Hello Everyone,
I am using ADNS2620 Mouse Sensor Evaluation Board (link : ADNS2620 Mouse Sensor Evaluation Board - WIG-10026 - SparkFun Electronics) and Ardunio Uno.Also there are document (like schematics and Ardunio library) below the link. I want to get position to this module and I am using example project under the ardunio library. I shared this code under the this text. But I am taking ‘FF’ value for X and Y direction. Also I am taking advantage of some example project ;
https://www.instructables.com/id/Interfacing-With-a-Mouse-Sensor-ADNS-3050/
http://frenki.net/2013/12/convert-optical-mouse-into-arduino-web-camera/
And example code ;
/* ADNS2620 Example Sketch
* Demonstrates how to use the ADNS2620 Library to interface with the mouse sensor
* on the ADNS2620 evaluation board from SparkFun Electronics
* More register definitions are located in the 'adns2620.h' file. Read the
* ADNS2620 datasheet to understand how to use the registers.
* After loading the sketch to the ADNS2620 evaluation board, open the serial terminal
* using a baud rate of 9600 to see the output from the ADNS2620 sensor.
* Written by Ryan Owens
* 11/4/10
* SparkFun Electronics
//Add the ADNS2620 Library to the sketch.
#include <adns2620.h>
//Name the ADNS2620, and tell the sketch which pins are used for communication
ADNS2620 mouse(18,19);
//This value will be used to store information from the mouse registers.
unsigned char value=0;
//Initialize the ADNS2620
mouse.begin();
delay(100);
//A sync is performed to make sure the ADNS2620 is communicating
mouse.sync();
//Put the ADNS2620 into 'always on' mode.
mouse.write(CONFIGURATION_REG, 0x01);
//Create a serial output.
//The DELTA_X_REG and DELTA_Y_REG store the x and y movements detected by the sensor
//Read the DELTA_X_REG register and store the result in 'value'
value = mouse.read(DELTA_X_REG);
//Print 'value' to the serial port.
Serial.print("X:");
Serial.print(value, HEX);
Serial.print('\t');
//Read the DELTA_Y_REG register and store the result in 'value'
value = mouse.read(DELTA_Y_REG);
Serial.print("Y:");
Serial.println(value, HEX);
delay(10);
Where is the problem for taking the positions?
