if((nChimeHours == 0) && (nMinutesN1 != tmTime->tm_min))
    // No hours chime is in process and minutes changed,
    // update minutes n - 1.
    nMinutesN1 = tmTime->tm_min;
    // Check for chime start on the quarter hour.
    switch(tmTime->tm_min)
      case 0:
        // Minutes == 0, start hour chime.
        Mp3Start("/12.mp3");
        // Then after hour mp3 plays, chime the hour count if not cold start chime.
        if(bChimeColdStart)
          // Cold start chime, just play the top of hour.
          bChimeColdStart = false;
          // Not cold start chime, chime the hour count.
          nChimeHours = (((tmTime->tm_hour + tmTime->tm_isdst) % 24) == 0) ? 12 : (tmTime->tm_hour + tmTime->tm_isdst) % 24;
      case 15:
        // Minutes == 15, start quarter hour chime.
        Mp3Start("/15.mp3");
      case 30:
        // Minutes == 30, start half hour chime.
        Mp3Start("/30.mp3");
      case 45:
        // Minutes == 45, start three quarter hour chime.
        Mp3Start("/45.mp3");
  // Check nChimeHours.
  if(nChimeHours > 0)
    // nChimeHours > 0, check for end of top of hour mp3 by waiting for
    // bMp3Playing to transistion from on to off.
    // Note since StartMp3() only starts taskStartMp3(), the bMp3Playing
    // flag will not be set until the os actually starts taskStartMp3()
    // thus here we check for a transition of bMp3Playing from on to off,
    // indicating that mp3 playback has indeed ended.
    if(bMp3PlayingN1 != bMp3Playing)
      // Transition, update n-1.
      bMp3PlayingN1 = bMp3Playing;
      // Check transition.
      if(!bMp3Playing)
        // On to off transition thus top of hour mp3 has ended.
        // Note when nChimeHours is > 0 it contains a valid "chime count" from 1
        // through 12.  There are 12 hour count chime files, "/Hours1.mp3" through
        // "/Hours12.mp3", on the sd card.  Build the mp3 filename for the file
        // associated with the hour chime count contained in nChimeHours.
        char  chBuffer[81];
        sprintf(chBuffer, "/Hours%d.mp3", nChimeHours);
        // Debug.
        Serial_printf("UpdateChimes(): hours chime file is \"%s\".\n", chBuffer);
        // Start the mp3.
        Mp3Start(chBuffer);
        // End of chime hours
        nChimeHours = 0;
        // Off to on transition.
      // No transition.
    // No nChimeHours.
// UpdateDstStartAndEnd
// Update the daylight savings time variables ulDstStart and ulDstEnd.
// Entry   : the year in which to generate dst variables
//         : pointer to tmClock structure
void UpdateDstStartAndEnd(int nYear, tmClock * tmTime)
  // Local variables.
  tmClock  tmTimeLocal;
  // Both user settings months must be non-zero for dst to be processed.
  if(nDstStartMonth && nDstEndMonth)
    // User desires dst, calculate the start date of dst in seconds for this year.
      // Obtain the start seconds.
        // Obtain the seconds since 1970 for the start month of the year
        // (see tmClock structure for element details).
        tmTimeLocal = {0, 0, 0, 1, (nDstStartMonth - 1) % 12, nYear, 0, 0, 0, 0, 0, false};
        tmTimeLocal.ulTime = DateAndTimeToSeconds(& tmTimeLocal);
        // Fill in the remaining tmTime elements.
        SecondsToDateAndTime(& tmTimeLocal);
        // Set tm_mday and tm_hour based on user input.
        // Note if the user enters 0 for the day, then use SecondSunday(),
        // else use the user day.
        tmTimeLocal.tm_mday = (nDstStartDay) ? nDstStartDay : SecondSunday(tmTimeLocal.tm_wday);
        tmTimeLocal.tm_hour = nDstStartHour % 24;
        // Set tmTime->ulDstStart.
        tmTime->ulDstStart = DateAndTimeToSeconds(& tmTimeLocal);
      // Obtain the end seconds.
