ADNS 3080 odd data
hi there guys and girls, I have a questing relating to the ADNS 3080. I’ve been playing around with the example mousecam from http://simonwinder.com and it is meant to output a number of values like x&y movement along with some camera related information like light levels but after changing to the correct spi pins on the nodemcu I’m using i am still getting just a string of ASCII like messages that don’t seem to translate to anything. so if anyone has any experience with spi on a nodemcu or might have a suggestion on a possible solution I would greatly appreciate it. this is the code I’m using
#include "SPI.h"
// these pins may be different on different boards
// this is for the uno
#define PIN_SS        10
#define PIN_MISO      12
#define PIN_MOSI      13
#define PIN_SCK       14
#define PIN_MOUSECAM_RESET     2
#define PIN_MOUSECAM_CS        15
#define ADNS3080_PIXELS_X                 30
#define ADNS3080_PIXELS_Y                 30
#define ADNS3080_PRODUCT_ID            0x00
#define ADNS3080_REVISION_ID           0x01
#define ADNS3080_MOTION                0x02
#define ADNS3080_DELTA_X               0x03
#define ADNS3080_DELTA_Y               0x04
#define ADNS3080_SQUAL                 0x05
#define ADNS3080_PIXEL_SUM             0x06
#define ADNS3080_MAXIMUM_PIXEL         0x07
#define ADNS3080_CONFIGURATION_BITS    0x0a
#define ADNS3080_EXTENDED_CONFIG       0x0b
#define ADNS3080_DATA_OUT_LOWER        0x0c
#define ADNS3080_DATA_OUT_UPPER        0x0d
#define ADNS3080_SHUTTER_LOWER         0x0e
#define ADNS3080_SHUTTER_UPPER         0x0f
#define ADNS3080_FRAME_PERIOD_LOWER    0x10
#define ADNS3080_FRAME_PERIOD_UPPER    0x11
#define ADNS3080_MOTION_CLEAR          0x12
#define ADNS3080_FRAME_CAPTURE         0x13
#define ADNS3080_SROM_ENABLE           0x14
#define ADNS3080_FRAME_PERIOD_MAX_BOUND_LOWER      0x19
#define ADNS3080_FRAME_PERIOD_MAX_BOUND_UPPER      0x1a
#define ADNS3080_FRAME_PERIOD_MIN_BOUND_LOWER      0x1b
#define ADNS3080_FRAME_PERIOD_MIN_BOUND_UPPER      0x1c
#define ADNS3080_SHUTTER_MAX_BOUND_LOWER           0x1e
#define ADNS3080_SHUTTER_MAX_BOUND_UPPER           0x1e
#define ADNS3080_SROM_ID               0x1f
#define ADNS3080_OBSERVATION           0x3d
#define ADNS3080_INVERSE_PRODUCT_ID    0x3f
#define ADNS3080_PIXEL_BURST           0x40
#define ADNS3080_MOTION_BURST          0x50
#define ADNS3080_SROM_LOAD             0x60
#define ADNS3080_PRODUCT_ID_VAL        0x17
void mousecam_reset()
  digitalWrite(PIN_MOUSECAM_RESET,HIGH);
  delay(1); // reset pulse >10us
  digitalWrite(PIN_MOUSECAM_RESET,LOW);
  delay(35); // 35ms from reset to functional
int mousecam_init()
  pinMode(PIN_MOUSECAM_RESET,OUTPUT);
  pinMode(PIN_MOUSECAM_CS,OUTPUT);
  digitalWrite(PIN_MOUSECAM_CS,HIGH);
  mousecam_reset();
  int pid = mousecam_read_reg(ADNS3080_PRODUCT_ID);
  if(pid != ADNS3080_PRODUCT_ID_VAL)
    return -1;
  // turn on sensitive mode
  mousecam_write_reg(ADNS3080_CONFIGURATION_BITS, 0x19);
  return 0;
void mousecam_write_reg(int reg, int val)
  digitalWrite(PIN_MOUSECAM_CS, LOW);
  SPI.transfer(reg | 0x80);
  SPI.transfer(val);
  delayMicroseconds(50);
