I've got a sensor that gives me a small voltage between 2 and 10 millivolts.
I'd like to use the Arduino to sample this sensor.
Since the voltage provided is very small, I was wondering what would be the better approach, amplifying the voltage (how?) or decreasing the reference voltage of the ADC?
The ADC cannot operate with a reference voltage below about 1V, BTW - the built-in analog reference is 1.1V, but that's still not going to help you much.
You need to amplify the signal. This is a classic case of needing an instrumentation amplifier since your signal is so small. Look at the specs for the MAX4208 for example for a 5V single-rail device with rail-to-rail capability. Mixed-signal and digital signal processing ICs | Analog Devices - other manufacturers make instrumentation opamps too!
Alternatively a single-op-amp circuit can be used but won't be as accurate due to time and temperature drift. Depends on your precision requirements (you'll definitely need a 'precision low voltage' opamp that works down to the negative rail. If your sensor has a high output impedance the instrumentation amp is the best route I think.
I had an LM358 here and tried the non inverting dc gain application from the datasheet and it is already a nice improvement. Don't know yet if it will be precise enough, so I will keep your advice on the MAX4208 and instrumentation amplifier in mind, thanks a lot!