        // Obtain the seconds since 1970 for the end month of the year
        tmTimeLocal = {0, 0, 0, 1, (nDstEndMonth - 1) % 12, nYear, 0, 0, 0, 0, 0, false};
        // Note if the user enters 0 for the day, then use FirstSunday(),
        // else use the user day.  Note also the clock logic runs on
        // ntp time which does not account for dst, so the end hour is
        // set to the user end hour - 1.
        tmTimeLocal.tm_mday = (nDstEndDay) ? nDstEndDay : FirstSunday(tmTimeLocal.tm_wday);
        tmTimeLocal.tm_hour = (nDstEndHour - 1) % 24;
        // Set tmTime->ulDstEnd.
        tmTime->ulDstEnd = DateAndTimeToSeconds(& tmTimeLocal);
    // Dst start and end are now valid.
    tmTime->bDstValid = true;
    // One or both user settings months are zero, no dst processing.
// UpdateNtp
// Update ntp time.
// Returns : true if time updated, false if not
// Notes   :
//  1) UpdateNtp operates in one of three modes, REQUEST, SENT and RECEIVED:
//    a) If nNtpPacketMode == REQUEST, UpdateNtp will create and send an ntp
//       packet to request the time, then set nNtpPacketMode = SENT to indicate
//       the packet has been sent.
//    b) If nNtpPacketMode == SENT, UpdateNtp will await a response from the
//       ntp time server.  If a response is received, UpdateNtp will convert
//       the received time from ntp time to unix time and update the tmClock
//       structure, then set nNtpPacketMode = RECEIVED to indicate that the
//       time has been received from the ntp time server.  If a response is
//       not received after five seconds, UpdateNtp will set nNtpPacketMode =
//       REQUEST to request another packet.
//    c) If nNtpPacketMode == RECEIVED, UpdateNtp will wait for the top of the
//       next hour, then set nNtpPacketMode = REQUEST.
//  2) If everything works as planned:
//    a) On cold start, nNtpPacketMode = REQUEST, and bNtpTimeRequestEnabled = false.
//    b) UpdateNtp case REQUEST sends a time request to the ntp server, then sets
//       nNtpPacketMode = SENT.
//    c) UpdateNtp case SENT waits for the ntp time server response.
//    d) If UpdateNtp case SENT receives ntp time from the server, it converts the
//       received time from ntp time to unix time, updates the tmClock structure,
//       then sets nNtpPacketMode = RECEIVED.
//    e) If UpdateNtp case SENT does not receive ntp time from the server, it downcounts
//       nNtpPacketDelay until zero, at which time it sets nNtpPacketMode = REQUEST to
//       return to 2.b and start the process again.
//    f) UpdateNtp case RECEIVED waits for the top of the next hour, then sets
//       nNtpPacketMode = REQUEST to start the process again.
//    g) If all goes well (e.g. the ntp time server responds), steps 2.b, 2.c, 2.d and
//       2.f are continuously repeated at a rate of once per hour.
//    h) If all does not go well (e.g. the ntp time server does not respond), steps 2.b,
//       2.c, and 2.e are continuously repeated at a rate of 5hz until the ntp time
//       server responds.
bool  UpdateNtp(tmClock * tmTime)
  // Local variables.
  static int              nNtpPacketDelay        = PACKET_DELAY_RESET;
  static NtpPacketMode    nNtpPacketMode         = REQUEST;             // initialized to REQUEST to immediately request ntp time on cold start
  // Determine the current mode.
  switch(nNtpPacketMode)
    case REQUEST:
      // REQUEST mode, create and initialize ntp packet.
      memset(chNtpPacket, 0, NTP_PACKET_LENGTH);
      chNtpPacket[0]  = 0b00011011;
      // Send the ntp packet (see https://tf.nist.gov/tf-cgi/servers.cgi for other ip addresses).
