I am doing a project that I hope I can adjust the frequency in Arduino Serial Monitor. I know there is a solution which I could use "analogWrite" to do the math. Here's my code in analogWrite control:
But the value of analogWrite shows 0 - 255, I would like to use frequency value (HZ unit) to control my Buzzer's sound. I used "tone" to control it but I can't do math in "tone" syntax. Could you guys help me and provide some suggestion please?
One more question is when I used "tone" syntax and I am not sure why there's still a low sound when I set my frequency 0, like this:
const int buzzer = 9;
void setup(){
pinMode(buzzer, OUTPUT);
tone(buzzer, 0); // <===== set frequency to 0
void loop(){
Please give me some suggestion. Thank you guys so much in advance.
OldSteve:
So what do you mean by "I can't do math in "tone" syntax."
Hi OldSteve,
First of all, thanks for your help:)
I would like to control the Buzzer frequency through entering a number in Serial Monitor. Cause the code I wrote, it's the method for controlling LED by entering 0~255 in Serial Monitor to adjust the luminosity of LED. I know it's totally a different value between LED and Buzzer's frequency. So do you know any method to do controlling Buzzer's frequency by entering a number in Serial Monitor, the unit is HZ?
LarryD:
If you want to set the frequency of PWM, pins 9/10, look at the TimerOne library.
Hi LarryD,
Thank you so much for your information. I will check on it.
What about exactly what you originally wrote, but using "Tone" instead of 'analogWrite()'?
By the way, don't use '#define' for pin allocations. It can lead to errors. Use 'const byte'.
Thank you so much for your help. It's really helpful. Now I solve the problem I faced yesterday, It turns out I can control my frequency on "tone" syntax and I set "noTone" in the beginning for turning off first. Then I enter numbers as frequency in serial monitor and it totally works!!! Thank you guys all this help:)
