ADNS5050
Hello! I have some problems with ADNS5050 on Arduino atmega328 board?I appreciate anyone who can help me out.I get some code on the internet but it doesnot work well.Can you post your code ? I will learn it very hard .Thank you very much!
, but I’m not going to tell you what they are.
Here is my code ,Can you help me find the problem with it ?Thank you !
#include "arduino.h"
#include "Adns.h"
 * Definitions
#define SCLK                6
#define SDIO                5
#define NCS                 4
#define PRODUCT_ID          0x00
#define DELTA_Y_REG         0x03
#define DELTA_X_REG         0x04
#define SQUAL_REG           0x05
#define MAXIMUM_PIXEL_REG   0x08
#define MINIMUM_PIXEL_REG   0x0a
#define PIXEL_SUM_REG       0x09
#define PIXEL_DATA_REG      0x0b
#define SHUTTER_UPPER_REG   0x06
#define SHUTTER_LOWER_REG   0x07
#define RESET          0x3a
#define MOUSE_CONTROL2      0x19
#define RES_CPI            0x1B
#define NUM_PIXELS          361
byte pix[361];
char  dx;
char  dy;
  pinMode(SDIO, OUTPUT);
  pinMode(SCLK, OUTPUT);
  pinMode(NCS, OUTPUT);
  sync();
  byte productId = ADNS_read_old(PRODUCT_ID);
 Serial.print("Found productId ");
  Serial.print(productId);
 // Freezes DX and DY until they are read or MOTION is read again.
     dx = ADNS_read_old(DELTA_X_REG);
     dy = ADNS_read_old(DELTA_Y_REG);
   Serial.print("DELTA:");
    Serial.print( dx, DEC);
   Serial.print("    ");
    Serial.print( dy, DEC);
     Serial.print("    ");
    Serial.print('\r');
     Serial.print('\n');
  //   pixelGrab();
//    Serial.print("FRAME:");
//    for(int i = 0; i < NUM_PIXELS; i++)
//      byte p = pix;
//      if( p < 0x10 )
//        Serial.print("0");
//        Serial.print(p, HEX);
//    Serial.println();
//byte surfaceQuality()
//  return ADNS_read_old(SQUAL_REG);
void sync()
  digitalWrite(NCS, LOW);
  delayMicroseconds(2);
  digitalWrite(NCS, HIGH);
   ADNS_write_old(RESET, 0x5a);
  delay(100); // From NRESET pull high to valid motion, assuming VDD and motion is present.
   if(ADNS_read_old(PRODUCT_ID) ==  0x12)
        ADNS_write_old(MOUSE_CONTROL2, 0x1B);
void pixelGrab()
    //ADNS_write(PIXEL_DATA_REG, 0); // start reading
    //delayMicroseconds(20);
  int grabCount = 0;
  while( grabCount < NUM_PIXELS )
    byte data = ADNS_read_old(PIXEL_DATA_REG);
    if( (data & 0x80) != 0 ) { // Data is valid
      pix[grabCount++] = data&0x7f;
void ADNS_write_old(unsigned char addr, unsigned char data) {
  char temp;
  int n;
  digitalWrite(NCS, LOW);//nADNSCS = 0; // select the chip
  temp = addr ;
  digitalWrite(SCLK, LOW);//SCK = 0;                // start clock low
  pinMode(SDIO, OUTPUT);//DATA_OUT; // set data line for output
  for (n=0; n<8; n++) {
    delayMicroseconds(1);
    if (temp & 0x80)
      digitalWrite(SDIO, HIGH);//SDOUT = 1;
      digitalWrite(SDIO, LOW);//SDOUT = 0;
    temp = (temp << 1);
    digitalWrite(SCLK, HIGH);//SCK = 1;
    delayMicroseconds(1);//delayMicroseconds(1);          // short clock pulse
  temp = data;
    if (temp & 0x80)
    temp = (temp << 1);
  digitalWrite(NCS, HIGH);//nADNSCS = 1; // de-select the chip
byte ADNS_read_old(unsigned char addr) {
  byte temp;
  int n;
  temp = addr;
  digitalWrite(SCLK, OUTPUT); //SCK = 0;                // start clock low
  pinMode(SDIO, OUTPUT); //DATA_OUT;                // set data line for output
    if (temp & 0x80) {
    else {
    temp = (temp << 1);
    digitalWrite(SCLK, HIGH); //SCK = 1;
  temp = 0; // This is a read, switch to input
  pinMode(SDIO, INPUT); //DATA_IN;
  for (n=0; n<8; n++) {       // read back the data
    if(digitalRead(SDIO)) {// got a '1'
      temp |= 0x1;
    if( n != 7) temp = (temp << 1); // shift left
  digitalWrite(NCS, HIGH);// de-select the chip
  return temp;
You still haven't told us what you perceive "the problem" to be.
Thank you for your responses.I am not sure the application of Motion ,Squal ,Pixel_Sum,Pixel_Grab.I use ADNS5050 to location on robot.I want to get X_displacement and Y_displacement. dx = ADNS_read_old(DELTA_X_REG); dy = ADNS_read_old(DELTA_Y_REG);
in my code ,Now but the changes are not very noticeable.please experts to analyze why.Thanks!