      IPAddress ipNtpServer(129, 6, 15, 29);
      Udp.beginPacket(ipNtpServer, 123);
      Udp.write(chNtpPacket, NTP_PACKET_LENGTH);
      Udp.endPacket();
      // Packet has been sent, on the next pass...
        // UpdateNtp is in SENT mode,
        nNtpPacketMode = SENT;
        // and initialize nNtpPacketDelay for possible UpdateNtp SENT mode
        // ntp timeouts.
      // Debug.
      Serial_printf("UpdateNtp(): ntp packet sent.\n");
    case SENT:
      // SENT mode, an ntp time request has been sent, wait for a response
      // from the ntp time server.
      if(Udp.parsePacket())
        // Server responded, read the packet.
        Udp.read(chNtpPacket, NTP_PACKET_LENGTH);
        // Obtain the time from the packet, convert to Unix time, and adjust for the time zone.
        // Unix time is indicated as the number of seconds since 1/1/1970 at 00:00.
        // NTP time is indicated as the number of seconds since 1/1/1900 at 00:00.
        // Hence there is a 70 year difference between the two, and 17 leap years
        // during those 70 years.
        // The following equation obtains the ntp seconds bytes then converts ntp
        // seconds to unix seconds by subtracting from the ntp time in seconds the
        // value (((70 * 356) + 17) * SECONDS_PER_DAY) where:
        //  1) 70 is the number of years between unix and ntp time.
        //  2) 365 is the number of days in a year.
        //  3) 17 is the number of leap years during the 70 year difference.
        unsigned long ulCurrentSeconds = tmTime->ulTime;
        tmTime->ulTime = ((unsigned long)chNtpPacket[40] << 24) +       // bits 24 through 31 of ntp time
                         ((unsigned long)chNtpPacket[41] << 16) +       // bits 16 through 23 of ntp time
                         ((unsigned long)chNtpPacket[42] <<  8) +       // bits  8 through 15 of ntp time
                         ((unsigned long)chNtpPacket[43]) -             // bits  0 through  7 of ntp time
                         (((70UL * 365UL) + 17UL) * SECONDS_PER_DAY) +  // ntp to unix conversion
                         (nTimeZone * SECONDS_PER_HOUR) +               // time zone adjustment
                         2UL;                                           // compenstation for ntp request delay
        // Received seconds, update date and time.
        SecondsToDateAndTime(tmTime);
        // On the next pass, UpdateNtp is in RECEIVED mode.
        nNtpPacketMode = RECEIVED;
        // Debug.
        Serial_printf("UpdateNtp(): ntp packet received, time in seconds = %lu, delta = %lu.\n",
                      tmTime->ulTime,
                     (tmTime->ulTime >= ulCurrentSeconds) ? (tmTime->ulTime - ulCurrentSeconds) : (ulCurrentSeconds - tmTime->ulTime));
        // Time updated.
        return true;
        // Server has not yet responded, down count nNtpPacketDelay.
        nNtpPacketDelay = nNtpPacketDelay - 1;
        // Check nNtpPacketDelay.
        if(nNtpPacketDelay <= 0)
          // Timeout, on the next pass, place UpdateNtp in REQUEST mode
          // to try again.
          // Debug.
          Serial_printf("UpdateNtp(): ntp time packet timeout.\n");
    case RECEIVED:
      // RECEIVED mode, ntp time request has been sent and received.  Wait
      // until the top of the next hour to return to REQUEST mode.
      // Local variables.
      static bool bNtpTimeRequestEnabled = false;   // latch initialized to false for cold start
      // Check minutes.
      if(tmTime->tm_min == 0)
        // tmTime->tm_min == 0 (top of hour) will occur for 60 seconds.  To
        // avoid sending 60 ntp time request packets during this time, check
        // if ntp time has already been requested for this hour.
