Adjust time with RTClib.h possible?
I want to be able to adjust the time in my code using external buttons.
I plan to do it with two buttons; 1+ hour increase and 1+ minute increase
So i went ahead and found this code and it is workin as intended:
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
void setup()  {
  Serial.begin(9600); // start the serial connection to the PC.
  pinMode(2, INPUT);       // set pin 2 as an input
  digitalWrite(2, HIGH);   // activate internal pullup resistor on pin 2
  pinMode(3, INPUT);       // set pin 3 as an input
  digitalWrite(3, HIGH);   // activate internal pullup resistor on pin 3
  pinMode(4, INPUT);       // set pin 4 as an input
  digitalWrite(4, HIGH);   // activate internal pullup resistor on pin 4
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  setSyncInterval(60);        // set the number of seconds between re-sync
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC.");
     Serial.println("RTC has been read.");
  if (digitalRead(2) == LOW) {         // Zero the minutes!
                                       // setting the onboard time to 0 minutes.
    setTime(hour(),0,second(),day(),month(), year());
    RTC.set(now());                    // sending the onboard time to the RTC.
    Serial.println("Minutes Reset.");  // send confirmation to the PC.
  // *** had to adjust the adjustTime function in the Time library.
  // Inside Time.cpp, the adjustTime method was replaced with:
  //  void adjustTime(long adjustment){
  //    setTime(sysTime + adjustment);
  if (digitalRead(3) == LOW) {         // add an hour!
    adjustTime(3600);                  // adjust onboard time by +3600 seconds (1hr) ***
    Serial.println("Added an hour.");  // send confirmation to the PC.
  if (digitalRead(4) == LOW) {         // add a minute!
    adjustTime(60);                    // adjust onboard time by +60 seconds (1min) ***
    Serial.println("Added a minute."); // send confirmation to the PC.
  // this section is for setting the rtc chip from the serial terminal.
  if(Serial.available()){
     time_t t = processSyncMessage();
     if(t >0)
        RTC.set(t);   // set the RTC and the system time to the received value
        setTime(t);
  digitalClockDisplay();  // sends an update of the time to the PC.
  delay(1000);            // wait for a bit.
void digitalClockDisplay(){
  // digital clock display of the time over serial
  Serial.print(hour());
  Serial.print(":");
  printDigits(minute());
  Serial.print(":");
  printDigits(second());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*  code to process time sync messages from the serial port   */
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
time_t processSyncMessage() {
  // return the time if a valid sync message is received on the serial port.
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      return pctime;
  return 0;
The problem occurs when I try to incorporate this code to my own,
I get compilation errors, To my suspection it’s because of
#include “RTClib.h”
Is in the same code.
So to my question, as highlighted in the subject:
Is it possible to adjust time with the RTClib?
Thanks for reading.
What compilation errors do you get, and where did you get the library from?
What version of the IDE are you using?
It may be as simple as a couple of declarations in the library.
ChilliTronix:
i got the lib at GitHub - adafruit/RTClib: A fork of Jeelab's fantastic RTC library
errors:
“conflict declaration ‘RTC_DS1307 RTC’”
“‘class DS1307RTC’ has no member named ‘begin’”
“‘class DS1307RTC’ has no member named ‘isrunning’”
“‘class DS1307RTC’ has no member named ‘now’”
“request for member ‘hour’ in ‘now’ is of non-class type ‘time_t()()’”
I’m using version 1.0.6
i can post my main code if you’d like aswell