int mousecam_read_reg(int reg)
  SPI.transfer(reg);
  delayMicroseconds(75);
  int ret = SPI.transfer(0xff);
  delayMicroseconds(1);
  return ret;
struct MD
 byte motion;
 char dx, dy;
 byte squal;
 word shutter;
 byte max_pix;
void mousecam_read_motion(struct MD *p)
  SPI.transfer(ADNS3080_MOTION_BURST);
  p->motion =  SPI.transfer(0xff);
  p->dx =  SPI.transfer(0xff);
  p->dy =  SPI.transfer(0xff);
  p->squal =  SPI.transfer(0xff);
  p->shutter =  SPI.transfer(0xff)<<8;
  p->shutter |=  SPI.transfer(0xff);
  p->max_pix =  SPI.transfer(0xff);
  delayMicroseconds(5);
// pdata must point to an array of size ADNS3080_PIXELS_X x ADNS3080_PIXELS_Y
// you must call mousecam_reset() after this if you want to go back to normal operation
int mousecam_frame_capture(byte *pdata)
  mousecam_write_reg(ADNS3080_FRAME_CAPTURE,0x83);
  SPI.transfer(ADNS3080_PIXEL_BURST);
  int pix;
  byte started = 0;
  int count;
  int timeout = 0;
  int ret = 0;
  for(count = 0; count < ADNS3080_PIXELS_X * ADNS3080_PIXELS_Y; )
    delayMicroseconds(10);
    if(started==0)
      if(pix&0x40)
        started = 1;
        timeout++;
        if(timeout==100)
          ret = -1;
    if(started==1)
      pdata[count++] = (pix & 0x3f)<<2; // scale to normal grayscale byte range
  delayMicroseconds(14);
  return ret;
  pinMode(PIN_SS,OUTPUT);
  pinMode(PIN_MISO,INPUT);
  pinMode(PIN_MOSI,OUTPUT);
  pinMode(PIN_SCK,OUTPUT);
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV32);
  SPI.setDataMode(SPI_MODE3);
  SPI.setBitOrder(MSBFIRST);
  Serial.begin(38400);
  if(mousecam_init()==-1)
    Serial.println("Mouse cam failed to init");
    while(1);
char asciiart(int k)
  static char foo[] = "WX86*3I>!;~:,`. ";
  return foo[k>>4];
byte frame[ADNS3080_PIXELS_X * ADNS3080_PIXELS_Y];
  #if 0
  // if enabled this section grabs frames and outputs them as ascii art
  if(mousecam_frame_capture(frame)==0)
    int i,j,k;
    for(i=0, k=0; i<ADNS3080_PIXELS_Y; i++)
      for(j=0; j<ADNS3080_PIXELS_X; j++, k++)
        Serial.print(asciiart(frame[k]));
        Serial.print(' ');
  delay(250);
  #else
  // if enabled this section produces a bar graph of the surface quality that can be used to focus the camera
  // also drawn is the average pixel value 0-63 and the shutter speed and the motion dx,dy.
  int val = mousecam_read_reg(ADNS3080_PIXEL_SUM);
  MD md;
  mousecam_read_motion(&md);
  for(int i=0; i<md.squal/4; i++)
    Serial.print('*');
  Serial.print(' ');
  Serial.print((val*100)/351);
  Serial.print(' ');
  Serial.print(md.shutter); Serial.print(" (");
  Serial.print((int)md.dx); Serial.print(',');
  Serial.print((int)md.dy); Serial.println(')');
  // Serial.println(md.max_pix);
  delay(100);
  #endif
/code]
and this is the output I'm getting from the serial monitor
0x2d
csum 0x2d
v09f0c112
~ld
2⸮t,4I⸮@⸮d⸮⸮⸮⸮⸮!Mմ0⸮ݱ%⸮%⸮%⸮k⸮%!!!1!!⸮⸮⸮!1!1a⸮1!1⸮⸮⸮̱⸮⸮⸮⸮6⸮!⸮DH
⸮⸮⸮!⸮մ0⸮ݱ⸮%%⸮%ű⸮%!!!1!!A⸮⸮!1!1a⸮1!1⸮⸮⸮H⸮⸮⸮?⸮⸮!⸮z) ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
It seems a crash or a reset on the ESP8266. MAybe ypu have to change pins like in this sketch
https://github.com/Neumi/esp8266-ADNS3080-Supertrack/blob/master/ESP8266_optiflow/ESP8266_optiflow.ino
