Is there a way to use the Arduino IDE without using administrator password
You will need to provide more details. Which version of the IDE are you using? What OS are you using?
I'm on W10 running IDE 1.8.19 and I don't get asked for a password.
Are you trying to install the IDE? There is a zip version of the 1.8.19 that I use that you can unzip to a place of your choice on your PC. As far as I know, it's all self contained.
the reason i need a password is because it needs to make changes to my device
If it is not actually "YOUR" computer but lets say work or educational then you will need to get the required permissions from your IT admin.
If you are a secondary user that too can introduce limitations.
Under windows xp upwards the primary user can install almost anything with the exception of some nasty stuff.
There is in some cases under windows a "hidden" administrator account that can be enabled.
Wont give any details other than that.
Often it helps to give information that appears to be missing in this case.
Please take a few moments to Learn and Use the Forum.
Get the best out of this forum Installation & Troubleshooting
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you donât follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your proâĻ
It will help you get the very best out of the forum in the future.
- Mention if you are using AI generated code it is valuable information.
- Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
- Always list the version of the IDE you are using and the board version if applicable.
- Use quote or CODE tags to add error messages as an attachment NOT a picture.
- How to insert an image into your post. ( Thanks sterretje )
- Add your sketch where applicable but please use CODE TAGS
- Add a SCHEMATIC were needed even if it is hand drawn.
- Add working links to any specific hardware as needed (NOT links to similar items)
- Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
- Ensure you have FULLY inserted the USB cables.
- Check you have a COMMON GROUND where required. ( Thanks Perry)
- Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
- Try other computers where possible.
- Try other USB leads where possible.
- You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
- There may be a problem with the board check or remove your wiring first.
- Remove any items connected to pins 0 and 1.
COMPUTER RELATED
- Close any other serial programs before opening the IDE.
- Ensure you turn off any additional security / antivirus just to test.
- There may be a problem with the PC try RESTARTING it.
- You may be selecting the wrong COM port.
- Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
- Clear your browsers CACHE.
- Close the IDE before using any other serial programs.
- Preferably install IDEâs as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
- CH340/341 based clones do not report useful information to the âget board infoâ button.
- NANO (Old Types) some require you to use the OLD BOOTLOADER option.
- NANO (ALL Types) See the specific sections lower in the forum.
- NANO (NEW Types) Install your board COREâs.
- Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default âAVRISP mkIIâ.
- Boards using a MICRO USB connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
- On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
- On Linux ~/ArduinoCreateAgent-1.1/config.ini
- On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
- ä¸æ (Chinese)
- Deutsch - German
- EspaÃąol - Spanish
- Français - French
- āĻ āĻ¸āĻŽā§āĻ¯āĻŧāĻž, āĻŦāĻžāĻāĻ˛āĻž, ā¤Ŧā¤Ąā¤ŧāĨ - India
- Italiano - Italian
- Nederlands - Dutch
- Portugues - Portuguese
- Đ ĐžŅŅиŅ - Russia
- Scandinavia Swedish, Suomi - Finnish, Norsk - Norwegian
Thanks to all those who helped and added to this list.
@Ballscrewbob knows far more about this stuff than I do.
But the first question that comes to my mind is what "your device" is and the second question is when "it" wants to make changes. The last question is what "it" is. Based in the limited information, I guess it's the IDE; but you don't state the version which might (or might not) be important
Yes, This is a educational computer, so is there anyway for me to use the IDE without It Admins Helps
Nobody around here will help you bypass security for your computer.
Best solution is to talk to your IT administrator.
They can give you the required priveledges to install the IDE of your choice and any drivers you may need.
Sorry but that is about the best I can give you.