        // I know, I know, you're asking why not check for tmTime->tm_sec ==
        // 0?  In the unusual but plausible event where the clock falls 1 or
        // more seconds behind per hour, the check for tmTime->tm_sec == 0
        // would fail so this code checks for tmTime->tm_min == 0 along with
        // the latching variable bNtpTimeRequestEnabled used as a one shot
        // per hour latch.
        if(bNtpTimeRequestEnabled)
          // Entering a new hour, place UpdateNtp in REQUEST mode for the next
          // pass.
          // Then dissable further nNtpPacketMode = REQUEST for the remainder
          // of tmTime->tm_min == 0 for the new hour.
          // Debug.
          Serial_printf("UpdateNtp(): top of hour, triggering ntp time request.\n");
          // Still in tmTime->tm_min == 0 for the new hour, do nothing, just a comment.
        // No longer in tmTime->tm_min == 0 for the new hour, enable ntp time request
        // for the next hour.
        bNtpTimeRequestEnabled = true;
  // Time not updated.
  return false;
// UpdateOled
// Update adafruit feather 2900 oled.
void  UpdateOled(tmClock * tmTime)
  // Update oled display.
    // Local variables.
    char  chBuffer[81];
    // Clear the display buffer.
    // Display the date.
    sprintf(chBuffer, "%s, %s %d%s, %4d",
            chDaysOfWeek[tmTime->tm_wday],
            chMonth[tmTime->tm_mon],
            tmTime->tm_mday,
            (tmTime->tm_mday == 1) ? "st" : (tmTime->tm_mday == 2) ? "nd" : (tmTime->tm_mday == 3) ? "rd" : "th",
            tmTime->tm_year);
    display.setCursor((display.width() / 2) - (strlen(chBuffer) * 6) / 2, 0);
    display.println(chBuffer);
    // Display the time.
    display.setTextSize(2);
    sprintf(chBuffer, "%02d:%02d:%02d%s",
           ((tmTime->tm_hour + tmTime->tm_isdst) % 24) ? ((tmTime->tm_hour + tmTime->tm_isdst) % 24) : 0,
            tmTime->tm_min,
            tmTime->tm_sec,
            (((tmTime->tm_hour+ tmTime->tm_isdst) % 24) >= 0) ? "pm" : "am");
    display.setCursor(4, 12);
    // Send the buffer to the 2900.
    display.display();
// UpdateTime
// Update time.
void  UpdateTime(tmClock * tmTime)
  // Check for an ntp update.
  if(UpdateNtp(tmTime))
    // UpdateNtp() did update time, update daylight savings start and end times.
    // Note UpdateNtp() updates ntp at the top of each hour, so after each update
    // is a good time for updating the dst start and end times.
    UpdateDstStartAndEnd(tmTime->tm_year, tmTime);
    // UpdateNtp() did not update time, manually update time
    // in seconds.
    tmTime->ulTime += 1;;
    // Update year, month, day, hours, minutes, seconds from ulTime.
  // Update daylight savings time status.
  if(tmTime->bDstValid);
    tmTime->tm_isdst = IsDst(tmTime);
// vs1053Read
// Read data from the vs1035.
// Entry   : address of data in the vs1035 to read
// Returns : data at address
unsigned int vs1053Read(unsigned char chAddress)
  // Local variables.
  unsigned int nData = 0;
  // Start spi transaction.
  SPI.beginTransaction(SPISettings(250000,  MSBFIRST, SPI_MODE0));
  // Select the vs1053.
  digitalWrite(VS1053_CS, LOW);
  // Build the read command.
  unsigned char  chBuffer[2];
  chBuffer[0] = VS1053_SCI_READ;
  chBuffer[1] = chAddress;
  // Send the read command.
  SPI.writeBytes(chBuffer, sizeof(chBuffer));
  // Give the vs1053 time to respond.
  delayMicroseconds(10);
  // Read the two byte (16 bit) response.
