int potPin= A0; //Declare potPin to be analog pin A0
int LEDPin= 9; // Declare LEDPin to be arduino pin 9
int readValue; // Use this variable to read Potentiometer
int writeValue; // Use this variable for writing to LED
pinMode(potPin, INPUT); //set potPin to be an input
pinMode(LEDPin, OUTPUT); //set LEDPin to be an OUTPUT
Serial.begin(9600); // turn on Serial Port
readValue = analogRead(potPin); //Read the voltage on the Potentiometer
writeValue = (255/1023) * readValue; //Calculate Write Value for LED
analogWrite(LEDPin, writeValue); //Write to the LED
Serial.print("You are writing a value of "); //for debugging print your values
Serial.println(writeValue);
This simple code will not turn in my led to be able to adjust it need help
