Hi there,
I have some problems here and i was wondering if someone smarter than me could help.
I want to adjust the time and date using some pushbuttons and rtc + lcd128x64
this is the code but it seems that i have too much errors.
I think my logic sucks...
#include "U8glib.h"
#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
// setup u8g object
U8GLIB_ST7920_128X64 u8g(13, 12, 11, U8G_PIN_NONE);
// Setup RTC
RTC_DS1307 RTC;
int P1=A4; // Button SET MENU'
int P2=A2; // Button +
int P3=A3; // Button -
int P4 = A0;
//************Variables**************//
String newHour = "";
String newMinute = "";
String newSecond = "";
String newDay = "";
String newMonth = "";
String newYear = "";
int menu = 0;
char monthString[37]= {"IanFebMarAprMaiIunIulAugSepOctNoiDec"};
int monthIndex[122] ={0,3,6,9,12,15,18,21,24,27,30,33};
String thisMonth = "";
String thisTime = "";
String thisDay="";
int clockCentreX = 64; // used to fix the centre the analog clock
int clockCentreY = 32; // used to fix the centre the analog clock
String newBtnHour = "";
String newBtnMinute = "";
String newBtnSecond = "";
String newBtnDay = "";
String newBtnMonth = "";
String newBtnYear = "";
int hourUpg, minuteUpg, secondUpg, dayUpg, monthUpg, yearUpg;
//TMP36 Pin Variables
boolean useTMP36 = false; // set this to false if you don not use TMP36
//boolean useTMP36 = false;
#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
int tempPin = 1; //the analog pin the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade with a
//500 mV offset to allow for negative temperatures
int tempReading; // the analog reading from the sensor
void checkButtons()
if(digitalRead(P4))
menu=menu+1;
// in which subroutine should we go?
if (menu==1)
setHour();
if (menu==2)
setMinute();
if (menu==3)
setSecond();
if (menu==4)
setYear();
if (menu==5)
setMonth();
if (menu==6)
setDay();
if(menu == 7)
StoreAgg();
menu=0;
delay(100);
void draw(void) {
// graphic commands to redraw the complete screen should be placed here
u8g.setFont(u8g_font_profont15);
//u8g.setFont(u8g_font_6x10);
//***** RTC **********
DateTime now = RTC.now();
// display date at bottom of screen
thisDay = String(now.day(), DEC) + "/";
thisMonth="";
for (int i=0; i<=2; i++){
thisMonth += monthString[monthIndex[now.month()-1]+i];
thisDay=thisDay + thisMonth + "/";
thisDay=thisDay + String(now.year() , DEC);
const char* newDay = (const char*) thisDay.c_str();
u8g.drawStr(32,63, newDay);
// display time in digital format
thisTime="";
thisTime=String(now.hour()) + ":";
if (now.minute() < 10){ thisTime=thisTime + "0";} // add leading zero if required
thisTime=thisTime + String(now.minute()) + ":";
if (now.second() < 10){ thisTime=thisTime + "0";} // add leading zero if required
thisTime=thisTime + String(now.second());
const char* newTime = (const char*) thisTime.c_str();
u8g.drawStr(39,10, newTime);
// Now draw the clock face
u8g.drawCircle(clockCentreX, clockCentreY, 20); // main outer circle
u8g.drawCircle(clockCentreX, clockCentreY, 2); // small inner circle
//hour ticks
for( int z=0; z < 360;z= z + 30 ){
//Begin at 0° and stop at 360°
float angle = z ;
angle=(angle/57.29577951) ; //Convert degrees to radians
int x2=(clockCentreX+(sin(angle)*20));
int y2=(clockCentreY-(cos(angle)*20));
int x3=(clockCentreX+(sin(angle)*(20-5)));
int y3=(clockCentreY-(cos(angle)*(20-5)));
u8g.drawLine(x2,y2,x3,y3);
// display second hand
float angle = now.second()*6 ;
int x3=(clockCentreX+(sin(angle)*(20)));
int y3=(clockCentreY-(cos(angle)*(20)));
u8g.drawLine(clockCentreX,clockCentreY,x3,y3);
// display minute hand
angle = now.minute() * 6 ;
x3=(clockCentreX+(sin(angle)*(20-3)));
y3=(clockCentreY-(cos(angle)*(20-3)));
// display hour hand
angle = now.hour() * 30 + int((now.minute() / 12) * 6 ) ;
x3=(clockCentreX+(sin(angle)*(20-11)));
y3=(clockCentreY-(cos(angle)*(20-11)));
// now add temperature if needed
if (useTMP36==true) {
//getting the voltage reading from the temperature sensor
tempReading = analogRead(tempPin);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = tempReading * aref_voltage;
voltage /= 1024.0;
// now print out the temperature
int temperatureC = (voltage - 0.5) * 100 ; //converting from 10 mv per degree wit 500 mV offset
String thisTemp1 = String(temperatureC) + "C";
// printing output as follows used less program storage space
const char* thisTemp = (const char*) thisTemp1.c_str();
u8g.drawStr(100,10,thisTemp);
// the print command could be used, but uses more memory
//u8g.setPrintPos(100,10);
//u8g.print(thisTemp1);
void setup(void) {
// If you want to set the aref to something other than 5v
analogReference(EXTERNAL);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
void loop(void) {
checkButtons();
// picture loop
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
// rebuild the picture after some delay
delay(50);
void setHour()
// hourUpg = String(now.hour());
if(digitalRead(P2) == HIGH)
if(hourUpg == 23)
hourUpg = 0;
hourUpg++;
if(digitalRead(P3) == HIGH)
if(hourUpg == 0)
hourUpg = 23;
hourUpg--;
newHour = String (hourUpg);
u8g.drawStr(39,10,newHour.c_str());
void setMinute()
if(minuteUpg == 59)
minuteUpg = 0;
minuteUpg++;
if(minuteUpg == 0)
minuteUpg = 23;
minuteUpg--;
newMinute = String (minuteUpg);
u8g.drawStr(44,10,newMinute.c_str());
void setSecond()
if(secondUpg == 59)
secondUpg = 0;
secondUpg++;
if(secondUpg == 0)
secondUpg = 59;
secondUpg--;
newSecond = String(secondUpg);
u8g.drawStr(49,10,newSecond.c_str());
void setDay()
if(dayUpg == 31)
dayUpg = 0;
dayUpg++;
if(dayUpg == 0)
dayUpg = 31;
dayUpg--;
newDay = String (dayUpg);
u8g.drawStr(32,63,newDay.c_str());
void setMonth()
for(int i = 0; i<11; i++)
if(monthString[i] == 11){
monthUpg == 0;
monthUpg += monthString[i];
for(int i = 11; i>=0; i--)
if(monthString[i] == 0)
monthUpg = 11;
monthUpg -= monthString[i];
newMonth = String(montUpg);
u8g.drawStr(38,63,newMonth.c_str());
void setYear()
yearUpg++;
yearUpg--;
newYear = String(yearUpg);
u8g.drawStr(44,63,newYear.c_str());
void StoreAgg()
RTC.adjust(DateTime(newHour,newMinute,newSecond);
RTC.adjust(DateTime(newDay,newMonth,newYear);