    // Read the upper byte.
    nData = ((unsigned int)SPI.transfer(0x00) << 8);
    // Read the lower byte.
    nData |= (unsigned int)SPI.transfer(0x00);
  // Deselect the vs1053.
  // End of spi transaction.
  // Return the data read.
  return nData;
// vs1053Reset
// Reset the vs1035.
// Entry   : nothing
void  vs1053Reset(void)
  // Keep trying to reset the vs1053 until success.
  while(true)
    vs1053Write(VS1053_REG_MODE, VS1053_MODE_SM_SDINEW | VS1053_MODE_SM_RESET);
    delay(100);
    vs1053Write(VS1053_REG_CLOCKF, 0x6000);
    delay(100);
    // Validate that vs1053 is reset.
    int vs1053Status = (vs1053Read(VS1053_REG_STATUS) >> 4) & 0x0F;
    if(vs1053Status == 4)
      // Reset, success break out of loop.
      // Reset failed, delay then try again.
      // Debug.
      Serial_printf("vs1053Reset(): vs1053 reset failed, status = %d.\n", vs1053Status);
  // Set the vs1053 playback volume.
  vs1053Write(VS1053_REG_VOLUME, (nMp3CurrentVolume << 1) + (nMp3CurrentVolume & 0xff));
// vs1053Write
// Write data to vs1053
// Entry   : address in vs1053 to write to
//         : data to write
void vs1053Write(unsigned char chAddress, unsigned int nData)
  // Begin spi transaction.
  // Select the vs1503.
  // Build the write command.
  unsigned char  chBuffer[4];
  chBuffer[0] = VS1053_SCI_WRITE;
  chBuffer[2] = nData >> 8;
  chBuffer[3] = nData & 0xFF;
  // Send the write command.
  // Deselect the vs1503.
Hello nwbuss90
Take a view at line 1438 to modifiy the void UpdateChimes(tmClock * tmTime) function to your needs.
Sorry, i'm very new with arduino codes. But what do you mean modify the void UpdateChimes(tmClock * tmTime)???
It will be something like this, which should have no impact on the remaining logic.
If you get errors, post the entire code. State also if the clock works correctly without these modifications.
put this near the top of function UpdateChimes()
// allow chimes during specified hours
uint8_t hourLocal = (tmTime->tm_hour + tmTime->tm_isdst) % 24 ;
bool chimeEnable = ( hourLocal >= 5 && hourLocal <= 22 ) ;
before each call of function Mp3Start (there appears to be 5 of them in function UpdateChimes() ) check that chimeEnable is set as in the following example :
if ( chimeEnable) Mp3Start("/45.mp3") ;
Thanks! it works perfect!
But now I realize it doesn't play back at 05:00AM. Did i do something wrong?? :thinking:
// UpdateChimes
// Update chimes.
  // Local variables.
      case 0:
        if ( chimeEnable) Mp3Start("/00.mp3");
        if(bChimeColdStart)
      case 15:
        //Mp3Start("/15.mp3");
      case 30:
        if ( chimeEnable) Mp3Start("/30.mp3");
      case 45:
        //Mp3Start("/45.mp3");
  if(nChimeHours > 0)
      if(!bMp3Playing)
        char  chBuffer[81];
        // Debug.
        // Start the mp3.
        Mp3Start(chBuffer);
        nChimeHours = 0;
      // No transition.
    // No nChimeHours.
Did it just fail for the 05:00 chime or did the chimes not restart at all ?
You have missed one:
You appear also to have commented out the 15 minutes and 45 minutes chimes (although I see no problem there and that should be OK).
The player appears to be managed over a series of global flags which I have not followed in detail. If that doesn't work and you see no obvious output on the serial console indicating it is stuck, then probably the least "invasive" way of solving this is to create an "silent" mp3 file and play that instead between 05:00 and 22:00. Something like this example but do it also for the other chimes you wish to keep :
else Mp3Start("/silence.mp3");
and in this case:
       // Start the mp3.
       if ( chimeEnable) Mp3Start(chBuffer);
